Author Topic: B+ voltage testing were to find ? anong pin nito mga sis ilang volts dapat d  (Read 536 times)
Offline ™Vensh®w™
  • High Voltage
sis tanong lang gusto ko mag voltage testing sa b+ ilang voltahin rin at saan ito makita na pin sa FBT? may naka lagay bang b+ or number lang? tnx
Whenever you're working on any electronic equipment, your own safety has to come first.Every electronic technician must always take safety precautions before he or she starts work.Electricity must be handled properly, are else it can injure or cause fatal.
Offline Deantyne
  • Pogi/Ganda Points: 90
  • Focus my friend...
sis from main Chopper transformer (psu) ,may RU2 diode don which supplies around 180volts dc going to pin of FBT -ito yong B+ ng fbt, winding connected to Collector of Hor.output xsistor..
BACK TO BASICS
Offline marcialnasi
  • Pogi/Ganda Points: 35
  • ''IT'S JUST A MATTER OF LOGIC''...
sis depende sa model at design ng tv yan..at depende rin sa gamit na regulator..to check b+ mas maganda kung me diagram ka para indicated kung ilang volts dapat sa bawat tp..kung mag rerely ka naman sa regulator usually naka indicate sa ic ng regulator kung ilang volts dapat..ex..str50103..b+ 103 volts..str50115..b+ 115 volts..str50135..b+135 volt..ang problema me mga ic na bumabase sa feedback ckt ng PSU as refference ng output or b+..like ix1791..strsXX..strwXX..schematic plus expirience pa rin sis.
  • Pogi/Ganda Points: 413
Parang kasundo yan ng Collector pin ng HOT(B+). Tama po ba sis marcial?
Offline marcialnasi
agree sis..
Offline ™Vensh®w™
  • High Voltage
ic ok.. mga sis mas maganda pala kong may diagran tama agree din ako... para doon sa mapa makita yong volts na dadaloy..... depende pala yan sa regulator din.. ok mga sis thanks sa mga info nyo ha.. big help talaga iton forum na ito sa elab dah.. tnaks.... learning..
Offline x13r_kit_0
  • Pogi/Ganda Points: 151
  • --__x13r_kit_0__--
^^sundan mo lang lagi ang sec output ng chopper measure ka sa cathode side ng diode..kung susundan mo nakakonek yan sa positive pin ng B+ ecaps usually 160v at connected din yan sa hinahanap mong fbt pin..
may mga board na na nakaprint ang mga pins ng mga component.testpoints at mga required voltage..marami din ang wala..
tama sa taas kung may mapa..syempre andun na lahat ng sagot..
"Kumain tayo at uminom,Sapagkat bukay ay mamamatay tayo"  CORINTO 15:32
   =How about the other side?=
Offline RhUNhA
  • Pogi/Ganda Points: 356
ganito din ang gawa ko...pero mas ok tlaga kung may schema ka para hindi maligaw
">>>''HiNdI mO mAkIkItA aNg TaMa HaNgGaT mAsAyA mOnG gInAgAwA aNg MaLi "<<<''
  • Pogi/Ganda Points: 812
pag sinabi mo na b+ yan at tv ang units mo means ung boltahe na papunta ng hot ang tinutukoy mo,ndi kasi pwde na b+ ng vert ckt kundi vcc ang tamang tawag dun.
masusukat mo ito dun mismo sa pangalawang ecap na malaki at nasa secondary na ito ng chopper or pulse transformer.
Offline turotoknis
  • Pogi/Ganda Points: 14
ganun pla yun.... mtry nga
mas panget mas maganda, mas maganda mas panget
Offline kaholito
ang problema po mga master saan makakuha ng diagram ng tv ung libre sa internet.? ???
Offline TBG
  • Pogi/Ganda Points: 144
sa secondary ng chopper transformer may makikita kang diode  at capacitor ,,,makikita mo kung ilang volts ang rating ng capacitor.pwede yan ang
pagbabasehan mo
schematic ang sasagot sa tanong mo sis
Offline Deantyne
^aGREE.
BACK TO BASICS
Offline jhuntronics
try mo test bawat pin ng fbt .. ohms ang range kung alin ang 0 reading yun ang b+ ng fbt..
