Author Topic: sanyo st-21kx2 few hours shutoff .turn on again few minetes shutoff.  (Read 302 times)
Offline Antonio
  • Pogi/Ganda Points: 12
    • http/www.electronicslab.ph.com
gud pm po sa lahat.
galing sa ibang tech .
3hours daw pinaadar hindi nag shutoff. kaya wala raw sira. sabi ng tech.
sa akin 15 minetes nag shut off na  . on ulit secend lng shutoff na.
kasulukuyan hang ko lahat ang tackswiths
at try ko ulit.
ano pang ibang mga idea sa ganitong trouble
pls po mga sir..........luv u sa lahat........ :-*
antonio tayag
Offline BhongTech
  • Pogi/Ganda Points: 152
Re: sanyo st-21kx2 few hours shutoff .turn on again few minetes shutoff.
« Reply #1 on: April 17, 2012, 12:28:55 PM »
check for deff. ecaps yan muna ang gawin mo TS.
Offline DSM_elektronix_shop
  • Pogi/Ganda Points: 153
« Reply #2 on: April 17, 2012, 12:36:24 PM »
loosecontak lang siguro yan ts meron d2 shop ko kahapon ko pa test di pa namamatay...loose con sa vert ic...
DSM_electronics_shop
Alvin Y. Carulasan
Sinal Village, Taguig city
Offline acer
  • Pogi/Ganda Points: 109
« Reply #3 on: April 17, 2012, 01:00:08 PM »
loosecon
nevergive up
Offline Antonio
« Reply #4 on: April 17, 2012, 01:05:03 PM »
obserbahan ko
palit narin ako reprogram memory.
pag nag shutoff po uli
gawin ko na po mga adviced ninyo.
update aku mamya.
................luv u sa inyo.......tnk sa raply........... :-*
antonio tayag
Offline mcleod
  • Pogi/Ganda Points: 143
« Reply #5 on: April 17, 2012, 02:24:45 PM »
obserbahan ko
update aku mamya.
baka leaky or loose primary cap.
Offline Antonio
« Reply #6 on: April 17, 2012, 04:27:31 PM »
sir
saan parte ho ako mag replace ng ecaps?
...........tnks po sa reply....... :-*
antonio tayag
Offline Antonio
« Reply #7 on: April 17, 2012, 04:33:00 PM »
mag hihinang ho ako ulit.
...........tnks sa reply........ :-*
antonio tayag
  • Pogi/Ganda Points: 231
« Reply #8 on: April 17, 2012, 05:05:09 PM »
sir
yung mga small ecap sa PSU .
Offline Antonio
« Reply #9 on: April 17, 2012, 07:49:19 PM »
nagpalit na ho  ako ng mga ecaps
sa smps......primary at secondary lahat.
nahinang na ho ang lahat ng parts.
same parin.
any idea po mga master  hu hu hu.
.........tnks sa mga reply.......... :-*
antonio tayag
