Author Topic: PC INTERFACING with SOFTWARE  (Read 579 times)
Offline vpm28
« on: February 17, 2012, 12:53:49 PM »
mga kuya/ate, patulong naman po. Hindi ko kasi alam yung mga kailangan na mga gamit para makapaginterface ako.
Kailangan ko kasi magprogram gamit TASM para maginterface (testing lang, pailaw ng LED). Ang tanong ko po, anong connection ang kailangan ko?
(i) Pwede po ba yung USB to RS232? saan po nakakabili nito?
(ii) Eh kung parallel port naman po, bibili ako ng PCI parallel port card, possible rin po ba to?
Windows 7 po gamit kong os.
Salamat po sa mga sasagot :)
Offline PlCUSER
  • Pogi/Ganda Points: 153
Re: PC INTERFACING with SOFTWARE
« Reply #1 on: February 17, 2012, 01:04:51 PM »
ung TASM mo, assembler. ano ba iproprogram mo?
Offline vpm28
« Reply #2 on: February 18, 2012, 11:37:27 PM »
nakabili na ko ng usb to rs232 sa cdr king yung HL-340. ang problema ko, hindi siya madetect ng system ko.
Unknown device siya under USB, eh di ba dapat nasa ports siya? nainstall ko naman yung driver.
Windows 7/64 bit gamit kong OS.
Gusto ko lang sana magpailaw ng LED gamit yung serial port ng walang MCU. Patulong po pakiusap.
Offline PlCUSER
« Reply #3 on: February 19, 2012, 12:03:36 AM »
install mo muna nang maayos ung driver nang usb2rs232 mo. gmg.
ung serial port, may 2 output pin. dtr rts. gnd out kapag enabled. now do your math.
Offline carlsberg11
  • Pogi/Ganda Points: 30
« Reply #4 on: February 19, 2012, 02:08:53 AM »
sir wala po bang driver na binigay sa inyo yung cdr king?
Anyone who has never made a mistakes has never tried anything new.
-Albert Einstein
Offline carlsberg11
« Reply #5 on: February 19, 2012, 02:11:26 AM »
http://www.mediafire.com/?a2do2xdnzofynsm
yan po driver ng usb to rs232 ng cdr king, try mo po. nag work po kasi sa akin yan. hope mag work din po sa inyo :D :D :D
-Albert Einstein
Offline dummy_c
  • Pogi/Ganda Points: 162
  • If I die 2nyt, 8's bcoz maimai is not at my side!
« Reply #6 on: February 19, 2012, 08:28:28 AM »
Cdr king usb to serial cable working perfectly sa akin.
Windows 7 32 bit.
More than 5 pcs na Cdr king usb to serial cable ang na connect ko na sa laptop ko, so far walang isang pumalya.
Isauli mo yang cable at papalitan mo sa kanila if may warranty pa.
Been there than that already. -sir motion555
http://tinyurl.com/3glkuc5
Although not in assembly. ;D ;D
The world's technology is always changing, no doubt about it, and I hope it’s a while yet before it impacts my ability to tinker.
Offline vpm28
« Reply #7 on: February 19, 2012, 10:57:57 AM »
salamat po sa mga sumagot. hindi pa rin po gumana sa akin, tingin ko kasi OS ko Win7 64 bit. meron ba sa inyo napagana sa ganung OS?
subukan ko nalang sa ibang OS.
Offline vpm28
« Reply #8 on: February 19, 2012, 11:02:16 AM »
ay possible po ba yun kuya, servo motor iinterface sa PC? hmm?
Offline carlsberg11
« Reply #9 on: February 19, 2012, 11:32:41 AM »
sir win 7 and 64 bit din po gamit ko. na try mo na yung binigay ko na driver? oki po kasi sa akin....
-Albert Einstein
Offline PlCUSER
« Reply #10 on: February 19, 2012, 11:36:20 AM »
mahihirapan kang magpatakbo ng pc interfaced dc servo motor without mcu.
Offline vpm28
« Reply #11 on: February 19, 2012, 04:56:54 PM »
@carlsberg11  - ginamit ko po yung driver niyo, pero ganun pa rin, Unknown Device pa rin siya.
Sinubukan ko rin sa Windows XP, kahit nainstall na yung driver ng maayos, Unknown Device pa rin pero may Unknown port na kasama.
« Reply #12 on: February 19, 2012, 04:59:40 PM »
Manual install ???
Offline Arvie
« Reply #13 on: March 04, 2012, 11:11:47 AM »
Try mong gamitin eh yung USB-to-RS232 ng e-gizmo. mga P252.00 un.
It uses Prolific chip, easy to install yung driver at available pa sa website ng Prolific.
Nagamit ko na sya sa thesis ko.
Gamit ko eh VB.NET Language for the software and C Language for the AT89S52 Microcontroller then USB-to-RS232 para makacommunicate yung Software sa Microcontroller.
Offline candyreyes
« Reply #14 on: March 04, 2012, 10:01:04 PM »
okay na kuya @Arvie, napagana ko na Assembly Language, yung kasi required sa amin. Virtual com port kasi yang mga vb.net at c#, kaya pwede rekta.
