Sori ngayon ko lang na tingnan to.Assuming your power supply is 9V, start with the values of R3 = 1K8 and R2 = 560R.Measure the voltage at the drain and at the source. Vd should be around 5.4V and Vs should be around 1.7V. If not, check that Vsupply - Vd => 3V and Vd - Vs => 3V. The target is to get a +/-3V swing from the drain terminal.
Noted sis. Pag hinawakan ko ang tab ng regulator, nawawala ang humming. Grounding issue kaya?
Nagawa ko na yung jumpers. Nabawasan na yung hum. Pero pag around 75% meron pa din. Palagay ko yung 1m kelangan din ilagay sa negative ng 100uFSalamat sir Efren
@sir TTH,parehas lang din po kaya ang principle ng pagcompute ng R2(SOURCE resistor) dito sa attached schema ng "iPad-Guitar Input Buffer"? since walang R3 kasi directly connected na yung DRAIN ng FET sa mic-input ng iPad(which has 2.8Vdc coming from iPad). 2N5457 din po kasi sana ang gagamitin ko.eto po ang schema:source: http://www.planetz.com/?p=1531
Pareho lang yan ang pag determine ng R2. From the way the drain is connected directly to the IPad input, it is logical to assume that there is a pull up resistor at the IPad input. This pull up resistor must be pulled up to +5V since IPad uses logic components. You could start with a value of 470R for R2 then adjust it to get 2.5 to 2.8V at the drain.
gain will be dictated by the transconductance of the FET. (just a guess)
