Author Topic: Simple PWM Class d Amp 200w  (Read 7910 times)
Offline flyback
  • Pogi/Ganda Points: 62
« on: March 12, 2012, 01:17:35 PM »
Baka my gusto mag try already tested and working
Knowing GOD is not being good,Knowing GOD is just knowing him as my friend
Offline jiggins20
  • Pogi/Ganda Points: 15
Re: Simple PWM Class d Amp 200w
« Reply #1 on: March 12, 2012, 01:29:51 PM »
pwede post ng schematic sis?
Audio amp addict
Offline flyback
« Reply #2 on: March 12, 2012, 01:34:47 PM »
sis up ko lang
 pls be aware that schematic is no inductor connected\
link ng pcb
http://www.sendspace.com/file/kc9ke8
  • Pogi/Ganda Points: 324
« Reply #3 on: March 12, 2012, 01:37:55 PM »
available po ba locally ung IC?
TL074 pala ginamit :D
Offline flyback
« Reply #4 on: March 12, 2012, 01:42:49 PM »
yes TLO74 lang yan
Offline flyback
« Reply #5 on: March 12, 2012, 01:46:24 PM »
hehehe uu sis kaya nga simple yung masilan lang dyan matching ng inductor ,,,easy to start class d
!!warning max voltage 50vdc only
Offline jiggins20
« Reply #6 on: March 12, 2012, 01:50:56 PM »
di ko madownload sis?
Audio amp addict
Offline flyback
« Reply #7 on: March 12, 2012, 01:52:43 PM »
click mo yung hehehe
Click here to start download from sendspace
may ibang link kasi kasali dyaan
EE ferrite core with gap with bobbin will work  kung meron kang lcr meter mas mabuti
Offline TinTopHack
  • Pogi/Ganda Points: 154
« Reply #8 on: March 12, 2012, 01:54:24 PM »
sis up ko lang
Interesting... seems the 3rd op-amp stage rightwards up to the output form a relaxation oscillator. The audio signal from the 1st and 2nd op-amp stage modulates the pulses generated. I think you need both an inductor and cap at the output to filter the PWM pulses...
Offline flyback
« Reply #9 on: March 12, 2012, 01:57:13 PM »
yes po sis thats why i posted no indutor at filter but sa pcb may terminal na po yung indutor
inductor 22uh filter is 1uf 250volts
note yung bd139's/140's lagyan lang ng maliit na heatsink normal na mag heat yan
Offline jiggins20
« Reply #10 on: March 12, 2012, 02:03:51 PM »
di ko tlga  madownload sis...hehehe
Audio amp addict
Offline flyback
« Reply #11 on: March 12, 2012, 02:05:00 PM »
email mo sis?
ito yung mounting ng irf540 .irf9540 ko
Offline jiggins20
« Reply #12 on: March 12, 2012, 09:15:13 PM »
Audio amp addict
Offline flyback
« Reply #13 on: March 12, 2012, 10:32:20 PM »
file sent sis
Offline mund24
  • Pogi/Ganda Points: 37
  • Certified Boy'z
« Reply #14 on: March 12, 2012, 11:08:08 PM »
ganda sir +1
pm nalang kita sir my email add, send na din ng schematic, thanks sir
Offline RaffT
  • Pogi/Ganda Points: 103
  • more on R-n-D
    • MY Bots
« Reply #15 on: March 12, 2012, 11:14:37 PM »
parang nakita ko na ito? sa SONY ba ito?
Offline flyback
« Reply #16 on: March 13, 2012, 10:57:54 AM »
D ko po alam kung Sony po yan but this was develop by Jtagle from Spanish forum
pm answered and file sent thru email
  • Pogi/Ganda Points: 414
« Reply #17 on: March 13, 2012, 07:38:11 PM »
Mga magkano magastos less power supply? tamang-tama sa LCR ko...;D
Offline flyback
« Reply #18 on: March 13, 2012, 08:00:22 PM »
d aabot ng 1k yata yung 2 channel nyan d kasi ako nag total sa mga diy ko
yung mga EE core 1uf 250v caps makukuha mo sa pc psu
try nyu tingnan sa new port price
ex:
TL074CN-O        14.00
IRF540N        50.00
IRF9540        50.00
BD139        10.00
BD140        10.00
@ sis Kasamiko pls share you working lcr meter pls accurate po ba sya
« Reply #19 on: March 13, 2012, 08:04:02 PM »
waw. :D magawan nga ng PCB toh.
