Author Topic: TDA8950TH/TDA8953TH class D power amp with reserved PoweR  (Read 2814 times)
Re: TDA8950TH/TDA8953TH class D power amp with reserved PoweR
« Reply #20 on: March 17, 2012, 08:06:55 PM »
Di pa tumunog yung sakin heto na naman?
pigilan ko muna laway ko..:P
  • Pogi/Ganda Points: 98
« Reply #21 on: March 18, 2012, 12:32:24 PM »
^hahaha kaya nga hindi ko muna inorder yung 8950 kasi alam ko na may mas malakas pa  ;D ;D
Offline mund24
  • Pogi/Ganda Points: 37
  • Certified Boy'z
« Reply #22 on: March 18, 2012, 02:59:17 PM »
guys may bagong niluluto si sir dandy!
quiet muna ako baka mapurnada! :)
sana matuloy! pag may kit sya nun sure kukuha ako!
Offline Dandy
  • Pogi/Ganda Points: 31
« Reply #23 on: March 18, 2012, 04:49:01 PM »
lol!   I like your thread on the LM4702, iyan reference ko   http://www.electronicslab.ph/forum/index.php?topic=32310.msg607228;topicseen#msg607228 ,  kasi compairing ko ang predriver na IC LM4702  and then predriver na digital class T,  both performance at saka price saka availability,  if several guys will be interested, why not to make the kit version  (provided may mag invest).  Pero gagawin kon lang iyan with MCU control and with catching LCD displays, not just the amplifier.
Back to topic,  loko kasi iyong intsik na agent kala niya madali kukuha ng IC na SMD, iiwanan na tuloy ako napahiya na.  Baka palitan nalang ng package na DIP iyong IC.    Of course makakauha tayo sa ibang bansa ng SMD, medyo gold nga lang ang dating, kung para sa akin, may pambili na pero kung maramihan na, medyo mabigat na kaunti.   what I am planning now is :
1.  Add extra pad for DIP accomodating TDA8953J and possibly TDA8954J,  check ko ang pcb designer
Offline mund24
  • Certified Boy'z
« Reply #24 on: March 23, 2012, 12:15:32 AM »
thanks sir dandy! :)
any update with this amp and other perspective amp?
« Reply #25 on: March 30, 2012, 10:41:03 AM »
sir dandy may available ba nito na kit, if meron sir let me know
maraming salamat!
-saging
Offline Dandy
« Reply #26 on: March 30, 2012, 12:38:20 PM »
maraming salamat!
-saging
Still in the bringup test,  gumamit na ako ng DIP na package for interwork with TDA8953/54 kasi mahirap humanap ng SMD.  I update you once available.
« Reply #27 on: March 30, 2012, 01:36:54 PM »
ok sir, interested po ako ;D
binili na po yung dr100 ko ng kapitbahay namin,
papalitan ng mas malakas ;D
Offline Dandy
« Reply #28 on: March 30, 2012, 04:41:59 PM »
It takes more time to finished this project behind real hectic job,  pasyal ka dito sa baguio para ma test natin iyong prototype, may humming pa due to grounding issue, kapag nagko-nnect-connect na ang mga ibang modules.  Sorry po, hindi ito available within next month.
If need mo talaga malakas, around 600W stereo, puwede kita i-order ng digital class T,   attend ako ng HK Elecronic show  by first 2 week of april 2012,  hand carry ko na for you.    You can opt also to get one 1,800Wrms/channel into 8 ohms  3,600W stereo, puwede din  1,200Wrms stereo sa isang module - all are digital class T power amplifier.
Offline mund24
  • Certified Boy'z
« Reply #29 on: March 30, 2012, 04:45:52 PM »
wow demanding yung mga wattage ng mga yab sir dandy!
napipigsa dagita sigudo :)
« Reply #30 on: March 30, 2012, 06:06:38 PM »
nyaah :D :D
200watts would be fine ;D
balitaan mo nalang ako sir
TY!
Offline Dandy
« Reply #31 on: November 14, 2012, 07:19:09 PM »
hello... just an update.
I go back to the DR100W_PA, re-design the PCB and added some stuff like VU meter, improved the Standby control.  See here,  http://www.1diycentre.com/new_dr100w_pcb.html
In this PCB version,  it can handle the 100Wrms stereo and 200wrms Stereo, at least now,  we have good source of HSOP24 package,  The TDA8953TH, it is hard to find and do not have stable source.
It's the end of the story......!
We've (I've) been testing  higher power solution like 300Wrms/channel (600Wrms stereo into 4 ohms), a digital Class T ,  at the end ----- I do not need that amount of power for a normal house (with normal listening ear).   what I realized is the lack of
1.  Good Speaker Systems
2.  Good CD player   (now, i begun to dislike MP3)
to really have a good hi-fi music.
Maybe, this is where I focus.
Offline cyrusnicole
  • Pogi/Ganda Points: 40
  • WORK LIKE A SLAVE.....DRINK LIKE A KING..!!!!!
« Reply #32 on: November 14, 2012, 11:54:33 PM »
san ka sa baguio sir?...
work like a slave...drink like a king   :)
Online sp0c0
  • Pogi/Ganda Points: 38
« Reply #33 on: November 15, 2012, 12:17:54 AM »
very interesting thread. ang yummy ng pinaguusapan. ;D
yung pangalawa kong DR100W hanggang ngayon e di pa natunog. suspect ko e may tama yung IC. mataas yung dc offset ng kabilang channel. :)
Learning by doing..
Offline Dandy
« Reply #34 on: November 15, 2012, 12:47:16 AM »
Sir,  please try to re-solder the IC once more, let me know if this can fixed the issue.  thanks
San Luis, Naguilian Road, Baguio City
Online sp0c0
« Reply #35 on: November 15, 2012, 12:56:10 AM »
sir ni resolder ko sya last week pero still ganun parin ang problem. thanks
Learning by doing..
Online sp0c0
« Reply #36 on: November 15, 2012, 05:21:33 AM »
i resolder ko ulit mamaya sir using hot air. thanks po.
Learning by doing..
Online Ron_21
  • Pogi/Ganda Points: 27
« Reply #37 on: November 15, 2012, 06:08:05 AM »
pasub muna sis Dandy. :)
I am a DBA.
Offline cyrusnicole
« Reply #38 on: November 15, 2012, 07:45:54 AM »
thanks sa reply sir....sa magkaroon rin ako niyan...
Offline Dandy
« Reply #39 on: November 23, 2012, 08:23:32 AM »
Looking forward....  keep moving
