Author Topic: For Swap: ez80 Embedded Web Server sa ENC28J60 Module  (Read 1074 times)
Offline toasted siopao
  • Global Moderator
  • Pogi/Ganda Points: 107
    • TeknoBlogger
« on: February 04, 2012, 06:11:59 PM »
I have this and wala ako pag-gagamitan, swap ko kung ano ang kit or breakout board na di nyo rin gamit.
Kapag di ko na-swap, baka give away na lang sa may matinong gagamit.  ;D ;D
  • Global Moderator
    • TeknoBlogger
Re: For Swap: ez80 Embedded Web Server sa ENC28J60 Module
« Reply #1 on: February 05, 2012, 09:29:45 AM »
ez80F91 E-net Module
http://uk.farnell.com/zilog/ez80f915005modg/module-ez80f91-enet-connectivity/dp/1554228
eZ80F91 Mini Enet Module:
• eZ80F91 MCU operating at 50 MHz, with 256KB of
internal Flash memory and 16KB of internal SRAM
memory
• On-chip Ethernet Media Access Controller (EMAC)
• 128KB of off-chip SRAM memory
• Ethernet PHY and RJ-45 port
• Real-Time Clock, battery capable
• Footprint for an SIR IrDA transceiver
• Two 56-pin expansion connectors for attachment
to the eZ80Acclaim!™ Development Platform or
end-user system
eZ80Acclaim!™ Development Platform:
• Footprint for 2M x 8 external Flash memory.
• RS232 connector with interface circuit for on-chip
UART.
• ZDI and JTAG debug connectors
• Two 56-pin mini-module connectors
• Two 60-pin interface connectors for connection to
other MDS application boards (not supplied)
• 32-pin header and footprint for a GPRS modem
• Power 3.3Volt green LED
• One yellow Test LED and pushbutton
  • Global Moderator
    • TeknoBlogger
« Reply #2 on: February 07, 2012, 05:49:57 AM »
up
  • Global Moderator
    • TeknoBlogger
« Reply #3 on: February 07, 2012, 08:21:11 PM »
up
  • Global Moderator
    • TeknoBlogger
« Reply #4 on: February 25, 2012, 12:30:49 PM »
up
Offline Embedded
  • Pogi/Ganda Points: 8
  • The only thing that is permanent is change.
    • Visit Me...
« Reply #5 on: December 30, 2012, 09:11:08 AM »
sir may nag swap na sayo nito?
need mo pa ng encore module?
Offline Embedded
    • Visit Me...
« Reply #6 on: December 30, 2012, 09:14:28 AM »
ay sorry di pla encore module hanap mo sir, Ethernet Module And Demo Codes pala
Offline Mayor Johnaray
  • Pogi/Ganda Points: 238
« Reply #7 on: December 30, 2012, 11:42:15 AM »
Hmmmm
I quote: "Kapag di ko na-swap, baka give away na lang sa may matinong gagamit.   "
Akin na lang yan Paps tutal matino pa naman ako para gumamit hehehehehe ;D ;D ;D
