Author Topic: TA2024 Bulilit class T stereo Amp  (Read 2254 times)
Offline Dandy
  • Pogi/Ganda Points: 31
« on: February 28, 2012, 01:40:52 PM »
Just to Share this class T amp from Tripath TA2024  15W/channel,  for general low power applications amplifier for your use.  It measure  52cm by 62cm,  I find its use when I am in need of a center and surround amplifier for my 5.1 AV project.  Personally,  the high frequency is good enough when used in full range apps.   I do not think I can consume the 15W/channel  for the center and surround,  perhaps I just need less than 5W of it - its not how big the sound to makes me satisfy, its the sound coming from different speakers, front-center-rear - making to use low power amp.
It's not our design, just seen it in the live market, and it cost around  370 php  (around means, depending on RMB to PHP conversion).  I plan to order few for my Field Trial on the  DTS/Dolby decoder, in case you like this amp, you may add up to my order.
With +12V power supply, it match with most Tone control and equalizer or other audio processing,  it also match for my DTS/Dolby decoder which even I do not use external Low pass filer to filter most digital spurious on the decoder IC, it works so far  (in the hobby level, not ever tried EMC on the lab).  One thing I notice is that, with shared dc power supply, less problem on hum noise even 4 of this amp are cascaded.    One problem is that, the IC is SOP Power Pack - a SMD , its hard to diy control the "sleep" by connecting a wire from MCU directly from the IC pin.
Offline ditchie
  • Pogi/Ganda Points: 100
  • wish ....wish...
Re: TA2024 Bulilit class T stereo Amp
« Reply #1 on: February 28, 2012, 01:50:40 PM »
subscribing.
magkano lahat, door to door to tacloban?
planning to order one for my mp3 player.
--Mahatma Gandhi
« Reply #2 on: February 29, 2012, 09:39:31 AM »
Stereo ba Ito sir?
  • Pogi/Ganda Points: 316
« Reply #3 on: March 03, 2012, 07:35:12 PM »
how much ;D
Offline DJFEL
  • Pogi/Ganda Points: 44
« Reply #4 on: March 03, 2012, 07:44:26 PM »
abang mood..nice one..
dj fel on the mix
Offline Dandy
« Reply #5 on: March 03, 2012, 09:51:54 PM »
« Reply #6 on: March 03, 2012, 10:47:25 PM »
I'm interested on this? How much kaya?
Offline Dandy
« Reply #7 on: March 17, 2012, 02:27:07 PM »
oh yeah, handy and easy to use,  the price is on the first post.
Offline ditchie
  • wish ....wish...
« Reply #8 on: March 17, 2012, 03:26:21 PM »
^sir dandy reserve me one. gamitin ko sa mp3 player na nakuha din sa inyo kasya eto sa alexan casing na maliit.
--Mahatma Gandhi
Offline fantom_mayonaise
  • Pogi/Ganda Points: 30
« Reply #9 on: April 16, 2012, 02:26:05 PM »
interested din. for 5.1 use
Offline ditchie
  • wish ....wish...
« Reply #10 on: April 16, 2012, 03:01:43 PM »
anu na kaya update nito. meron na ba stock?
--Mahatma Gandhi
Offline SexyPaint
  • Pogi/Ganda Points: 25
« Reply #11 on: April 16, 2012, 05:12:41 PM »
Pa sub din...ganda neto...
Offline Dandy
« Reply #12 on: April 19, 2012, 01:12:00 PM »
well,  just let me know, we can purchase it while many guys are in China - they will go abck this end of week or early next week.
Offline gliderman
« Reply #13 on: April 19, 2012, 01:26:23 PM »
pa subscribe po.
« Reply #14 on: April 19, 2012, 02:28:44 PM »
two units for me sir dandy.
fantom_mayonaise - 2kits(?)
« Reply #15 on: April 21, 2012, 12:39:29 PM »
Pa-cancel na po :)
Offline ditchie
  • wish ....wish...
« Reply #16 on: April 21, 2012, 01:23:03 PM »
sir dandy here is the order list.
1 unit - ditchie
--Mahatma Gandhi
Offline Dandy
« Reply #17 on: April 21, 2012, 02:03:48 PM »
1 unit - ditchie
Got it, you will have it next week
Offline ditchie
  • wish ....wish...
« Reply #18 on: April 21, 2012, 02:08:45 PM »
mode of payment sir. and location ko is tacloban city, magkano lahat
--Mahatma Gandhi
Offline Dandy
« Reply #19 on: April 21, 2012, 02:58:14 PM »
the module is cost 370php plus air21 of 120 php..    send to me your full address and phone by PM para mapadala once I arrived in Manila sometimes next week.
