Author Topic: DTMF kit  (Read 381 times)
Offline cperocker
DTMF kit
« on: February 14, 2012, 12:25:27 PM »
good day sa inyong lahat  ;D
tanung ko lang po kung meron nito dito.. hehe
DTMF Opto kit
-Morse Transpond
-Opto coupled input
-4 digit security ID
Details
There is one relay output offering clean contacts, and one Opto coupled input offering complete isolation from the circuit being monitored.
You can switch the output on/off remotely with or without a 4 digit security code. The decoder also has a TX keying output to key a transmitter for transponding a Morse confirmation. There is also an audio output for the Morse audio tones.
The PCB has been designed to allow 3 input configurations - unbalanced audio, an Electret microphone or balance audio to be connected.
The Opto input can be interrogated and a Morse confirmation received confirming the current state (on or off).
It's easy to turn the output on/off. Just send the decoder its ID followed by 0 and * for ON or # for OFF e.g. 12340* turns the output on and 12340# turns the output off.
And if you want to toggle the output, just send for example 12340A and the state of the output will be changed to the opposite of its previous state. The Morse transpond will be confirmation of the new state. If you want to pulse the output send e.g. 12340B and the output will turn on for 0.5 seconds - the Morse transpond will be 0 P.
PLUS you can now use 9 for A and 8 for B with 12 key DTMF pad.
Morse
For confirmation of the switching of the output the decoder will key a Transmitter and respond in Morse code. Turning on the output will respond as 0 ON in Morse, and turning off the output will respond as 0 OFF. There is a 2 second transpond delay followed by a 400ms link establishment delay to allow for CTCSS (if used).
Input
You can also interrogate the current state of the Opto 1 input by sending the ID followed by 1* e.g. 12341* and the decoder will transpond in Morse 1 OFF or 1 ON depending on the input state.
Change the 4 digit security ID
It's easy to change the 4 digit security ID. Simply fit a jumper to the middle 2 pins of CN3, powering up the decoder and sending it a new 4 digit ID with DTMF. Remove power, remove jumper, then power-up and your new ID is set. If no ID is required then simply program the ID as 0000 and on next power-up no ID will be needed and e.g. 0* will turn on the output.
Switch off the Morse Transpond
You can choose to turn off the Morse transpond. When setting the 4 digit identity, just add a fifth digit as 9 and the Morse transpond will be turned off. Any other character in the fifth position turns the Morse transpond on. When supplied the identity is 1234 and the fifth digit is set as 0. You do not need to program the fifth digit if transpond is desired, the fifth digit is not used as part of the identity.
The PCB is a high quality Gold Plated double sided PTH (plated through hole) 1.6mm FR4 (Fibreglass) board 64 x 38mm in size.
DTMF kit
Offline bravokilo
  • Pogi/Ganda Points: 105
Re: DTMF kit
« Reply #1 on: February 15, 2012, 07:56:38 AM »
So, CProcker, you have this and you do not need help if I read you right. i am into RF TX and RX and can do mulitplexing(time) for up to 9 ports. This is used in RC but can be modi to become a code...
BK 0922 281 0680
Re: DTMF kit
