Author Topic: DIY induction cooker/heater  (Read 3254 times)
Offline Pinoy_Tech
  • Pogi/Ganda Points: 181
    • My YT-Channel
Re: DIY induction cooker/heater
« Reply #40 on: March 25, 2012, 10:40:52 PM »
^ sir Tony salamat sa info...
« Reply #41 on: April 10, 2012, 06:50:29 PM »
I was having a light reading about SMPS and skin effect is one of the consideration. and so I have to read about skin effect.
generally, skin effect is the tendency of high frequency AC to pass only on the skin of the conductor.
At 60 Hz, the skin depth of a copper wire is about 1⁄3 inches (8.5 mm). At 60 kHz, the skin depth of copper is about 0.01 inches (0.25 mm). At 6 MHz[5], the skin depth is about 0.001 inches (25 µm). Round conductors larger than a few skin depths don't conduct much current near their axis, so that material isn't used effectively.
litz wire daw ang ginagamit na wire para di masayang ang inner part ng conductor.
at dahil dito, nalaman ko na Litz wire pala ang ginagamit sa coil ng induction cookers.
http://en.wikipedia.org/wiki/Skin_effect
http://en.wikipedia.org/wiki/Litz_wire [may picture dito ng coil ng induction cooker]
  • Pogi/Ganda Points: 522
« Reply #42 on: April 10, 2012, 07:41:52 PM »
some also use 6mm copper tubings, that will also work.....
Offline e-tronix
« Reply #43 on: April 10, 2012, 09:28:11 PM »
subs
« Reply #44 on: April 11, 2012, 10:51:06 AM »
yes sir, I guess that will work just fine.
basta ginagamit ang tube-like conductors to lessen the cost of the material.
pati na din ang weight and flexibility of the conductor.
« Reply #45 on: April 11, 2012, 11:00:42 AM »
copper tubes are also used in very sort wave transmitters, precisely because of skin effect....
Offline roltex_rohit123
« Reply #46 on: May 22, 2012, 09:35:34 PM »
use refrigerator coil tubes. they are hollow. buy from a scrap store. they would be pretty cheap. you could introduce water cooling to the coil.
« Reply #47 on: May 22, 2012, 09:41:36 PM »
hey friends please give me a good schematic of a working induction heater able to heat upto 1500 degree celcius capable of melting about 50 gm of iron. i am very eager to build my own induction heater.
Offline drin20
  • Pogi/Ganda Points: 17
« Reply #48 on: May 22, 2012, 10:31:23 PM »
pa sub
« Reply #49 on: May 24, 2012, 10:55:17 PM »
circuit diagram any body please??
  • Pogi/Ganda Points: 412
« Reply #50 on: May 24, 2012, 11:41:35 PM »
Check this out..
http://www.icct.ru/Practicality/Papers/30-03-2010/Invertor-01.php
It's in Russian just translate it via Google...;D
BR
Offline efren
  • Pogi/Ganda Points: 210
  • old school audio fanatic
« Reply #51 on: May 24, 2012, 11:42:21 PM »
backread, start from the beginning, links are provided...
"just keep 'em glowing"
« Reply #52 on: May 25, 2012, 12:50:54 AM »
thankyou kasamiko. it is really great. if parts are available in lcal market i will make it withn a week. hank you very much!!
Offline Pinoy_Tech
    • My YT-Channel
« Reply #53 on: May 27, 2012, 06:41:52 AM »
Mga sis, bukod sa Newport (Manila) may alam ba kayong mabibilhan ng IR2153? Out of
stock daw ito ngayon sa newport at di rin naman daw available sa ibang tindahan kasi
nilibot na ng brother ko yung kahabaan ng Raon.
