Author Topic: amplifier cabinet/casing  (Read 2981 times)
« on: January 29, 2012, 03:15:46 PM »
pa share naman sis sa mga diy amp cabinet nyo para magkaidea naman ako...yung mga amps ko walang mga casing.  ;D ;D
Offline THXneo
  • Pogi/Ganda Points: 34
  • DJ, Home Theater Fanatic
More to Lose by Seona Dancing
Re: amplifier cabinet/casing
« Reply #1 on: January 29, 2012, 03:43:03 PM »
« Reply #2 on: January 29, 2012, 08:41:55 PM »
sis THneo nabasa ko na yung post mo. pang mobile yung sa yo. sa akin pang bahay lang, 100W sa low, 50W sa high at mid. yun lng sana set up ko. may low at high na ako,pero wala pa akong amp cabinet. ;D ;D ;D
Offline THXneo
« Reply #3 on: January 29, 2012, 08:51:18 PM »
pang bahay ko lang din ito. ;D kung gusto mo standard size na amp casing.meron dun sa decibel electronics jan sa sta.cruz.sa tabi ng fire station. meron cila magandang klase na amp casing.kasya kahit 6"(height)na trafo.
« Reply #4 on: January 29, 2012, 09:03:55 PM »
ang layo ko sis, im frm cebu city. yun sanang aluminum case pero hindi ko po alam if my nagbebenta dito sa cebu.
« Reply #5 on: January 29, 2012, 09:05:13 PM »
ung aluminum nlang w/ wood, para vintage ung dating ;D
ung mga amps ko puro NPC..
No Permanent Casing ;D ;D ;D
Offline THXneo
« Reply #6 on: January 29, 2012, 09:20:21 PM »
try mo din ang ganitong klase ng casing na pang HTPC tapos konting modification lang- meron cguro sa cebu nyan
http://www.tipidpc.com/viewitem.php?iid=14393977
  • Pogi/Ganda Points: 136
« Reply #7 on: January 29, 2012, 10:21:49 PM »
Ganyan mga case ko ah.
Ma-picturan nga. ;D ;D ;D
« Reply #8 on: January 29, 2012, 10:31:55 PM »
Ayan Class A Vintage amp.
May kalawang na. ;D ;D ;D
« Reply #9 on: January 29, 2012, 10:49:49 PM »
oh yeah ;D +1
  • Pogi/Ganda Points: 98
« Reply #10 on: January 29, 2012, 11:52:53 PM »
hindi ko pa iniwire naghihintay pa dun sa traffo na pinapagawa ko :D
mga sis may alam ba kayong simple na analog vu meter driver yung one transistor lang
yung circuit ko kasi op-amp gamit thanks! ;D
parang ganyan sis classical class D ;D ;D
« Reply #11 on: January 30, 2012, 07:12:48 AM »
oo yan nga, astig nga eh kaso gusto ko talaga naked ;D
Online tony
  • Pogi/Ganda Points: 521
« Reply #12 on: January 30, 2012, 08:00:11 AM »
kung all aluminum casings, pwede kayo pagawa kay Peng ng Unity metals sa T. Alonzo....
« Reply #13 on: January 30, 2012, 08:43:51 AM »
ayus to ah perforated metal yung case. :D
+1 sir
saan banda yan sir,yung madaling makuha na location?
« Reply #14 on: January 30, 2012, 11:02:57 AM »
Isali ko yung pangit kung casing. Mali yung size ko maliit pala ito dun sa ilalaman.
Online tony
« Reply #15 on: January 30, 2012, 11:23:51 AM »
812 T. Alonzo (along c.m. recto kanan papuntang divisoria)
tel. 711-4276
« Reply #16 on: January 30, 2012, 11:26:16 AM »
paanu mo ginawa yung mga butas sa front annd back panel sis?
« Reply #17 on: January 30, 2012, 11:28:41 AM »
ahh nakarating na ako sa lugar na yan noong HS pa ako di ko lang napapansin ito,anyway salamat na marami sir Tony. :)
« Reply #18 on: January 30, 2012, 12:28:29 PM »
Drill yan sis. At tyaga sa kikil(sa chain saw, trianggular iba isang maliit at medium). Malaki kung nagamit na bit ay halos 8-10mm ang size.
« Reply #19 on: January 30, 2012, 12:35:41 PM »
ayus. +1 ka sa akin sis. ;)
