Author Topic: look-up table sa MikroC  (Read 386 times)
Offline tamuragko
« on: April 04, 2012, 07:17:23 AM »
Hi po mga master, i'm a newbie in high level PIC programming pero mai konting experience na po with assembly language...
Tanong ko lang po kung pano gumwa nang parang "look-up" table sa MikroC..  ;D ;D
Offline glutnix_neo
  • Pogi/Ganda Points: 166
    • Underground Workbench
Re: look-up table sa MikroC
« Reply #1 on: April 04, 2012, 08:01:31 AM »
gamit ka ng switch-case or array....depende sa application
// convert hex to char
switch(hexnumber)
case 0:
  character = '0'
  break;
case 1:
  character = '1'
  break;
case 2:
  character = '2'
  break;
default:
  character = '0'
  break;
char lookup[4] = {'0','1','2','3'}; // initialize lookup table here.
character = lookup[hexnumber];
Offline tamuragko
« Reply #2 on: April 04, 2012, 12:24:52 PM »
yeah got it working... one other thing sir, pano pag fuctions na ilagay ko sa array...??? like
char lookup[2] = {funk1(),funk2()};
nag eerror na sya.
Offline glutnix_neo
« Reply #3 on: April 04, 2012, 12:47:29 PM »
nag eerror na sya.
use the switch-case,
switch(func_ref)
  case 0:
    function1();
    break;
  case 1:
    function2();
    break;
  default:
    break;
Offline tamuragko
« Reply #4 on: April 04, 2012, 06:12:38 PM »
cool.. thanks sir glutnix_neo :D
Offline glutnix_neo
« Reply #5 on: April 04, 2012, 06:20:19 PM »
common mistake lang sa switch case, malimit nakakalimutang lagyan ng break yung bawat case, dapat palaging may default din and define how to handle default....
default yung condition similar to else sa if-else statement...
Offline carlsberg11
  • Pogi/Ganda Points: 30
« Reply #6 on: April 26, 2012, 01:26:54 AM »
^UP.
sir question regarding lookup table. pwedi po ba i set mo yung output of any port you like sa pic?
example.
switch(hexnumber)
case 0:
  PORTB= 0xA8;
  Delay_ms(45.6);
  PORTB= 0xB1;
  break;
case 1:
  PORTB= 0x90;
  Delay_ms(45.6);
  PORTB= 0x00;
  break;
case 2:
  PORTB= 0x00;
  Delay_ms(45.6);
  PORTB= 0x12;
  break;
default:
  PORTB= 0xA2;
  Delay_ms(45.6);
  PORTB= 0x56;
  break;
valid po ba yung above code?
-Albert Einstein
Offline dummy_c
  • Pogi/Ganda Points: 162
« Reply #7 on: April 26, 2012, 05:25:10 AM »
^^ Hindi! ;D ;D
Mag error po yan.
Di pwedi decimal point sa delay_ms.
Use delay_us instead, i.e. delay_us(45600).
At tulad ng sabi ni master gluti na kailangan may break sa bawat case at meron din default.
Offline carlsberg11
« Reply #8 on: April 26, 2012, 11:11:27 AM »
^^ Hindi! ;D ;D
Mag error po yan.
yun salamat master lurker. para kasi to sa POV, :D :D ommit ko na lang yung decimal points regarding the delays. thanks for correction master! +1 :D 101+1
-Albert Einstein
