Author Topic: Insulation Foam Installation  (Read 1054 times)
  • Pogi/Ganda Points: 414
Re: Insulation Foam Installation
« Reply #20 on: April 20, 2012, 02:46:44 PM »
Then they are NOT using it for insulation?
yes gamit nila kaya lang added benefit na yan at dahilan.
Offline Asarnako
  • Pogi/Ganda Points: 19
« Reply #21 on: April 20, 2012, 02:51:06 PM »
Actually ende talaga pede sa severe tropical country ang inulators na yan.... mas maganda pa lagyan mo ng old sytle ventilation ang roofing mo.....either lagyan mo ng rptating vent fan sa roof mismo or lagyan mo ng window both ends ng kisamee and add up some exhaust fan..... 8) :o
« Reply #22 on: April 20, 2012, 02:55:00 PM »
masasaturate talaga yung foam nang init. but it helps a lot pa din para ma contain yung init. one way or another. lalo na sa nagtitipid.
Offline Asarnako
« Reply #23 on: April 20, 2012, 03:00:20 PM »
Hehehe!
Nakatipid ka pero the heat stays inside the kisame and no way to get out, but thru ur room!
LOL!
« Reply #24 on: April 20, 2012, 03:03:24 PM »
At least minimize, yung dating aircon gamit mo, efan na lang. Medyo mainit lang talga design ng kisame ni sis kas kung walang circulating air sa taas ng kisame nya both inbetween ng mismong kisame.
  • Pogi/Ganda Points: 412
« Reply #25 on: April 20, 2012, 03:34:35 PM »
Ito yung the best if sarili mo yung bahay...pero tulad ko na nag rent lang ito yung cheapest approach na sa tingin ko gagana..
Offline Asarnako
« Reply #26 on: April 20, 2012, 03:46:38 PM »
How much kung lalatagan mo ng insulation fibers or kung lalagyan mo ng electric exhaust fan sa may gilid( na binutasan mo upside down ) para i-suck ang hot air from the kisame, or u could put both all together.....
« Reply #27 on: April 20, 2012, 03:50:48 PM »
pampaganda lang kaya nasa labas yung foil. ;D lalo na kung yung fiberglass ang gamit.
para mas bawas ang init, double insulation dapat. parang style nung mga glass freezers na display style, ilang patong yung salamin tapos may pagitan.
pwedeng i-compute sa thermodynamics yan kung gusto ng sakit ng ulo. ;D pero ang best advice ng prof namin, huwag mong idikit sa yero, dapat mahigit ilang ruler, para na rin lumiit yung palalamigin ng aircon.
« Reply #28 on: April 20, 2012, 03:53:29 PM »
kung insulation foam lang mga 9 meters magagamit ko..@90/ meter nasa so di aabot ng 1k..meron ba exhaust na nasa 1k lang? kaso dagdag pa sa kunsumo ng kuryente to..:(
since more or less mga 10ft pa yung ceiling namin I was planning na ihang ko yung insulation foam mga 2 ft below the ceiling...;D
Offline Asarnako
« Reply #29 on: April 20, 2012, 03:58:18 PM »
Well.. meron exhaust fan na same na use ng mga toilette, tuwing afternoon lang naman sobra enet ha? It's just like an ordinary electric fan... less than 1K.. buy ka sa mga second hand..LOL!
« Reply #30 on: April 20, 2012, 04:01:24 PM »
same din sa office, naka-hang yung styro na kisame. bale pangalawang kisame na yun pagkatapos ng kahoy. :D
« Reply #31 on: April 20, 2012, 04:09:28 PM »
tsk...naisip mo ba na kung yan ang gagamitin ko, buong ceiling ng bahay yung icool nya? while sa foam specific locatoion lang. Dagdag mo pa maintenance nyan like cleaning at consumable parts...
« Reply #32 on: April 20, 2012, 05:33:59 PM »
Hindi kaya ng exhaust fan palamigin ang kisame basta. Kasi ang suck air din ay karaniwan mainit. Mas maganda talaga yang foam insulator.
Offline Asarnako
« Reply #33 on: April 20, 2012, 05:35:34 PM »
U mean ilalagay mo yung foam hanging from ur ceiling? Not inside the ceiling itself?
If it's an ordinary foam( not the fiber type) it is safe, but if ur thinking using that yellow fiber insulating foam it is dangerous to ur health, dapat nasa loob ng ceiling yang fiber type...
Talking about economics to satisfy temperature control... i'll go for the exhaust fan! The faster u gey rid of the heat the cooler it gets... just like in ur desktop...
Ende ba pede i segregate ang area mo lang?
« Reply #34 on: April 20, 2012, 06:39:52 PM »
Insulation foam...yung may foil sa isang side...or both sides..
mas malaki trabaho if segregate kasi yung gusto ko icool 3x3 mts lang..
« Reply #35 on: April 20, 2012, 09:49:55 PM »
Mukhang isang kwarto o working area mo? Kung di maglalayo sa presyo pede naman double insulating basta orig.
  • Pogi/Ganda Points: 316
« Reply #36 on: April 20, 2012, 09:53:28 PM »
both sides samin may foil.
« Reply #37 on: April 20, 2012, 09:55:45 PM »
^Nyehehe kaya pala maski san mo tingnan eh me foil.  ;D
« Reply #38 on: April 20, 2012, 11:04:30 PM »
merong required CFM para maalis kaagad yung init. mas masasagot yan ng mga HVAC practitioners. sa opisina mas effective nung dinoble ang kisame namin kaysa noong meron kaming 3 industrial size na exhaust (2ft. blades, 1/2HP each), maingay pa noon. :D
« Reply #39 on: April 20, 2012, 11:09:48 PM »
^Same principle na ginagamit ng mga military sa desert mobilization, two layer na magkahiwalay na tent. Para maging bearable yung heat. Parang kasama ito sa survival training sa desert.
