Author Topic: ECE Thesis Suggested Topics  (Read 91762 times)
Offline Google
  • Pogi/Ganda Points: 20
Re: ECE Thesis Suggested Topics
« Reply #160 on: June 02, 2009, 07:47:25 AM »
MCU-based na system sa pagpapalaki ng mga kangkong ;D
Offline paul_dhoze
« Reply #161 on: June 05, 2009, 11:04:27 PM »
any bluetooth application ;D????
Offline McMillan
  • <"innocent but not ignorant">
« Reply #162 on: June 19, 2009, 11:21:12 AM »
automated flood gate controll with water level sensor..any idea bwt that topic?..how's the procedure and what are the possible components to be used?..ok lang naman cguro no kahit miniture lang?..and abwt sa water level sensor,pwede naman cguro na mag base sya sa pressure ng water sa gate...
Offline ajak
  • Pogi/Ganda Points: 50
« Reply #163 on: June 20, 2009, 12:55:29 AM »
start a new thread para matulungan ka ng mga master dito
eto tingnan mo po ito..
http://njhurst.com/electronics/watersensor/
« Reply #164 on: June 20, 2009, 03:39:03 AM »
actually madame p0 tay0ng project na pedeng gawin using this bt, the only idea is replacing the wire with this WPAN, the advantage is the security and m0re access due t0 flexibility when it c0mes t0 cust0m pr0grams... like f0r example y0u can have a cust0m pr0gram for y0ur m0bile ph0ne let say a rem0te, n0w y0u can c0ntr0l/c0mmand y0ur h0me/office appliances thr0ugh this...
Offline Google
« Reply #165 on: June 20, 2009, 10:33:18 AM »
PASA-Charge ;D ;D ;D ;D
Offline jennylyn
« Reply #166 on: June 20, 2009, 02:17:40 PM »
HEY, HELP NAMAN PO AKO SA THESIS KO. ANG HIRAP MAGHANAP EH
  • Pogi/Ganda Points: 151
« Reply #167 on: June 20, 2009, 02:21:07 PM »
It only mean di ka naghahanap kasi sobrang dami ng possible project its up to you to think an application.
Offline jennylyn
« Reply #168 on: June 20, 2009, 02:23:32 PM »
GANUN, NAGHAHANAP NA NGA PO AKO EH. KAYA NAPUNTA AKO D2 SA WEBSITE NA 2. 1ST TIME KO LANG KZ GAGAWA EH. SORRY NAMAN PO
Offline Mayalin22
  • Pogi/Ganda Points: 409
« Reply #169 on: June 20, 2009, 02:29:11 PM »
ganyan sagot ko sa kabilang thread  :D :D :D ako pa daw ang galit.. dapat meron munang idea... then mas marami kayong makukuhang advice and comment sa mga master...  ;)
Offline ef - el - ay - pee
  • Pogi/Ganda Points: 34
  • Regrets, I have a few...
    • The Taste Bytes Food Blog
« Reply #170 on: June 20, 2009, 02:46:58 PM »
wag naman po sana all caps, ;)
Offline jennylyn
« Reply #171 on: June 20, 2009, 03:02:40 PM »
sorry po mga masters. first time po kasi eh.
hmmmm, visit ko muna ung mga sites ni ate maditah. taz tanung nalang ako mgainfo na need ko. sana po maraming tumulong sakin. ^_^, thanks
« Reply #172 on: June 20, 2009, 04:47:44 PM »
jenn, consider t0 atleast t0 kn0w the background of y0ur study, we can help y0u if y0u will y0urself..
Kindly pr0vide us,our needed infos like, scope and limitati0n of studies,type of applicati0n, theme(if there's any), y0ur kn0wledge scope,time frame and so on and so f0rth..
Just relax..Dont be to rush..
Offline Fullmetal1788
« Reply #173 on: June 20, 2009, 08:38:01 PM »
mga sir ang gusto po kc ng professor nmin eh magbebenefit ung skul dun s project n ggwin nmin.. nhihilo nku kakaisip. :o :-[ :-[ andami n nming naipropose puro nireject lahat.. 6 kc kmi s group.
buti p kau 6, kmi 3 lng T_T huhuhu
One world One Dream
Offline kraze
  • The electrons is not there till we put it there
« Reply #174 on: June 20, 2009, 08:44:06 PM »
uu nga ang daya,kami din 3 lng...Hehe, dapat meron karin Plan B kung sakaling kapusin kayo sa oras... Minsan kasi maraming lumalabas na problema lalo na pag malapit na presentation.
Offline Google
« Reply #175 on: June 20, 2009, 08:52:22 PM »
standard na yata ang tatluhan ... pababa ng pababa next na riyan baka isahan na ;D ;D
problema talaga yung gastos :( okei lang na 2 or 3
Offline stealthyassassin
« Reply #176 on: June 20, 2009, 09:34:24 PM »
Sir Elektron,
May nakagawa na po ba nung Weather Station? Yun kasi naisip kong SP tapos sa pagsearchsearch ko eh napadpad ako sa site na to, hehehe.
Pwede pa ba makuha ng group namin yun for proposal? Ang plano ko sana eh through Zigbee ipapadala ung information from the different sensor modules to the base station or receiver na may LCD display. Nagawa na po ba to?
Sayang pala sir, hindi ka namin teacher ngayong sem  ;D, parepareho pala tayo estudyante ngaun, hehehe. Pero sir na sir ka pa rin po dito sa forum. Thanks po sa lahat na natutunan namin sayo.
Offline Google
« Reply #177 on: June 20, 2009, 09:40:10 PM »
Sir Elektron,
may nakagawa na ata nyan
« Reply #178 on: June 20, 2009, 09:49:01 PM »
Ah ganun po ba? Haaaaaaaaaay.......
Salamat po. Mabuti nang malaman ng maaga para makapag-isip pa ng iba, hehehe ;D
« Reply #179 on: June 21, 2009, 01:07:45 PM »
sa iba nga eh isa lang eh..
ahm.. ayun.. just keep on posting here and let us be updated with your thesis so that we can help you ^_^
