Welcome,
Guest
. Please
login
or
register
1 Hour
1 Day
1 Week
1 Month
Forever
Home
Help
Search
Login
Register
Digital Electronics
General Digital Design
(Moderator:
marcelino
HELP!!! logic experts..........
« previous
next »
Print
Pages: [
1
2
Go Down
Author
Topic: HELP!!! logic experts.......... (Read 1410 times)
rinkashe
CR2032 Battery
Pogi/Ganda Points: 0
on:
March 25, 2012, 11:15:18 AM »
.......kailangan po namin nang project sa logic namin tungkol po sa queuing system na may 0-99 ang COUNTER,.........gusto po sa aming INSTRUCTOR ng dalawang TELLER........pero separate yung DISPLAY nang bawat TELLER, example, nag press si TELLER1 (display ni teller1 ay 1), nag press si TELLER2( Display ni teller2 ay 2), separate po ang kanilang DISPLAY pero CONTINUE ang kanilang COUNTING,, parang katulad po ng sa bangko.... hope matulungan nyo kami... SALAMAT PO...
Logged
on:
motion55
Technical People
Diesel Generator
Pogi/Ganda Points: 244
Gender:
Been at this longer than you've been alive.
Re: HELP!!! logic experts..........
Reply #1 on:
March 25, 2012, 01:45:31 PM »
Simple lang yan. Isang 2 digit counter lang. Naka OR ang mga buttons ng mga teller sa clock input and of course with the right debounce and lock out.
Ang 2 x 4 BCD output ng counter ay pupunta sa 8 bit latch ng bawat teller. Bale dalawang 8-bit latch para sa dalawang teller. Bawat latch output will be connected to a 2-digit display driver. Kung sinong teller pumindot, sa kanyang latch ay ma-clocked to update her display.
Pakawalan mo ang nakakulong na utak mo.
Logged
"Set your mind free!"
Reply #1 on:
PlCUSER
Diesel Generator
Pogi/Ganda Points: 153
Reply #2 on:
March 25, 2012, 01:57:15 PM »
Quote from: motion55 on March 25, 2012, 01:45:31 PM
at ugaliing mag inom ng ovaltine.
Logged
Reply #2 on:
rinkashe
CR2032 Battery
Reply #3 on:
March 25, 2012, 08:37:24 PM »
salamat po sir..............pwede po follow up question?
?? baguhan pa kasi ako tapos fresh pa po sakin ang mga words na iyong ginagamit.. para san po yong right debounce and lock out?? at yong latch ano po yon?
and the possoble IC'S na dapat gamitin sa project na ito. salamat po....................
Logged
Reply #3 on:
motion55
Technical People
Diesel Generator
Gender:
Reply #4 on:
March 25, 2012, 09:26:21 PM »
Pag dinertso mo switch sa clock input ng counter para mag increment by 1, pwede more than 1 ang increment dahil sa mechanical properties ng switch. May talbog sa contacts ng switch at multiple times mag increment ang counter.
As for lock out, pwede kasi mag sabay ang dalawang teller sa pindot ng button. Dapat ang naunang teller discable ang kabilang teller habang nakapindut siya. Hindi masyado important sa simula. Pwede kayo gumawa ng walang lock out. Pero sa testing madidiskubre mo ang ganitong problema.
Standard 74xxx TTL devices ang gamitin mo. Ikaw na pumili kung aling BCD (decimal) counter ang hilig mo. Pwede 74273 or 74374 d-type latches.
Logged
Reply #4 on:
rinkashe
CR2032 Battery
Reply #5 on:
March 25, 2012, 10:05:19 PM »
ah so yong lock out po sir is somewhat like priiority.. ? at ano naman po yong debounce?? salamat po sir
Logged
motion55
Technical People
Diesel Generator
Gender:
Reply #6 on:
March 25, 2012, 10:28:00 PM »
Debounce = pang tanggal ng switch bounce. GMG.
Logged
rinkashe
CR2032 Battery
Reply #7 on:
March 25, 2012, 10:36:28 PM »
ah ok sir so pang prevent siya for multiple pulses na ma produce in every electrical contact sa switch. at sir pag mag debounce can inuse circuit from the internet? like 555 timer switch debouncer??
Logged
rdpzycho
Technical People
Solar Power Satellite
Pogi/Ganda Points: 632
Gender:
Respect Begets Respect
Reply #8 on:
March 25, 2012, 10:45:28 PM »
just read the description ng makikita mong debounce circuit sa internet, it can even be just a simple RC circuit. try experimenting kung ano ang pinaka-effective or cost-effective para sa application niyo.
Logged
rinkashe
CR2032 Battery
Reply #9 on:
March 25, 2012, 11:04:28 PM »
sir ito bang 8bit latch is it a decoder?
Logged
carlsfootprints
Lead Acid Battery
Pogi/Ganda Points: 25
Reply #10 on:
March 25, 2012, 11:24:49 PM »
baka makatulong sayo maintindihan ung sinasabi ni sir motion55..
http://circuitdesolator.blogspot.com/2011/01/logic-based-digital-queuing-system.html
Logged
never saturate..
akositado
Size AAA Battery
Pogi/Ganda Points: 3
Reply #11 on:
March 26, 2012, 07:08:54 AM »
pa sub ako... basa basa mode...
Logged
motion55
Technical People
Diesel Generator
Gender:
Reply #12 on:
March 26, 2012, 09:26:57 AM »
Quote from: rinkashe on March 25, 2012, 11:04:28 PM
Diba binigay ko na 74273, 74374? GMG, download at magbasa ng datasheet.
http://www.google.com/search?q=74ls273
http://www.google.com/search?q=74ls374
http://en.wikipedia.org/wiki/List_of_7400_series_integrated_circuits
Mga ganitong problems, parang jigsaw puzzle yan. Mahirap ma solve lahat kaagad. Mas madali gawin ninyo muna mga parteng naintindihan. Pag may partial circuit na kayo, makakatulong para maintindihan yung ibang parte. Like I said, parang jigsaw puzzle.
Logged
rinkashe
CR2032 Battery
Reply #13 on:
March 29, 2012, 07:30:55 PM »
sir na try na namin yong binigay mo na hint.ang problemt a lahat nang display ay 5 . at di siya nag count up.. ano po problema non..bukas na namin ipasa. please help.
Logged
rinkashe
CR2032 Battery
Reply #14 on:
March 29, 2012, 08:17:45 PM »
sir ano kaya problema non??? dipo siya na count up tapos stable ang kanyang state.. kailangan namin matapos ngayon please help
Logged
motion55
Technical People
Diesel Generator
Gender:
Reply #15 on:
March 29, 2012, 08:26:25 PM »
Post your schematics para mabigyan ng comment. Kahit link beginning with hxxp para ma post ninyo,
Logged
rinkashe
CR2032 Battery
Reply #16 on:
March 30, 2012, 08:40:59 AM »
sir ito po ang picture nang aming schematic.. salamat po sir
Logged
motion55
Technical People
Diesel Generator
Gender:
Reply #17 on:
March 30, 2012, 08:58:00 AM »
74192 is an UP/DOWN counter. Hmmm.... One problem is ang teller #1 naka clock sa UP count input. At ang teller #2 ay naka clock sa DOWN clock input. Dapat naka OR sila sa UP count lang. But I like the debounce circuit you made.
Logged
Hydroelectric
Pogi/Ganda Points: 123
Truth suffers, but never dies.
Reply #18 on:
March 30, 2012, 09:11:40 AM »
importante yong debouncer baka bigla nalang tatalon yong priority number ng counter posibleng magsuntokan ang mga customer ng banko dahil sa tagal ng hintayan na bypass pa ang numero nila
you may try 74ls221 sa debouncer para wlang mintis (see datasheet)
Logged
rinkashe
CR2032 Battery
Reply #19 on:
March 30, 2012, 11:55:44 AM »
sir bali sa left side na push button bali yan ang count up ng bawat teller at sa kabila ay ang count down ng bawat teller. tag iisa sila ng push button..
Logged
Reply #19 on:
Print
Pages: [
1
2
Go Up
« previous
next »
Digital Electronics
(Moderator:
marcelino
