Author Topic: SAKURA Power AMPLIFIER ko nasira..HELP!po  (Read 1087 times)
Offline Roland
  • Pogi/Ganda Points: 204
  • I always compete to myself
Re: SAKURA Power AMPLIFIER ko nasira..HELP!po
« Reply #20 on: April 03, 2012, 10:20:40 AM »
ilabas na ang bolang crystal!!!!
Offline SexyPaint
  • Pogi/Ganda Points: 25
« Reply #21 on: April 03, 2012, 10:53:34 AM »
wala na si TS....busy...
Offline jazMyn<3u
« Reply #22 on: April 05, 2012, 03:44:02 PM »
lols,.wala nang crystal basaG na po:D:D:D
Offline jazMyn<3u
« Reply #23 on: April 05, 2012, 03:52:09 PM »
ano po ba yang 3pins na D2394?para saan po yan?.,.para kasing transistor eh.,yan lang kasi transistor nakikita ko sa board ng Amp ko.,
5 pcs nang ganyan andito.,pano po buh echeck yan kung sira???
Offline gorex
  • Pogi/Ganda Points: 45
« Reply #24 on: April 05, 2012, 04:15:31 PM »
tingnan mo sa circuit diagram at basahin mo yung schematic simula sa power supply then yung block diagram mula sa pre amp to power amp. step 1. check power supply kung me tamang boltahe at check filter capacitors at diodes . check mo yung output transistor check mo mga pins niya.voltage ng  c to b then b to e .or tangalin mo output transistor check mo mga pins nila. baka nasunog sa sobrang pag video ke di na kaya ng amps ang taas kasi ng boses.joke lang pre. check din yung protection circuit yung relay trans at diode. isolate mo lang step by step para di ka malito.
Offline Pinoy_Tech
  • Pogi/Ganda Points: 171
    • My YT-Channel
« Reply #25 on: April 05, 2012, 06:07:28 PM »
Transistor nga yan pero parang ang liliit naman para gawing power output tsaka bakit lima,
walang kapares yung isa? Yan lang ba ang nakita mong may 3 paa? Mukhang quasi at low
wattage lang ang amp mo tapos nilagyan mo siguro ng malalaking speaker tapos napakinggan
mo yung paborito mong music at hala hataw si volume, hmmm! Wala lang naisip lang he he!
Pag test ng transistor? May NPN at PNP tayong pinagbabasihan, di mo na ba ma recall yun?
Meron tayong leak, short at open testing, tapos sa tester make sure na di depektibo
yung x1 or x10 bago gamitin. Pano ba 'to uumpisahan eh tulog yata ako ng itinuro sa akin yan,  ;D ;D !
Di mo ba ma picturan tapos send mo via PM kahit kanino dito makisuyo ka na lang para ma upload
sa topic mo para di na ilabas yung bolang butas  :D.
Offline jazMyn<3u
« Reply #26 on: April 06, 2012, 10:08:35 AM »
saLamat mga tecHNosis..:D cge subukan mga tips nyo...Update ko agad pagkatapos..
KODAKan ko din ..este picturan pala..:D
Offline n0th1n6
  • Pogi/Ganda Points: 62
« Reply #27 on: April 06, 2012, 10:26:45 AM »
Picturan mo na kahit VGA na cellphone lang basta maliwanag. Para me idea ang mga masters pano ka matutulungan :)
Offline Asarnako
  • Pogi/Ganda Points: 19
« Reply #28 on: April 06, 2012, 11:49:03 AM »
hehehe!
Mukhang nag short sa wiring ng output speaker at ende nag shutdown!
Check mo na lang power x'sistor mo at palitan mo yung mga burned parts....
Offline kaiky14
  • Pogi/Ganda Points: 27
« Reply #29 on: May 06, 2012, 03:59:06 PM »
ano po yang traffo sis?
means transformer
ginamit ko lang po tapos bigla nalang umusok.,yun pala pag check ko 3 resistors are burned! and test ko again after i replaced sa sirang resistors muntik nanaman nasunog ulit.,dalian ko nalng unplug ang AC supply..now nasunog na naman 2 fuse.,.:( posible po buh  yung AC rectifier IC nya ang sira?? RS406L po labeled!...ano sa tingin nyo mga masters at may experienced jan?
output trannies ang sira nyan... kelangan mo macheck lahat ng trannies kasi cgurado pati driver transistor nyan damay.. normal nangyayari yan sa amplifier lalo na kung spkr overload or shorted dahil sa speaker wires
dalawang 1/2watt po at isang 1/4watt resistor yung nasunog,.
ano po ang e.reresistance check ko po?yung RS406L?...bumibigay po fuse ko..;( hahai..
ibig sabihin nyan meron parin shorted na tranny. un lang naman ang pwedeng maging shorted sa main amp bihira lang ung iilang diode.
Dapat meron kang diagram nyan para malaman mo kung anong value ung tustadong resistor.
Offline jazMyn<3u
« Reply #30 on: May 22, 2012, 03:13:28 PM »
 ;D halow mga masters.,.Salamat sa mga ideas , comments at suggestion nyo.,.,u help alot..
 +points kau jan.,,Ok na po SAkura amp ko.,.Maingay na ulit sa hauz,hahaha Overload lng cgurO speakers ko ..
 power transiieees nga ang sira,,,pinalitan ko..SALAMAT!  ;D :D ;D ;) :o
Offline kaiky14
« Reply #31 on: May 22, 2012, 03:32:48 PM »
welcome :)
Offline JojoD818
  • Pogi/Ganda Points: 23
  • Rest when you're dead...
    • JD Labs Projects
« Reply #32 on: May 22, 2012, 03:34:44 PM »
partida yan mga hula pa lang ginawa ng mga masters pero na solve ang amp mo... ;D ;D ;D
paano na lang kung may picture pa yan... ;D ;D ;D
Offline mcleod
  • Pogi/Ganda Points: 142
« Reply #33 on: May 22, 2012, 03:35:32 PM »
congrats ts! +1 ka sa akin dahil persistent ka and updating your thread para sa mga newbie na tulad ko!  ;D ;D ;D
3 points ka na!
Offline jazMyn<3u
« Reply #34 on: May 22, 2012, 03:46:36 PM »
3 points ka na!
hahaha tama.,.dapat kahit ganu katagal may update..Lol maraming salamat sauulitin mga ka eLab..,,:D:D:D daming +point sa inyo..:D
Offline SexyPaint
« Reply #35 on: May 26, 2012, 03:35:19 PM »
oi congrats TS.....
Offline 01110011
  • Pogi/Ganda Points: 98
« Reply #36 on: May 26, 2012, 03:38:45 PM »
ts anong model ng sakura ba yan? d2394 looks small for a power xsistor
Offline yehan
« Reply #37 on: June 07, 2012, 04:34:24 AM »
Overheat yan. Bawasan mo ang load wag baba ba sa 4 ohms..Yung resistor mo sa pagitan ng dalawang transistor tama? Lakihan mo ng watts gawin mong 10watts lalaban sa initan yan. Nsunog ksi wlang overload protection yung amp mo.
Offline grizzom
  • Walang malayong kulangot sa mahabang kuko.
« Reply #38 on: June 07, 2012, 08:11:34 AM »
SUB
