Author Topic: Using Double-sided Presensitized PCB (a technique)  (Read 3355 times)
Offline paranz
  • Pogi/Ganda Points: 177
  • 1/4W resistor specialist
    • RapidSignal Electronics
« on: June 23, 2008, 09:58:16 AM »
I'll share my technique kung paano magawa ng PCB for your circuit, using a double sided presensitized PCB.
One of the major difficulty in making a double-sided PCB is the proper aligning of pins/pads/holes in both PCB sides. I hope that by using this technique, mas mapadali ang pag-align.
I'll be using a 10 x 7.5 cm double-sided presensitized PCB i bought from e-gizmo (10 x 15 cm i cut in half  ;)).
I will also need an illustration board and a scotch tape.
Offline paranz
Re: Using Double-sided Presensitized PCB (a technique)
« Reply #1 on: June 23, 2008, 10:03:32 AM »
i will cut an illustration board to a size much bigger than my double-sided PCB. Refer to figure below.
Offline paranz
« Reply #2 on: June 23, 2008, 10:06:38 AM »
then, i will cut (using a cutter  :D) a 10 x 7.5 cm area in the middle of the illustration board, in order for my PCB to fit in.
The PCB is inserted, to test if it fits.
Offline paranz
« Reply #3 on: June 23, 2008, 10:09:28 AM »
at the same time, print ko muna ang dalawang PCB design from Ultiboard to a either a tracing paper or acetate.
I'll be using a tracing paper (much better if acetate since its transparent, unfortunately i dont have one at the moment  :( )
« Reply #4 on: June 23, 2008, 10:14:05 AM »
wow!!! talgang ginawa na ni sir Paranz ha!
thanks!:)
Offline paranz
« Reply #5 on: June 23, 2008, 10:15:02 AM »
i taped 1 of the design (also a 10 x 7.5 cm, bottom layer) to 1 side of the illustration board and i make sure that the printed design aligns to the 10x7.5 "hole" area on the illustration board
Offline paranz
« Reply #6 on: June 23, 2008, 10:15:30 AM »
thanks!:)
hehe better late than never  :D
Offline paranz
« Reply #7 on: June 23, 2008, 10:21:12 AM »
then i taped the other design (top layer) to the other side of the illustration board
Offline paranz
« Reply #8 on: June 23, 2008, 10:25:23 AM »
ganito ang itsura when both designs (copper top and copper bottom) are taped
Offline paranz
« Reply #9 on: June 23, 2008, 10:29:44 AM »
align the 2 designs properly, so that pad/holes/pins on each design matched properly. Add more scotch tape para hindi na ma-moved ang dalawang tracing paper. This is critical, or else you will get misaligned (a useless) PCB  ;D
since im using tracing paper, medyo nahirapan ako ng kunti sa alignement kasi hindi transparent. Much better if acetate ang gagamitin. But i still use tracing paper since it is much cheaper
Offline paranz
« Reply #10 on: June 23, 2008, 10:35:02 AM »
now, its time to expose the double-sided PCB.
insert the PCB (with the white coverings removed already  :D) carefully to the illustration board. Make sure you don't misalign the 2 tracing paper! Or else you have to align them again.
Then, expose the 2 sides, 1 after the other, to your favorite UV/light source.
I'm using my own fluorescent lamp for PCB exposure.
Offline paranz
« Reply #11 on: June 23, 2008, 10:37:26 AM »
i removed the the PCB from the illustration board, treat it with the developer solution (to removed exposed portion), and here is the result
copper top layer:
copper bottom layer:
  • Pogi/Ganda Points: 412
« Reply #12 on: June 23, 2008, 10:38:12 AM »
kakagawa ko lang ng K149BC na USB/Serial programmer..double sided pcb..wala ako makuna ng ordinary PCB FR4 lang available..ginawa ko single-sided then dinikit ko lang yung dalawang single-sided.. ;D ;D
badtrip! di ko napansin...di pala mirror pa toner transfer ko!!  :'( :'(
Sayang lang..
Offline paranz
« Reply #13 on: June 23, 2008, 10:40:02 AM »
then i etched the PCB.
Afterward, i inspected the PCB and the holes/pins perfectly align in each sides.
Offline Heuriskein
  • Live each day as if it is the last ...
« Reply #14 on: February 06, 2010, 09:29:57 AM »
Sir paranz ano po ba maganda pangputol ng presenboard? Ito kasi nabili ko sa alexan malaki than what i need sayang naman .okey lang po ba yong cutter lang, di ba masisira yong board?
Offline DigiEX
« Reply #15 on: March 03, 2010, 11:10:12 PM »
Lagare ng bakal.
Offline xozip_neutron
« Reply #16 on: March 05, 2010, 07:27:04 PM »
sir pano po ninyo nalink ang magkabilang side ng inyong pcb?
Offline carlsfootprints
« Reply #17 on: March 06, 2010, 01:57:58 AM »
ngaun ko lang nakita tong thread na to.. hehe..
pogi ulit ni sir paranz :)
matry nga to minsan.. hehe..
likod ng cutter pwede.. un ang ginagamit ko ngaun.. dati lagaring bakal din..
wat do you mean na link? you can see it naman po sa illustration ni sir paranz.. hehe.. critical lang talaga ung part kapag ilalagay mo na ung pcb mo.. :D
never saturate..
Offline nucleus
« Reply #18 on: March 06, 2010, 02:20:13 AM »
mas mabilis talaga yung fine tooth na hack saw/lagating bakal ;D ;D kelangan lang ng matatag na pagpapatungan :D
« Reply #19 on: March 06, 2010, 02:29:03 AM »
ako naman.. mas straight ang cut ko sa cutter kaya nagswitch na ako ;D ;D ;D
never saturate..
