Author Topic: sharp primo 20v-l75m  (Read 1045 times)
Offline tatamcleanz
« on: February 05, 2012, 02:18:36 PM »
mga sis, tulong naman, e2 meron 5v at saka b+ tungo fbt. mag osc sya. tapos mawala mga 2 secs. try ko hung ung b+ tungo fbt. , ganun pa rin nag-osc tapos mawala. pls help. posible kaya eeprom to. tnx, baguhan pa kasi.
Offline Tripler02
  • Pogi/Ganda Points: 84
  • Saka na my own pic
Re: sharp primo 20v-l75m
« Reply #1 on: February 05, 2012, 04:10:17 PM »
Check vertical ic baka loscon,kung ok naman,directsub na.
Offline DJFEL
  • Pogi/Ganda Points: 44
« Reply #2 on: February 05, 2012, 05:20:12 PM »
abang sa vertical...
dj fel on the mix
Offline NORTH LUZON
  • Pogi/Ganda Points: 811
« Reply #3 on: February 05, 2012, 06:01:49 PM »
magulo ang scenario ng trobol mo sis
bakit hang na ang b+ eh nagooscillate pa?
ano ba ang sinasabi moi na nagooscillate?
more details
Offline RhUNhA
  • Pogi/Ganda Points: 356
« Reply #4 on: February 05, 2012, 07:00:01 PM »
more details
medyo naguluhan nga din ako...
resolder ka muna bka may loscon...
Offline charile
  • Pogi/Ganda Points: 23
« Reply #5 on: February 05, 2012, 07:13:55 PM »
check mo vertical section,
check mo rin crystal diode sa my parteng 180v ng FBT papuntang jungle... high resistance check mo x10k sa VOM baka may leak.. common yan sa mga primo.
RMO Electronics and Repair Center
Gen. Taino Street
Pagsanjan, Laguna
4008 Philippines
Offline jojoc
« Reply #6 on: February 05, 2012, 08:23:01 PM »
bago lang po me mga masters...san kaya ako magsisimula kase dead set or no power changhong 21F39PH tv me
Offline NORTH LUZON
« Reply #7 on: February 05, 2012, 08:38:14 PM »
gumawa ka ng new thread para sa changhong mo kapatid kasi para sa sharp ito
Offline Tripler02
« Reply #8 on: February 05, 2012, 09:16:22 PM »
jojoc.jojoc..hijacker ka ah.ehe.madali lang gumawa own thread,konting kalikot pa.=)
Offline DJFEL
« Reply #9 on: February 05, 2012, 10:20:53 PM »
basa mood lang taU mga sis...
dj fel on the mix
Offline tatamcleanz
« Reply #10 on: February 06, 2012, 04:00:55 PM »
try ko lang mga dre.
Offline tatamcleanz
« Reply #11 on: February 06, 2012, 04:08:01 PM »
oscila8 ung hot kaya lang walang suply ung fbt.
Offline Simatar
  • Pogi/Ganda Points: 29
« Reply #12 on: February 06, 2012, 06:09:11 PM »
 ??? pa subs
Offline charile
« Reply #13 on: February 06, 2012, 09:56:10 PM »
you mean may .5volts oscilation sa base ng H-out/?? pero Wala B+ ba? ibig sbihin sis? nalilito ako eh...
any way, kung wala B+ sukat ka output voltage sa sec. ng chopper... at chech mo fusibles, ecap 160v. baka mkatulong..
Gen. Taino Street
Pagsanjan, Laguna
4008 Philippines
Offline enriz622
  • Pogi/Ganda Points: 286
« Reply #14 on: February 06, 2012, 10:11:45 PM »
ilan ang boltahe sa collector sis,pag nag shutdown ba bagsak din ang b+ or steady lang,baka may problema ang vertical mo
Offline tatamcleanz
« Reply #15 on: February 07, 2012, 08:17:49 AM »
tama ka char, kuha ko na. 180 volt patungo eeprom nag changa value resistor. kaya pinalitan q ng 22k nakaseries sa crystal diode. d na kasi mkita ung 1st color ok naman. tnx mga sis.
  • Pogi/Ganda Points: 231
« Reply #16 on: February 07, 2012, 08:38:50 AM »
Congrats na pala.. pero anong location number nito, sure kaba na papuntang eeprom ito?
Offline charile
« Reply #17 on: February 07, 2012, 08:53:34 AM »
congrats sis... location nyan, susugin mo 180v galing fbt... my crystal diode dun series sa iba pang components ppuntang jungle un sis...
Kapehan na...
Gen. Taino Street
Pagsanjan, Laguna
4008 Philippines
Offline enriz622
« Reply #18 on: February 07, 2012, 09:23:41 AM »
22k 3watts ba yan supply ng tuner yan ah, may nakaharang na zener diode 33volts
Offline tatamcleanz
« Reply #19 on: February 07, 2012, 09:52:33 AM »
1/4 lang sis nakaseries pa ng isa tapos diode patungo eeprom. di ko makuha location number dun sa shop kasi. la din po akong schematic,.
