Author Topic: Philips 14GX1510/71R no power  (Read 881 times)
Offline kurapiket
  • Pogi/Ganda Points: 9
« on: April 11, 2012, 10:26:55 AM »
manga master sabog ang regulator P6N60FI..
nipalitan ko na pero wala pa rin  power...
may charge nmn yung primary ecaps 220uf/400v.
resoldered ko na rin po primary.
tips nmn poe. thanks!
gamitan mo ng microscope.
Offline BhongTech
  • Pogi/Ganda Points: 152
Re: Philips 14GX1510/71R no power
« Reply #1 on: April 11, 2012, 10:50:36 AM »
siguradong sibak din ang PWM nito sir..
check mo na rin ang gate limiter(resistor) ng reg mo.
  • Pogi/Ganda Points: 231
« Reply #2 on: April 11, 2012, 01:26:20 PM »
agree.. malamang sibak ang PWM ic nyan.. dapat palitan narin yan kapag sumabog ang FETs ( o regulator ) para cegurado.
Offline mcleod
  • Pogi/Ganda Points: 143
« Reply #3 on: April 11, 2012, 09:36:11 PM »
check mo resistors and diode sa primary. ok ang fuse? yung HOT mo ok ba? 8V regulator mo may heatsink na ba?
Offline kurapiket
« Reply #4 on: April 14, 2012, 09:57:14 PM »
nagpalit na aku ng PWM wala pa rin power.
pareho ba to? UC3842AN, UC3842BN
UC3842BN eto yung orig eh.
Offline kurapiket
« Reply #5 on: April 16, 2012, 02:45:21 PM »
up
Offline BUMBLEBEE
  • Pogi/Ganda Points: 109
  • transform!!!!!!!!!!!
« Reply #6 on: April 16, 2012, 03:04:31 PM »
pareho lang yan.. check mo muna ang supply ng PWM
sundan mo muna yung pin 1 ng reg.
Offline SexyPaint
  • Pogi/Ganda Points: 25
« Reply #7 on: April 16, 2012, 04:38:16 PM »
pa sub..
Offline benj2maze
  • Pogi/Ganda Points: 6
« Reply #8 on: April 17, 2012, 10:35:54 AM »
power supply problem pala eto, concentrate ka muna dyan sis, suyurin muna para sure tayo, regarding sa mga short, leaks, and open component kaya pumutok yan..thanks
Offline m@r
  • Pogi/Ganda Points: 59
« Reply #9 on: April 17, 2012, 10:51:32 AM »
check mo sir resistors dyan sa PSU baka nagchange value na, palitan na din mga ecaps dyan sa primary... pero malamang malaking chance ang problema pwm at resistors ito kaya check mo muna mga ito bago magpalit ng reg...
Offline BhongTech
« Reply #10 on: April 17, 2012, 11:44:20 AM »
dapat may masukat ka sa pin 7 ng PWM na 18vdc.pinakasimple ang design nito sir kaya di masyadong marami ang parts.pagtuloy tuloy ang pulse sa pin 6 ng ic o walang masukat na boltahe isa lang ibig sabihin fake ang nabili mo.
check mo rin ang zener diode papuntang gate ng reg baka shorted na rin kaya di tutuloy ang pag on nito.
Offline mcleod
« Reply #11 on: April 17, 2012, 02:28:01 PM »
 ;D ;D ;D
Offline nucleus
« Reply #12 on: April 17, 2012, 02:59:26 PM »
yung zener diode sa supply pin ng uc3842 mo may resistor din iyan galing B+ baka open
Offline kurapiket
« Reply #13 on: April 18, 2012, 02:22:01 AM »
wait lang po d2 manga sis. gagawin ko lahat yang mga suggestion nyo at points nga po pala sa mga nagreply.
update ko po kayo once makalikot ko na ulit yung tv. antay ko pa mei ari kung itutuloy pagawa kac hindi pa binibisita ang tv. para mapresyohan ko na.
Offline kurapiket
« Reply #14 on: April 18, 2012, 12:13:11 PM »
up!
manga sis confused ako d2 sa value ng resistor 3517.
3517 = orange, orange, black, gold, violet.
panu po ba coding nito?
33 ohms ba to?
open kac ito eh.
may nakita kc akong diagram sa thread na ito
http://www.electronicslab.ph/forum/index.php?topic=26054.0
15 ohms ang nakalagay na value ng resistor 3517.
Offline mcleod
« Reply #15 on: April 18, 2012, 03:34:44 PM »
walang parts list yan service manual na ata hawak mo?  ;D ;D ;D di ako sigurado baka color blind ka. ginamitan mo ba magnifying glass. ;D ;D
o review muna:
Offline kurapiket
« Reply #16 on: April 18, 2012, 04:33:54 PM »
o review muna:
OK 33ohms nga. iba po yung schematics na post ni sis RunHa. nacheck ko yung pcb iba connection ng mga parts although pareho ng parts no.
yung nirerepair ko nakaparallel yung resistor 3518 at ceramic caps 2518.
at wala sa cuircuit yung ibang cer caps. 2514, 2515.
service manual at schematics yung nasa akin sis mcleod. saka malinaw pa yung color ginamitan
ko po ng magnifying glass.
hanap muna ako resistor. baka bukas na makabili wala ako mbunot d2. service muna ako sa labas.
Salamat. update ko nlng ulit.
Offline BhongTech
« Reply #17 on: April 18, 2012, 09:40:06 PM »
mas stable ang 15ohms sir o kaya 18ohms,ito madalas ipalit ko sa 33ohms(fusible resistor).
Offline m@r
« Reply #18 on: April 18, 2012, 09:46:33 PM »
oi parang malapit na sa katutuhanan ah... abang nalang sa update..!
Offline DSM_elektronix_shop
  • Pogi/Ganda Points: 153
« Reply #19 on: April 18, 2012, 10:07:53 PM »
33ohms yan sis tama tama
DSM_electronics_shop
Alvin Y. Carulasan
Sinal Village, Taguig city
