Author Topic: 24 Second Shot Clock, 10 Minutes Count Up/Down Counter and Basketball Scoreboard  (Read 799 times)
Offline AldrichDSaints
Sino po may alam ng circuit diagram nito?
Meron na po ako ng mga gamit na to:
74192
7447
7 segment
555 timer
Pa-help naman po newbie lang po ako dito eh.. Thank you po  :)
bat andaming ganitong related threads ;D
Bago lang po kasi ako dito. Now ko lang nabasa na bawal po pala ang multiple threads :)
Uo tsaka kakalito .. ikaw rin malilito.. hahah
Offline LameRock
74192
7447
7 segment
555 timer
try nyo simulate sa circuit maker para makita mo ung output.. :)
74192
7447
7 segment
555 timer
kaya nyo yan,, way back year 2007-2008(2nd year 2ndSem) yan ang biglang pinagawa samin ng prof ko..
after namin magawa, biglang sinabi na papalitan ng MCU yung controller nya hahah at dun nagsimula kalbaryo ko sa MCU.
basa basa lang ng datasheet ng ng components na yan..
dont forget yung debounce ckt for the input ng 74xx192.. =)
goodluck=)
Offline Interlock()
  • Pogi/Ganda Points: 16
  • Puppet.Xander
Google ka muna then post mo d2 ung diagram or make ur own muna based dun sa naresearch mo.
then tanong ka kung meron kng ndi naiintindihan... :D
Everything Under CONTROL.
Just Master the Basics.
In every action there's always an equal reaction.
- Newton's 3rd Law of Motion
