Author Topic: CDR-King Inverter 700 watts with 12V 100AH battery  (Read 902 times)
« on: April 20, 2012, 05:49:07 PM »
ask ko lang sana kung worth it na ito. for brownouts...
or should i find na mas cheaper na alternative?   :-[ :-[ :-[ :-[
CD-R King Power Inverter (with Rechargeable battery FC12-100)
Php 10,000.00
Features
  •    Pure Sine Wave Output
        CPU Controlled Stable System
        Short Cicuit Protection
        Under/Over Voltage Protection
        Intelligent Charging System
        Line Interactive Design
        Full Range VAR
        Advance PWB Techonology
        Fast Change over
        Easy to install
        Rugged
Specifications:
  • Capacity: 1000VA / 600W
    With Indicator: Over load / Fully Charge
    With ON/OFF
    Input: 220V AC ~ 60Hz
    Output: 220V
    Wave form: Pure sine Wave
    Used as an Inverter / Home UPS
    Max.Charging: 10-25Amp
Battery:
  •    Model FC-12
        12V100AH = 10Hrs
        Cycle USE: 14.40-14.90V
        Standby USE: 13.60-13.80V
        Initial Current: Less Than 25A
  • Pogi/Ganda Points: 412
Re: CDR-King Inverter 700 watts with 12V 100AH battery
« Reply #1 on: April 20, 2012, 07:31:18 PM »
600 watts for 10 hrs? not bad...;D
Offline blackking
« Reply #2 on: May 14, 2012, 10:54:45 PM »
10k? :o di ba natin kaya gawin yan? :D
« Reply #3 on: May 14, 2012, 11:15:25 PM »
nakita ko na yung loob. kayang gawin and madali lang. but hindi worth it. time and effort na lang.
plus.. mapapamahal pa sa parts.
« Reply #4 on: May 14, 2012, 11:44:37 PM »
casing pa lang kakain na ng 500 petot yan..;D
Offline bravokilo
  • Pogi/Ganda Points: 105
« Reply #5 on: May 15, 2012, 11:41:52 AM »
With P10k, bili na lang ng generator. Ingay nga lang....well, most things at home can run on 12v. Car fans, LED lights, 12V for flourescent. Ref lang talaga at TV. malaking gastos yan P10k.
BK
« Reply #6 on: May 15, 2012, 06:02:22 PM »
BK
di pwede i compare ang genset sa battery powered inverters.
it's just that di pwede i compare apples to oranges.
usually kapag SOHO/remote areas/TOU/renewable solar wind or for some special reasons.
it's worth paying na din for a premium.
« Reply #7 on: May 15, 2012, 08:44:46 PM »
^^ may next target..para sa remote area sa lugar namin..
1 solar panel, battery, at 3 LED's bulb isang set...kahit wala ng inverter siguro running on battery lahat...
« Reply #8 on: May 15, 2012, 11:32:38 PM »
kung reliable yung components, good price na yan.
Offline motion55
  • Pogi/Ganda Points: 244
« Reply #9 on: May 18, 2012, 11:56:55 AM »
Specifications:
Battery:
       Model FC-12
        12V100AH = 10Hrs
Let me see... 600W for 10 hours?
12V100AH for 10 hours therefore 10A @ 12V = 120W
Someone from CDR-King must have invented a free energy device here!
"Set your mind free!"
Offline Mayor Johnaray
  • Pogi/Ganda Points: 238
« Reply #10 on: May 18, 2012, 12:08:38 PM »
And it is made in CHINA ;D ;D ;D
Offline jesper2g
« Reply #11 on: January 26, 2013, 06:51:24 PM »
Pwede kaya to gamitin sa foodcart? Blender lang ang appliance na ipa plug. For fruit shakes.
« Reply #12 on: January 26, 2013, 07:06:20 PM »
Pwedeng palitan ng 12v na motor yung blender sir. Mas matipid sa baterya yun kasi rekta na.
Though, mas madaling gawin yang inverter na lang.
Offline Super zHero
  • Pogi/Ganda Points: 73
  • That's not me but might as well be.
« Reply #13 on: January 26, 2013, 09:48:46 PM »
The inverter is rated at 600W daw.  Ibig sabihin, kung yung load ay higit na sa 600W, overload condition na yon.
Yung battery time naman ay pwedeng 10 hrs nga sa 120W load or less.  Kasi hindi naman specified ang efficiency.  So if load is 600W, battery time is less than 2 hrs assuming battery capacity is truly 100Ah.
