Author Topic: sms sending from pc to cp w/out using internet  (Read 3118 times)
Offline andromeda
« on: June 24, 2008, 12:05:13 PM »
Gud day to all... :) :)
ask q lang posana if my idea kau sa pagsesend ng sms message from pc to cp without using internet?
kasi baka isama ko po sa thesis namin... anong programming language or system ang ok na gamitin dun?  javascript lang po ba available?? ??? ???
never stop learning...
never stop living...
Re: sms sending from pc to cp w/out using internet
« Reply #1 on: June 24, 2008, 12:08:56 PM »
if you're using the old phones (FBUS/MBUS) there's gnokii (open source 'to kalikutin na lang yung source). kung AT commands (which is available on most phones today using Virtual COM port) kahit anong language basta may access sa serial port. VB gamit ko dati, pero anything sa .NET (C#, J#, C++) madali gamitin dahil available kaagad ang serialport class. ;)
Offline andromeda
« Reply #2 on: June 24, 2008, 12:35:39 PM »
bale depende po ba sa type ng phone or model ung pagpoprogram na gagawin?? super masalimuot po ba un program? basic lang pokasi alam namin... tnx po.. :)
« Reply #3 on: June 24, 2008, 12:39:27 PM »
nung gumawa ako using Motorola L70 and Motorola K1, kailangan mo lang intindihin yung serialport class ng .NET tapos konting basic sa GUI. tapos hanap ka lang ng available AT commands nung phone (sa motodev ko ata nakuha yun) pag-aralan yung AT commands. pwede munang simulate sa hyperterminal yung sequences kung AT commands. wala akong personal experience sa FBUS/MBUS, wala kasi akong phone na meron nun. ;D
Offline andromeda
« Reply #4 on: June 24, 2008, 12:56:08 PM »
tnx po!!!!!!!! pag-aaralan po namin un.... pero baka tanungin ko pa rin po kau,,, salamt po uli   :D :)
  • Pogi/Ganda Points: 412
« Reply #5 on: June 24, 2008, 12:58:06 PM »
You can used the old  Logomanager... ;D
Offline Born2BeWired
  • Pogi/Ganda Points: 168
    • e-Gizmo Mechatronix Central
« Reply #6 on: June 24, 2008, 01:02:39 PM »
With gsm modems (benq M23, siemens TC35, etc), it will be just a simple case of sending the AT command string from your PC to the gsm modem via serial transfer (PC COM PORT - modem COM port).
Example: to send "Hoy pogi!" to 0917111222
AT+CMGS="0917111222"<CR>"Hoy pogi!"<CTRL Z>
Of course there might be other housecleaning functions you will need to do before the modem will be ready to send sms messages. Housecleaning functions and actual command syntax depends on your gsm modem, but are quite easy to program. ;)
Offline zer0w1ng
  • Pogi/Ganda Points: 305
    • The Cebuano Geek
« Reply #7 on: June 24, 2008, 01:04:50 PM »
You could use wireless bluetooth link to your PC and still use AT commands to send SMS. (shameless plug)  ;D
See here http://www.electronicslab.ph/forum/index.php?topic=1330.0
BTW, I will post later a C program including the source code to send SMS thru it.
The Cebuano Geek
Offline andromeda
« Reply #8 on: June 26, 2008, 01:12:39 PM »
software po ba ung logomanager?  tsaka my background po ba kayo sa proximity limit ng pagsesend nun?tnx po... :)
Offline andromeda
« Reply #9 on: June 26, 2008, 01:19:57 PM »
wala po bang compatible phone ang nokia para dito? tsaka my distance limitati0n po ba ang pagsesend? tnx po.. :D
Offline 'yus
  • Pogi/Ganda Points: 299
  • hw -> fw -> sw
    • yus' projects
« Reply #10 on: June 26, 2008, 01:31:29 PM »
tama po, software po sya..
yung Classic Logomanager ata ang tinutukoy ni sir Kasamiko..
proximity? magde-depend yan sa network coverage (e.g. cell sites)..
Offline andromeda
« Reply #11 on: June 26, 2008, 01:43:02 PM »
tnx po ng madami...
 :D :D
Offline ef - el - ay - pee
  • Pogi/Ganda Points: 34
  • Regrets, I have a few...
    • The Taste Bytes Food Blog
« Reply #12 on: July 02, 2008, 04:19:06 PM »
GSM Module din yung irerecomend ko, aralin mo lang AT commands, tas kahit anong Language pwede, preferably C or Python.
« Reply #13 on: July 02, 2008, 09:17:02 PM »
may mga Nokia phones with built-in modem that accepts AT Commands. pero ok din yung sa bluetooth as sir zerowing said. ;D
ang na-try ko ng phones dito, Motorola K1, Motorola L70, SamsungDxxx (yun yung manipis na clamshell type). yung USB cable lang at drivers ang kailangan. masaya 'tong gamitin sa mga taong hindi mo naman kilala tapos "pre, naubos load ko pahingi namang 150" <--- send-an mo ng 150 messages per hour. ;D ;D ;D
Offline andromeda
« Reply #14 on: July 07, 2008, 12:10:57 PM »
thanks po ng madami.. ;D
« Reply #15 on: July 07, 2008, 02:01:46 PM »
ako din magtatanong...
yung mga at-commands ba, ipiniprint lang sa serial port(assuming serial port nakakabit ang gsm modem)?
so kung may nagtext sa PC ng "Hoy, pogi!"
ang reply ko sa program sa C:
printf("AT+CMGS="0917111222\r");
printf("ano yun??!! ctrl-z");      // Pano ba ang Ctrl-z????!
Offline paranz
  • Pogi/Ganda Points: 177
  • 1/4W resistor specialist
    • RapidSignal Electronics
« Reply #16 on: July 07, 2008, 02:11:55 PM »
ASCII 1A ang control-z
« Reply #17 on: July 07, 2008, 02:28:13 PM »
so tama yung assumption ko? we simply print (or send the string) to the serial port.
thanks! your the man!
« Reply #18 on: July 07, 2008, 04:46:42 PM »
yeah ganito rin gamit ko
« Reply #19 on: July 07, 2008, 08:49:30 PM »
yung ctrl-z lang mapapalitan. ;D
