Author Topic: Samsung la46a70 lcdtv series7  (Read 447 times)
Offline mikeee
« on: February 12, 2012, 05:18:35 PM »
mga boss need HELP my 46" lcdtv .. may line cya right side about 4-5 inch vertical .. then almost may mga spike mga sub title nia ... plssssssss help! try ko na napalitan ang t-con  nia still ganun padin .. i check the main board but all the capacitors is solid and in good condition(actual inspect ko lang d ko ginamitan ng tester)  any suggestion ??????? mikeee d ako makapag post ng picture??
Offline NORTH LUZON
  • Pogi/Ganda Points: 812
Re: Samsung la46a70 lcdtv series7
« Reply #1 on: February 12, 2012, 08:07:03 PM »
mga boss need HELP my 46" lcdtv .. may line cya right side about 4-5 inch vertical .. then almost may mga spike mga sub title nia ... plssssssss help! try ko na napalitan ang t-con  nia still ganun padin .. i check the main board but all the capacitors are solid and in good condition(actual inspect ko lang d ko ginamitan ng tester)  any suggestion ??????? mikeee d ako makapag post ng picture??
mali ito
dapat check mo kung ok pa ang capacitance
wag magtiwala sa physical look ng component
Offline panyero
  • Pogi/Ganda Points: 93
  • scratch my back and i scratch another back
« Reply #2 on: February 13, 2012, 05:33:32 AM »
pwedeng main board pwede rin screen,
post ka ng pix kapatid.
Offline jaguar3275
  • Pogi/Ganda Points: 126
  • BAKLA LANG ANG MAGTAMPO AT MAG EMOT2X!!!
« Reply #3 on: February 13, 2012, 12:52:55 PM »
pa subs...
Exodus 15:2 The LORD is my strength and my song, and he has become my salvation; this is my God, and I will praise him, my father’s God, and I will exalt him.
Offline mikeee
« Reply #4 on: February 13, 2012, 05:37:00 PM »
Sorry, you are not yet allowed to post links. ayaw mag post ng picture???
Offline mikeee
« Reply #5 on: February 13, 2012, 05:50:50 PM »
help mga bosing ayaw mag post picture am not allowed pa daw ??
Offline RhUNhA
  • Pogi/Ganda Points: 356
« Reply #6 on: February 13, 2012, 06:42:09 PM »
pa sub,,,
Offline panyero
Offline panyero
« Reply #8 on: February 13, 2012, 07:07:39 PM »
parang ganito
Offline mikeee
« Reply #9 on: February 13, 2012, 08:30:04 PM »
yes ganyan na ganyan! pero sa right side cya.... any procedure how to fix it??
Offline mikeee
« Reply #10 on: February 13, 2012, 08:31:34 PM »
thanks sa effort for posting....@ panyero
Offline panyero
« Reply #11 on: February 13, 2012, 10:51:37 PM »
right side yan sis nakabaliktad lang kasi.tingnan mo yong sa group sa Fb may mga comment don.
