Author Topic: sharp cv2191 flashing color  (Read 644 times)
Offline J@M
  • Pogi/Ganda Points: 125
Re: sharp cv2191 flashing color
« Reply #20 on: April 23, 2012, 03:34:26 PM »
May inayos ako dati ganito,cold solder lng...sa lahat aman channel un.
Don't Give up
Offline SexyPaint
  • Pogi/Ganda Points: 25
« Reply #21 on: April 23, 2012, 04:32:00 PM »
ganun ba sis, itong inaayus ko maganda pa mga solder niya, inistak na lang simula nung nagkaproblema kulay, binigay lang sakin to e...kaya pinagtiyatiyagaan kung inaayus kasamo ng mga master dito na handang tumulong.... ;) ;) ;)
Offline mcleod
  • Pogi/Ganda Points: 143
« Reply #22 on: April 23, 2012, 05:52:45 PM »
yung hinang sa loob ng tuner ha, see picture sa taas; hinidi yung paa ng tuner.
yung pinalitan mo crystal eh yung color crystal usually  3.5 Mhz? or some higher siya but since process din siya ng IC (chroma) yung ibang value ang gamit and magdedepende din naman sa filter (capacitor and inductors mo) hence kaya ko pinapa-check yung components mo da tuner section. subukan mo rin palitan yung isang crystal or resolder muna. tapos, you might consider checking chroma IC or UOC kung ito ginamit. hth(hope that helps)!
hindi talaga pede pag 4.5 Mhz  - 6.5 Mhz for FM sound modulation iyan. same lang kung 4.43 MHz e dapat same lang nito. Teka sis, di ba sa A/V mode same lang ang problem? Kung oo, sagot mo dito. It's time na check mo na saan galing Chroma, Chroma IC ba or UOC? bakit andito na hinahanap mo or katabi lang ng 3.5 MHz na crystal ang defective part.
off-topic: censya di ko makita yung schematic mo anlabo. and wala ako schema nito.
Offline Min
  • Pogi/Ganda Points: 202
« Reply #23 on: April 23, 2012, 06:01:46 PM »
Parang multi system ata ung model nato? Anu TS?
Offline SexyPaint
« Reply #24 on: April 23, 2012, 06:23:40 PM »
@mcleod sis pag video ok siya.....chroma kasama sa jungle...pede sis download yung schematic palikihin mo mababasa siya......
TDA8362 jungle ic
IX1830CE system
TDA4661 baseband delay line
TDA8395 SECAM
TDA4661 baseband delay line at TDA8395 SECAM connected sa pin 28,29,30,31,32 ng jungle ic
28,29 RY,BY Input
30,31 BY,RY Output
32 SECAM
pin 27 ng jungle e Hue/Secam Chroma connected siya system ic...
@HG oo sis
Offline Min
« Reply #25 on: April 23, 2012, 06:28:25 PM »
Saan naka set ang color sa Auto? kung naka auto try lipat NTSC.
Offline SexyPaint
« Reply #26 on: April 23, 2012, 07:09:07 PM »
wala sa setup sis, pag auto search ko channel Auto tas U at HV lang,
Offline mcleod
« Reply #27 on: April 23, 2012, 09:17:26 PM »
ok sa A/V mode, then nasa tuner section lang ang salarin. kunti lang naman parts dito, unahin mo na ecaps then coil sabi mo kasi good ang tuner mismo. then zener diode. then resistors.
Offline SexyPaint
« Reply #28 on: April 24, 2012, 10:25:28 AM »
update ko lang...
pinihit ko IF niya at auto search, yung dating magandang channel na pag linipat at ibabalik ay nagflaflash ngayun di na nagflaflash ang kulay....yung mga nagflaflash nalang is yung malabo ang stasyon...
na try ko naring palitan e-cap sa palibot ng tuner sis, zener at resistor di pa, may epekto din ba mga smd cap dito pag defective? TIA
Offline mcleod
« Reply #29 on: April 24, 2012, 10:30:19 AM »
update ko lang...
oo naman. pag sure ka na defective, observe mo rin baka naman may same label sa di smd type.
nasubukan  mo na ba palitan ang memory? (don't ask me wala ako nyan memory kahit schema wala) ask mo mga masters. may memory ba ito parang pihitin system ito, di ako sure? nakita ko na ito, di nga lang dumaan sa aking mga kamay.  ;D ;D
AGC ref kaya pin, good kaya mga nakasakay dito sa linya? may 2.2 uf / 50 V andf 100 uf / 16 V ba na ecaps? yung sa IF ba ok kaya ang transistor mo err i mean good working condition?
yung sa diode kala ko ba di zener? eh bakit zener diode pinalit mo?
Offline mcleod
« Reply #30 on: April 24, 2012, 10:49:29 AM »
update ko lang po
@mcleod sis napalitan ko na mga ecap ganun parin....
yung diode na open eto body number niya sv0330 ano pede replacement?(sa AGC)
pinalitan ko ng zener diode medyo ok na yung picture, yung nagflaflash na color yung mga mahinang reception nalang, yung dating malinaw na channel pag linipat at binalik di na nag flaflash...siguro konting tuning nalang, pihitpihit....pero yung value po ng diode sigurado may kinalaman yun open kasi siya e........
thanks...
Offline SexyPaint
« Reply #31 on: April 24, 2012, 11:13:28 AM »
mas nag ok kasis sis sa zener...na program ko narin memory niya sis...ala daw Service mode to...de pihit..
yung sa AGC ecap is 2.2uf/35v at 1uf/50v
ok tranny sa IF sis...
Offline SexyPaint
« Reply #32 on: April 25, 2012, 01:44:09 PM »
update ko lang ok na to...may nahanap akong kapareho ng diode sa AGC pinalitan ko ok na kahit yung mga malalabong channel di na kumukurapkurap ang kulay....thanks sa mga tumulong sakin dito.........+1 saging sa inyo........... ;D ;D ;D
Offline Min
« Reply #33 on: April 25, 2012, 01:48:41 PM »
Congatrs......Sexy P.
Offline noman75
  • Pogi/Ganda Points: 262
  • 09335154904 / 032-4848039
    • Here`s my blog....
« Reply #34 on: April 25, 2012, 01:54:52 PM »
Congrats!!! ilista mo na yan sa mahiwagang aklat mo ;D
NoMaNz 4-ever
Here`s my blog....
http://noman75.blogspot.com/
Offline mcleod
« Reply #35 on: April 25, 2012, 02:26:52 PM »
good for you! congrats! salamat sa kape! napalaban ako dito ah.
ano ba talaga; meron memory or wala? curios lang po.  nakita ko kasi yung tv hindi pa "hubad" eh. saka busy ako nun kaya di ako sure.  ;D hinintay ko bj kaso wala pa eh.
Offline SexyPaint
« Reply #36 on: April 25, 2012, 03:49:46 PM »
meron sis number nm93c46.......na reprogram ko narin eto..........
sige sis hintayin natin mag bj yung ginawa mo at ng mapagaralan naten ulet.... ;D ;D ;D ;D
Offline mcleod
« Reply #37 on: April 26, 2012, 07:32:11 AM »
hindi ako gumawa. yung isang tech namin. eh mag - 2 2 years na wala pa!  ;D ;D ;D
Offline SexyPaint
« Reply #38 on: April 26, 2012, 09:19:57 AM »
ganun ba sis......malapit ng masira yun..... ;D ;D ;D joke :D :D :D
