Author Topic: Basic Electrical Components  (Read 6509 times)
  • Pogi/Ganda Points: 413
Re: Basic Electrical Components
« Reply #180 on: May 20, 2012, 11:33:37 AM »
Paano nga ba malalaman kung PNP or NPN ang transistor? Paano malalaman ang EBC terminal niya?
Offline ΔЅịMø
  • Pogi/Ganda Points: 140
  • "Live Curious"
« Reply #181 on: May 20, 2012, 12:09:10 PM »
Eto nga rin yung di ko alam sir kung di ka gagamit ng multitester eh. Pero kung may tester ka, kukunin mo lang yung resistances nila. AFAIK, yung common is yung Base. At mas malaki ang resistance ng Emiter kaysa Collector. Correct me if baliktad po. Or better have this tester. :D
TRANSISTOR TESTER
« Reply #182 on: May 20, 2012, 12:16:44 PM »
Bakit ba walang tutorial dito kung paano malaman ang EBC terminal which is which? Maski sa net at nahihirapan akong mapakiusapan si google.
Offline ΔЅịMø
  • "Live Curious"
« Reply #183 on: May 20, 2012, 12:31:20 PM »
Kaya nga po sir eh. Baka rin kasi mali yung ma-post ko na information dito. Mas maigi kung masters talaga. ;D
Offline j a y k e z
  • gimmegaggigsss
« Reply #184 on: May 20, 2012, 01:05:15 PM »
nalilito pa rin tlga ako sa mga transistorzzzz  :D
eto kaya ;D
Lecture - 10 Transistors
Offline Deantyne
  • Pogi/Ganda Points: 90
  • Focus my friend...
« Reply #185 on: May 20, 2012, 02:13:00 PM »
TRANSISTOR TESTER
baliktad Asimo.. Collector is high resistance, then low resistance is emitter..then base is common .if BLACK probe is common then it is NPN, if RED then it is PNP. :D  (BASED SA SILICON TRANSISTOR)
USING a Japanese standard tester(Sanwa) pero makukuha mo lang ang reading if your analog multitester has a 10kohms setting.
di ito mkukuha sa 1k at 100kohms settings. ;D
BACK TO BASICS
« Reply #186 on: May 20, 2012, 02:16:47 PM »
Paturo nga nyan sis.  ::)
Offline Deantyne
« Reply #187 on: May 20, 2012, 02:18:14 PM »
sis , di pa tapos tester mo:
http://www.electronicslab.ph/forum/index.php?topic=33683.0
ito kasi gamit ko pag-identify ng transistor lalo pa't erased na ang markings ng transistor, minsan Mosfet pala yong parts na erased kala ko kasi ordinaring E-B-C lang ;D
BACK TO BASICS
« Reply #188 on: May 20, 2012, 02:51:47 PM »
Hehehe basic daw kasi dito sis kaya di ko pa sinasama yan.  :D
Saka yan naman eh hinahanapan ko pa ng mga footnote on building. Ngayon me natuklasan na naman ako.
Offline kaiky14
  • Pogi/Ganda Points: 27
« Reply #189 on: May 20, 2012, 03:26:57 PM »
hehe dali lang yan. wag lang kayo gagamit ng digital tester. dapat analog gamitin nyo.. medyo nakakalito lang sa umpisa lalo na sa paghanap ng collector at emitter.. mas mataas ang resistance reading collector kesa emitter.
« Reply #190 on: May 20, 2012, 03:36:02 PM »
pwede namang gumamit ng digital na tester, gamit 'yung diode check. B-E will read slightly higher forward voltage than B-C, mas doped kasi 'yung emitter than collector.
http://www.allaboutcircuits.com/vol_3/chpt_4/3.html
Offline kaiky14
« Reply #191 on: May 20, 2012, 06:03:17 PM »
sabagay depende nalang din siguro kung san ka mas sanay or nadadalian. :)
Offline Asarnako
  • Pogi/Ganda Points: 19
« Reply #192 on: May 20, 2012, 07:27:23 PM »
Ganun pala un?
I really don't care na kasi sa base ng X'sistor, halos lahat kasi ng PCB may design image na para sa transistor kaya ende ka na malilito para ilagay ang parts....
Bute at naalala kow yung mga pinag gagawa kow nu..LoL!
Offline dummy_c
  • Pogi/Ganda Points: 162
« Reply #193 on: May 20, 2012, 08:25:32 PM »
Pa subs nito prof...
Ang transistor ang isa sa reason sa hilig ko sa electronics.
Na amazed ako noong bata pa ako magpaputok tuwing pasko using magnetic wires 20 meters long. It would not have been possible without the xtor.
Meron ako noong book, ABC's of a Transistor.
I am not sure if yan ba talaga ang title.
Sa bandang katapusan meron steps pag locate sa B-E-C ng xtor, in-circuit or out of the circuit.
Pero madali lang naman malaman saan ang base and if NPN or PNP ba. ;D
At nalimuan ko na din yung step kasi makita naman sa net at pa balik2 na ang mga ginamit kong xtors.
Usually ma identify din base sa circuit kung saan doon ang B-E-C ng xtor.
Offline ΔЅịMø
  • "Live Curious"
« Reply #194 on: May 20, 2012, 09:11:05 PM »
Maraming salamat po mga master for that clarification.. Tinitingnan ko nalang po kasi diretso sa net yung pin config ng particular xtor e kaya di ako expert. ;D ;D
+1 sir ? ? ? for opening it again, +1 for sir rd, deantyne, lurker, and kalky14 for clarifying. ;D
« Reply #195 on: May 20, 2012, 09:27:27 PM »
^ merong mga transistor from different manufacturers (generic) na iba ang pinout from datasheet kaya minsan 'di ako nagtitiwala sa datasheet lang lalo na pag Chinese 'yung gumawa. :D
actually, kapag gumagamit ako ng transistor (hindi replacement) bukod sa tester, tine-test ko talaga sa actual use kung ano 'yung pin config. mahirap na magkamali kapag nakapag-design na ng board. :D
Offline dummy_c
« Reply #196 on: May 20, 2012, 09:33:39 PM »
Ako rin. ;D
I-breadboard papailaw ng LED gamit ng 100k to 5k sa base.
Offline ΔЅịMø
  • "Live Curious"
« Reply #197 on: May 20, 2012, 09:36:04 PM »
Diretso na kasi ako sa image ni google at maghanap ng pin config e. So far po naman sir, di pa nagkakamali magbigay si google nun. At gaya rin po sa sabi ni sir asar, naka-drawing na po sa PCB yung direction ng xtor or kung circuit ang binibigay, may mga paa na dun. Pero kung sa bagay, mahalaga talaga to malaman lalo na kung ikaw na mismo mag-de-design.
Offline ΔЅịMø
  • "Live Curious"
« Reply #198 on: May 20, 2012, 09:39:41 PM »
Ako rin. ;D
Meron kapa palang net sir. ;D Bukas ko nalang po bibisitahin ang ENC. Kakarating ko lang kasi. :D
On-topic:
Gumagamit ka pala ng xtor sir para magpa-ilaw ng LED? I-sisingit ko pa pala dito yung LEDs baka bukas. Basic component rin kasi yun e.
Offline kaiky14
« Reply #199 on: May 20, 2012, 09:41:39 PM »
gawang china pala eh mortal na kaaway ng philippines ngaun yan kaya ililigaw ka haha lol :D
kung medyo komplikado magbase ka sa datasheet pero kung hindi naman try mo icheck gamit ang tester :)
