Author Topic: CDR-KING 500W 12v to 220V inverter.  (Read 1450 times)
« on: February 01, 2012, 10:51:26 PM »
may el cheapo na inverter ako na nabili sa cdr-king
the problem is
* pag power on pa lang ON na agad yung fan. maingay.
* sa bench supply ko, fed with 12v, nasa .70 Amps agad.
* no load voltage is 245 volts (fluke 187 true rms)
pwede ba ito i-reverse engineer?
Re: CDR-KING 500W 12v to 220V inverter.
« Reply #1 on: February 01, 2012, 11:23:23 PM »
mataas talaga idle current niyan sis martin, doon naman sa maliliit, nasa 0.3A din ang idle. 'yan din sana ang gustong babaan ng boss ko para sa poultry niya (para tipid sa baterya kung idle naman), pero ginamit na rin as is.
ang typical output nito is modified sine (30-120-30).
« Reply #2 on: February 01, 2012, 11:39:16 PM »
ito inaabangan ko..;D
nag-iisip kasi ako na gumawa ng modified sine pero kung mura lang nman at ok yung sa CDRK dun na lang ako...may magandang casing pa...
sis baka plan mo dissect yan ha...
pasilip naman ng loob...;D
« Reply #3 on: February 02, 2012, 12:41:52 AM »
matagal din pala turn on time nya parang 200-500 ms?
di ko na measure yung time.
it's a cheapo inverter kay masaya na din ako for backup power lang naman.
kunan ko soon yung internal nya soon as ma install ko itong isang inverter sa office.
« Reply #4 on: February 02, 2012, 01:02:32 AM »
Magkanu yung 500 watts sis?
Offline bravokilo
  • Pogi/Ganda Points: 105
« Reply #6 on: March 08, 2012, 03:08:14 PM »
Find a UPS like the APC na giveaway na ang price. malamang batterya ang problemo o kaya ang charger. Use it in your car. No need for batt and no need for charger. continous yun kung sa car batt mo na.
Yung price sa CDR is really cheap...P750 ata yung 500W.
BK
Offline sp0c0
  • Pogi/Ganda Points: 38
« Reply #7 on: March 08, 2012, 03:24:24 PM »
kahapon napadaan ako sa cdr king.. yung price ng 500 watts 12v to 220v inverter e tumaas na Php. 999.00
Learning by doing..
Offline drin20
  • Pogi/Ganda Points: 17
« Reply #8 on: May 14, 2012, 10:28:06 PM »
BK
merong auto shutdown APC UPS sis.
« Reply #9 on: May 14, 2012, 10:46:47 PM »
^ mga ilang mins? kapag babagsak na ba ung out ng batt?
Offline drin20
« Reply #10 on: May 14, 2012, 10:58:35 PM »
10 to 15 mins. kahit full charge battery. napaka sensitive ng APC. sa density pa lang ng wire dapat malaki talaga. unless mag warning beep na agad.
  • Pogi/Ganda Points: 414
« Reply #11 on: May 14, 2012, 11:06:23 PM »
agree, save and shutdown talga gusto nila for some ups.
Offline Mayor Johnaray
  • Pogi/Ganda Points: 238
« Reply #12 on: May 15, 2012, 09:16:19 AM »
BK
Tita BK, hindi po pwede yan... I have APC UPS here at the office after 15 minutes nag AUTO shutdown na sya kahit Full charge... I believe meron thread dito na ni reverse Engineer nya noon yung UPS para maging constant ang supply
« Reply #13 on: May 15, 2012, 09:34:44 AM »
yung mga version na sumisindi ng walang 220v supply (luma na), kayang umandar continuously.
eto yung gamit namin sa road test dati (kinabit sa batt ng L300), TV at panghinang ang load, running from lunch 'til midnight sa tabi ng sementeryo sa Dau. ;D
« Reply #14 on: May 15, 2012, 09:35:56 AM »
though, nagpalit din kami to CD-R King inverters after few weeks. di ko na maalala dahilan.
Offline bravokilo
« Reply #15 on: May 15, 2012, 09:56:10 AM »
oops... thanks mga nieces ko.....di ko binanggit na may time our and UPS. kailangan e disable to pero e retain yung feature na shut down kapag crtical V na ang batterya.
Well, oscillator lang naman talaga ang basic principle pero may mga sensors nga lang. Yjng sa Alexan kit na nagawa ko nung araw, ganun nga. Yng naman waveform, depends kung saan gagamitin. Yung mga switching supply ng computers for example, dini DC naman yun tapos re-oscillated. prolemo kung kung may mga tansformers involved. Kung solder iron, no problem din. Or ilaw. For 220 flourescents, may 12V ballast naman, no need for inverter. I have a big one atg home . aayusin ko pa. YUASA ang brand gamit namin dati sa office.
BK
« Reply #16 on: May 15, 2012, 08:49:31 PM »
Same here...APC 600 yata yung sakin as long may laman yung battery tuloy ang andar...;D
Offline Gwenda
  • Pogi/Ganda Points: 24
« Reply #17 on: May 15, 2012, 09:46:21 PM »
Caution lang if it matters to you- lahat ng nakita kong inverter sa CD-R King ay 50Hz only.
Offline eback
« Reply #18 on: August 14, 2012, 10:49:31 PM »
mga master pwede ba ikabit d2 ung amp na 502?
