Welcome,
Guest
. Please
login
or
register
1 Hour
1 Day
1 Week
1 Month
Forever
Home
Help
Search
Login
Register
Instrumentation, Test Equipment and Materials
Insulation Resistance Test ?
« previous
next »
Print
Pages: [
1
Go Down
Author
Topic: Insulation Resistance Test ? (Read 288 times)
squelch
Size AAA Battery
Pogi/Ganda Points: 1
on:
March 16, 2012, 02:13:05 PM »
ano ba yung purpose ng IRT sa motor ?
Logged
on:
Solar Power Satellite
Pogi/Ganda Points: 433
Re: Insulation Resistance Test ?
Reply #1 on:
March 16, 2012, 05:05:38 PM »
Check mo "megger" sa search natin.
moisture test, insulation, atbp. Or hintayin natin mga master natin sa field.
Logged
Reply #1 on:
tony
Technical People
Pogi/Ganda Points: 539
Gender:
leach amp afficionado
Reply #2 on:
March 16, 2012, 08:30:44 PM »
Quote from: squelch on March 16, 2012, 02:13:05 PM
to find out that the motor stator winding are not soaked with moisture.........moisture is bad and can lead to motor burn-out due to breakdown of insulations....
on motors that are over 30kw, polarization index is also taken, any index greater than 1 is acceptable....
Logged
http://www.diyaudio.com/forums/power-supplies/191730-tonys-latest-traffo-diy-build-10.html
Reply #2 on:
squelch
Size AAA Battery
Reply #3 on:
March 24, 2012, 01:36:20 PM »
how about for the Transformer ?
Logged
Reply #3 on:
tony
Technical People
Gender:
Reply #4 on:
March 24, 2012, 04:16:55 PM »
about the same, if you read the DEP i sent you, you will understand better...
Logged
Reply #4 on:
Reply #5 on:
March 24, 2012, 04:18:25 PM »
woi ako rin sir tony pa send din.
Logged
tony
Technical People
Gender:
Reply #6 on:
March 24, 2012, 04:19:42 PM »
pm me yung email add mo...
Logged
Reply #6 on:
Print
Pages: [
1
Go Up
« previous
next »
