Author Topic: increment code to display in 2 7segments  (Read 359 times)
Offline coejayson
« on: April 09, 2012, 11:46:42 AM »
phelp naman po to derive a code to increment the value of the accumulator/register and to display in the 2 7segments...as in the queuing machine with 00 - 99...tnx
Offline sbtech
Re: increment code to display in 2 7segments
« Reply #1 on: April 09, 2012, 12:29:28 PM »
do you write in ASM?
Offline coejayson
« Reply #2 on: April 09, 2012, 12:47:12 PM »
yep po
Offline motion55
  • Pogi/Ganda Points: 244
« Reply #3 on: April 09, 2012, 02:26:33 PM »
If you use packed BCD, then the lower nibble can be used to display the ones digit and upper nibble for the 10's digit.
To perform BCD increment, you add 1 to the accumulator and then execute DA (decimal adjust) instruction.
    MOV A,R1
    ADD A,#1
    DA  A
    MOV R1,A
"Set your mind free!"
