Author Topic: TDA8950TH/TDA8953TH class D power amp with reserved PoweR  (Read 2939 times)
Offline Dandy
  • Pogi/Ganda Points: 31
« on: March 13, 2012, 10:33:44 AM »
The big brother of TDA8920BTH,
Left Amp :  DR100W_PA   with  TDA8920BTH    (used in the DR100 conCEPT Project)
Right amp :  TDA8950TH / TDA8953TH
For fellows hobbyist who are still eyeing for a higher power digital class D power amplifier.
Specs says :   TDA8950TH - 150Wrms/channel at 4 ohms   :  300Wrms Stereo
                    TDA8953TH  -  210Wrms / channel at 4 ohms  :  420W Stereo
Well,  I am on Field Trial (FT)  on the part of TDA8950TH the PCB and circuit is not yet finalized,  you are welcome to join the adventure while on FT stage,  I am still getting the IC TDA8953TH from Singapore, it seems cannot locate in China - our friends there find the TDA8953J  but not the TDA8953TH.
Offline mund24
  • Pogi/Ganda Points: 37
  • Certified Boy'z
Re: TDA8950TH/TDA8953TH class D power amp with reserved PoweR
« Reply #1 on: March 13, 2012, 10:54:58 AM »
wow pa sub sir dandy!
tempting talaga yang class d na amp nyo! ^_^
  • Pogi/Ganda Points: 540
« Reply #2 on: March 13, 2012, 11:51:39 AM »
yummy!!! i like that.....ano projected price at kailan ang kits?
Offline Dandy
« Reply #3 on: March 13, 2012, 12:14:10 PM »
friends,  were looking for the TDA8953TH IC mukhang mahirap hanapin itong IC na ito masubukan muna sana ang performance niya,  itong PCB ay naka design para lang sa IC na ito  - allowing bigger heatsink and headroom for power supply  (and of course an options to allow the younger brother chipset TDA8950TH and TDA8920BTH).
The success and availability of this project is dependent on the availability of the TDA8953TH IC.
« Reply #4 on: March 13, 2012, 12:49:18 PM »
i suggest you contact ic maker directly so they can point you to the correct source.....here's one........http://www.nxp.com/products/amplifiers/audio_amplifiers/class_d/TDA8953.html#ordering
Offline 01110011
  • Pogi/Ganda Points: 101
« Reply #6 on: March 13, 2012, 02:28:09 PM »
bitin ako sa power nung 8920  :D
Offline pEN DoTA
  • Pogi/Ganda Points: 187
« Reply #7 on: March 13, 2012, 04:29:59 PM »
pa subs...
GOD LOVES YOU
Offline hilltopcrew
« Reply #8 on: March 13, 2012, 09:09:01 PM »
Up!
Offline mund24
  • Certified Boy'z
« Reply #9 on: March 13, 2012, 09:44:19 PM »
ganun sir!
kailangan na siguro if medyo nabibitin for sure pasok sa panlasa mo o natin yung TDA8953TH :D :D :D
Offline Dandy
« Reply #10 on: March 14, 2012, 11:01:23 AM »
Thanks for the feedback on the outsourcing,  I wish Alibaba can cater the small fish,  hmmmmm, even now, it is confusing,    http://www.alibaba.com/product-gs/520018202/TDA8953TH_N1.html,     the price is really rocks, which is easy to tell that,  di nila alam ang ginagawa nila,  I contacted them and the moq is 100 pcs at such a high price.
Goodluck to my friends who are helping in the sourcing.
Offline Dandy
« Reply #11 on: March 14, 2012, 11:07:45 AM »
ooh,  you may need the 1,800Wrms/channel BTL TA3020 class T  high power apps,    3,600W rms stereo at 8 ohms load....  di ka na mabibitin niyan.
Offline 01110011
« Reply #12 on: March 14, 2012, 11:11:07 AM »
ganun sir!
hehe bitin talaga  kasi compared to a classic pioneer amp rated at 60watts (daw) talo pa rin yung DR100
Offline Dandy
« Reply #13 on: March 14, 2012, 11:52:11 AM »
I am thinking that the DR100W used 8 ohms speaker, or, the power supply may not enough.  When the DR100W  comes with rated power supply (+/- 27Vdc) and load (4 ohm) , it should reach a minimum of 65Wrms/channel driven at input sensitivity  (tested on 1KHz sinewave),  this will not be true if the load is 8 ohms.
Even the TDA8950TH,  the power rating is based on the 4 ohms load, also the TDA8953J - well,  all these brothers are evaluated from 3 to 6 ohms load for SE, and 8 ohms load on BTL.     We do not have measurement on SPL or power rating in functional music test.
If we have already a ready speaker, it is important to match this speaker to our amplifier - otherwise, we are expecting something from our power amplifier which cannot be attain.
« Reply #14 on: March 14, 2012, 03:18:56 PM »
i am one who is not bothered by specs......i will not operate near the limit anyway....i am always after sound quality........i stopped counting watts a long time ago......
  • Pogi/Ganda Points: 321
« Reply #15 on: March 14, 2012, 04:40:53 PM »
I CONCUR sir.
Offline danny
  • Pogi/Ganda Points: 324
« Reply #16 on: March 15, 2012, 01:52:33 AM »
yessss the best
danny
Offline mund24
  • Certified Boy'z
« Reply #17 on: March 15, 2012, 02:45:40 AM »
like it!  ;) ;) ;)
pansin ko medyo madugo yung TA3020 :'( :'(
Offline Dandy
« Reply #18 on: March 17, 2012, 02:26:04 PM »
like it!  ;) ;) ;)
I'm in to this solution for high power, mainly for curiousity, but accoridnlgy, this can be operate in the SE mode,  siguro 600Wrms/channel at 4 ohms,  1,200Wrms stereo with correct PSU.
Offline mund24
  • Certified Boy'z
« Reply #19 on: March 17, 2012, 07:53:36 PM »
nice sir! :) diba gumagamit eto ng mosfet sa OPS
Ok eto if kit but for diy mahirap lalo sa mga newbie! gaya ko!
