Author Topic: pakilagyan naman po ng comment each line ng mikroC prog n ito  (Read 369 times)
Offline spelter
« on: February 12, 2012, 10:16:48 PM »
volatile bit rx_event;
volatile bit sw_u;
volatile bit sw_d;
volatile bit btnSW;
char RxDat[10];
char tmp[7];
#define LswD PORTA.B0
#define LswU PORTA.B1
#define Proxity PORTA.B2
#define TraRED PORTB.B6
#define TraGREEN PORTB.B0
#define MotorDn PORTB.B2
#define MotorUp PORTA.B3
void RxStatus() {               //data receive part
    char *res;
    res = strpbrk("U",RxDat);
    if(res > 0) { sw_d=0; sw_u=1; }
    res = strpbrk("D",RxDat);
    if(res > 0) { sw_u=0; sw_d=1; }
    res = strpbrk("R",RxDat);
    if(res > 0) { TraRED = 1; TraGREEN = 0; }
    res = strpbrk("G",RxDat);
    if(res > 0) { TraRED = 0; TraGREEN = 1; }
    res = strpbrk("S",RxDat);
    if(res > 0) { TraRED = 0; TraGREEN = 0; }
void main() {
    rx_event=0;
    sw_u=0;
    sw_d=0;
    btnSW=0;
    PORTA = 0;
    PORTB = 0;
    TRISA = 0b00000111;
    TRISB = 0b00110010;
    ADCON1 = 0b11111111;
    UART1_Init(9600);    //initialize baud rate 9600
    Delay_ms(100);
    PIR1.RCIF = 0;       //?
    PIE1.RCIE = 1;       //?
    RCSTA.SPEN = 1;      //?
    INTCON.PEIE = 1;     //?
    INTCON.GIE = 1;      //?
    PWM1_Init(255);      //?
    Delay_ms(100);
    PWM1_Set_Duty(130);  //?
    PWM1_Start();        //?
    Delay_ms(1000);      //?
    while(1) {
       if(rx_event) { rx_event=0; RxStatus(); }
       if(PORTB.B5 == 0) {
          Delay_ms(20);
          if(PORTB.B5 == 1) {
             if(LswU == 0) sw_d=1;
             else if(LswD == 0) sw_u=1;
       if(Proxity == 0) {
          Delay_ms(15);
          if(Proxity == 1) {
             Delay_ms(1000);
             UART1_Write_Text("PASS");
       if(sw_u) {
          PWM1_Set_Duty(150);
          MotorDn = 0;
          MotorUp = 1;
          sw_u=0;
       if(sw_d) {
          PWM1_Set_Duty(80);
          MotorUp = 0;
          MotorDn = 1;
          sw_d=0;
       if(LswU == 0) MotorUp = 0;
       if(LswD == 0) MotorDn = 0;
void interrupt(void) {
    if(PIR1.RCIF) {
       UART1_Read_Text(RxDat, "\n", 10);       // "\n"?
       rx_event=1;
Re: pakilagyan naman po ng comment each line ng mikroC prog n ito
« Reply #1 on: February 12, 2012, 10:20:43 PM »
read mikroC manual as well as its MCU's Datasheet...
« Reply #2 on: February 12, 2012, 10:31:39 PM »
volatile bit sw_u;
volatile bit sw_d;
volatile bit btnSW;
char RxDat[10];
char tmp[7];
    char *res;
void main() {
    rx_event=0;
    sw_u=0;
    sw_d=0;
    btnSW=0;
    PORTA = 0;
    PORTB = 0;
    TRISA = 0b00000111;
    TRISB = 0b00110010;
    Delay_ms(100);     // delay by 100ms
    PIR1.RCIF = 0;       //?
    PIE1.RCIE = 1;       //?
    RCSTA.SPEN = 1;      //?
    INTCON.GIE = 1;      //?
    PWM1_Init(255);      //?
    PWM1_Start();        //?
    Delay_ms(1000); // delay by 1000ms
    while(1) {  // loop forever
       if(PORTB.B5 == 0) {
          Delay_ms(20); // delay by 20ms
          if(PORTB.B5 == 1) {
       if(Proxity == 0) {
          Delay_ms(15); // delay by 15ms
          if(Proxity == 1) {
       if(sw_u) {
          PWM1_Set_Duty(150);
          MotorDn = 0;
          MotorUp = 1;
          sw_u=0;
       if(sw_d) {
          PWM1_Set_Duty(80);
          MotorUp = 0;
          MotorDn = 1;
          sw_d=0;
    if(PIR1.RCIF) {
       rx_event=1;
eto na contribution ko. ;D
Offline spelter
« Reply #3 on: February 12, 2012, 10:48:33 PM »
salamat po
more details pa po ung sa mga complicated parts naman :)
Offline spelter
« Reply #4 on: February 12, 2012, 10:49:25 PM »
PIC18F1220 pala ginamit ko dito
Offline gwapa
« Reply #5 on: February 12, 2012, 11:57:37 PM »
Read the manual, use google.
is this your homework?
Offline kmb36td
  • Pogi/Ganda Points: 5
« Reply #6 on: February 13, 2012, 12:27:06 AM »
very bad code.....
happy troubleshooting... hehehe
Offline motion55
  • Pogi/Ganda Points: 244
« Reply #7 on: February 13, 2012, 05:55:47 AM »
    PIR1.RCIF = 0;       //?
    PIE1.RCIE = 1;       //?
    RCSTA.SPEN = 1;      //?
    INTCON.GIE = 1;      //?
Pwede ko i-bigay sayo ang sagot pero di mo matutunan paano hanapin. Ituro ko na lang paano hanapin.
Download the PIC18F1220 datasheet. Sa PDF reader, search mo ang RCIF, RCIE, SPEN, PEIE, at GEIE. Makukuha mo ang explanation with a little common sense.
"Set your mind free!"
Offline dummy_c
  • Pogi/Ganda Points: 162
« Reply #8 on: February 13, 2012, 07:12:21 AM »
Yah nasa data sheet lang yan TS.
    PWM1_Init(255);      //?
    PWM1_Start();        //?
Ito naman makikita mo ito sa mikroc's PWM example. Or tingin ka lang sa help ng mikroC then search mo PWM.
Offline spelter
« Reply #9 on: February 13, 2012, 09:12:22 AM »
salamat.. i'll try :D
Offline dummy_c
« Reply #10 on: February 13, 2012, 09:24:35 AM »
You'll try?? You're funny. ;D ;D ;D ;D ;D ;D
Offline spelter
« Reply #11 on: February 13, 2012, 10:25:23 AM »
i saw all the codes but it's a bit hard to understand
Offline dummy_c
« Reply #12 on: February 13, 2012, 04:19:38 PM »
That is why kailangan mo basahin ang datasheet at help file ng mikroC TS.
Huwag na i-try pa. Kasi kailangan talaga eh, kailangan, kailangan. ;D ;D ;D
Trust me if babasahin mo datasheet makikita mo yan. Search mo lang sa datasheet.
Yang PWM nasa mikroC help yan. Search mo lang din.
