Author Topic: DIY amp, ugong  (Read 1621 times)
Offline bravokilo
  • Pogi/Ganda Points: 105
Re: DIY amp, ugong
« Reply #20 on: February 08, 2012, 08:44:38 AM »
Dakuts...hi...ganda sana kung may schematics....pano baginawa ko upload...will someone teach Dakuts. may exsplanation paano sa ibang post...lagyan mo sa search "uploading picture" or "uploading image". Pero itong ang simple help ko. nagasemble sin ako ang transistoried amplifier in the 60's. ay may mga schema ako ng mag Yamaha organs...usually, pair of NPN and PNP a finals yan. Yung PNP sa taas and NPN sa baba. ang E ng NPN ground, and E ng PNP Plus rail. so, ang C nila common. tapos, may output capacitor sa C common to the speaker. Alternate ON and PNP and NPN dito, never the same time. kapag On si PNP, e chacharge nya and capacitor. kapag si NPN ang ON, e tutulag nya ang charge to the speaker. Get it? Ngayon, the voltage dun sa C junction ay dapat 0 kapag walang input!So, remove input, put a voltmeter sa junction, neg probe to ground and see the V. Ang taawag dito balancing the transistors. Now, may trimmer dapat dyan to adjust the "openness" of weither Q.(q is for transistor).
maganda san kung mayroon kang batteries and use baterries and check kung mawal ang hum. Kung nawala, eh di sa PS din, di ba?Kung 24 V yan with center  0V, maybe you can use two PSU ng computer. Gaganda yan.
BK
Re: DIY amp, ugong
  • Pogi/Ganda Points: 316
Re: DIY amp, ugong
« Reply #21 on: February 08, 2012, 12:06:01 PM »
d ung power supply unit lng po matitira dun pag palit to sakura board?
mga magkano nman price nun?
meron yan dito kay sis skyjham.
pero tirahin mo lang muna ;D ;D ;D
Re: DIY amp, ugong
Offline Mhavskie
  • Pogi/Ganda Points: 77
  • NeverShoutNever!
Re: DIY amp, ugong
« Reply #22 on: February 08, 2012, 12:39:27 PM »
linisin muna tapos resolder palit ng mga wire, pag meron pa din check yung mga filters, and mga resistor
Re: DIY amp, ugong
Offline n0th1n6
  • Pogi/Ganda Points: 62
Re: DIY amp, ugong
« Reply #23 on: February 08, 2012, 01:11:44 PM »
unang advice ko sis i Joy mo muna yan. Banlawan ng maige at patuyuin. The palitan mo mga e-caps. Mas maganda kung lahat na. Tsaka mo subukan uli :D
Re: DIY amp, ugong
Offline Johannah Aleksandria
  • Pogi/Ganda Points: 136
  • Make it simple
Re: DIY amp, ugong
« Reply #24 on: February 08, 2012, 01:16:27 PM »
Palitan mo na ng bago yung mga capacitor mo sa amp, baka leaky na yang mga yan. Lahat na at mga maliliit nman yan, mura lang.
Re: DIY amp, ugong
Offline Tukkar
  • Pogi/Ganda Points: 23
Re: DIY amp, ugong
« Reply #25 on: February 08, 2012, 04:23:01 PM »
yes try mo muna linisin yung boards at terminal baka me corroded na component pins...check mo wirings at grounding.palitan mo yung mga me kalawang at check mo yung mga cold solder o simply doblehin mo ulit hinangin mga joints pati yung sa pcb.
Offline jiggins20
  • Pogi/Ganda Points: 15
Re: DIY amp, ugong
« Reply #26 on: February 09, 2012, 05:32:31 PM »
ung sa dc offset normal lng yan..sa ugong naman check mo  ung input ground ng amp..pwede ring sa tone control at volume potentiometer..at lagpas kalahati na ung volume nagiging distorted palitan mo ng malaking traffo...
Audio amp addict
Offline dakutits
Re: DIY amp, ugong
« Reply #27 on: February 09, 2012, 09:03:07 PM »
salamat sa mga advice mga masters, xenxa na muna d pa ako makapag follow up, kc bc pa, one of this day, subukan ko kalikutin, konti lng kc alam ko electronics e, pero babase ako sa mga advice nyo.
dati nman ok sya tumunog kahit lagpas kalahati na volume, pinapaabot ko nga dati sa 3/4 e, hehehe
Offline dakutits
Re: DIY amp, ugong
« Reply #28 on: February 21, 2012, 04:45:34 PM »
nilabhan ko knina ng joy, humina ng konti ung ugong mga master, cguro nga kailangan na palitan mga ecaps, tapos mga potentiometer.
mga master ok lng ba ung pag power on ko tas nag engage ung relay for speaker e, pumipitik pailalim ung cone tas bumabalik dahan dahan?
 nagagamit ko pa din nman sya.
Offline dakutits
Re: DIY amp, ugong
« Reply #29 on: February 21, 2012, 04:59:48 PM »
up lang po...
nagcheck nga pala ako kanina ng supply nya sa magkabilang channel, naka hang, wala ung amp board ang nasukat ko 95 volts bawat isa, dba mataas yan?
sir bravokilo, yung cap at diode po ata na nasa may terminal ng speaker e, supply po ng power indicator at vu meter, dun lng ata kinuha ung ground sa may negative terminal ng speaker.
Offline n0th1n6
Re: DIY amp, ugong
« Reply #30 on: February 21, 2012, 05:24:36 PM »
Palitan mo na lahat ng electrolytic capacitors. Tsaka parang me DC na talaga na nakakarating sa speaker.
Re: DIY amp, ugong
« Reply #31 on: February 21, 2012, 06:52:10 PM »
totally agree sa iyo sir.
Offline dakutits
Re: DIY amp, ugong
« Reply #32 on: February 21, 2012, 07:02:25 PM »
mareresolve po ba ung nakakapasok na dc sa speaker mga sir kung palit mga capacitors?
Offline NORTH LUZON
  • Pogi/Ganda Points: 812
Re: DIY amp, ugong
« Reply #33 on: February 21, 2012, 07:11:10 PM »
sarap itrobolshot ang unit na ganito
Offline dakutits
Re: DIY amp, ugong
« Reply #34 on: February 21, 2012, 07:25:10 PM »
sir lakas, baka pwede mo po ipost step by step   :)
Offline NORTH LUZON
Re: DIY amp, ugong
« Reply #35 on: February 21, 2012, 07:28:48 PM »
ndi mo ba nababasa ang kasunod ng lakas sis?
Offline dakutits
Re: DIY amp, ugong
« Reply #36 on: February 21, 2012, 07:36:15 PM »
chamba? hehehe. ok lng sir baka machambahan mo din ung amp ko.
sir, ilocano ka ba?
Offline NORTH LUZON
Re: DIY amp, ugong
« Reply #37 on: February 21, 2012, 07:55:33 PM »
sir, ilocano ka ba?
paOT
pangasinan boy po ako sis
gawin mo ung mga post sa itaas sis at makukuha mo na yan
ecap ang karaniwang nasisira sa mga old amp
ung wirings nyan baka pulupot na?
palit shielded wire kung may budget ka
Offline dakutits
Re: DIY amp, ugong
« Reply #38 on: February 21, 2012, 08:02:06 PM »
ok lakay agyamanak.... :)
salamat po mga masters sa mga tulong nyo :)
Offline dakutits
Re: DIY amp, ugong
« Reply #39 on: December 11, 2012, 06:58:32 AM »
up ko lnga po, ok na pala tong amp ko, wala na ung ugong nya, grounding sa right channel po ung resolder sa base ng trapo.
salamat po sa mga nagbigay ng advice +1 po sa inyo
Re: DIY amp, ugong
