Author Topic: sim900d interface with pic16f877a  (Read 1710 times)
Offline carlsberg11
  • Pogi/Ganda Points: 30
-Albert Einstein
Re: sim900d interface with pic16f877a
« Reply #40 on: May 03, 2012, 11:47:43 AM »
Offline PlCUSER
  • Pogi/Ganda Points: 152
« Reply #41 on: May 03, 2012, 11:49:07 AM »
bakit po dpat 8 digit lng? e sim number dba po 11 ?
tinext ko na si joy. tanong mo sa kanya kung ilang number ang nag appear. ;D ;D ;D
Offline carlsberg11
« Reply #42 on: May 03, 2012, 11:50:52 AM »
OT:
si bitoy yan sir... :D :D :D hala ka!
-Albert Einstein
Offline Engr. Dacuycoy
  • Pogi/Ganda Points: 161
  • Proton Orcad EasyPCB User
« Reply #43 on: May 03, 2012, 11:52:31 AM »
Ok
AT+CPBR=1
+CPBR: 1,"09261428272",129,"Ram"
OK
AT+CPBR=2
+CPBR: 2,"09153078153",129,"Beyong"
OK
AT+CPBR=3
+CPBR: 3,"09156174948",129,"Pau"
OK
AT+CPBR=4
+CPBR: 4,"+639168481851",145,"Joy"
Ok
Master Ako ngsave sa nyan sa simcard ung AT+CPBR=1 un ang una kon sinave tas 2 pangalawa kong sinave etc.
Ok
^ ito tama
    Dim GlobalBuffer As String * 250  ' Sms storage & General storage  max is 250 (0 to 249)
    Dim MobileBuffer As String * 13  ' Mobile phone storage
    HSerOut ["AT+CPBR=1",CR]      ' Read memory location 1
    HSerIn 1000,TIMEOUT,[Wait(CR,CR,LF),Str GlobalBuffer]
TIMEOUT:
'    +CPBR: 4,"+639168481851",145,"Joy"
'    0000000000111111111122222222223333
'    0123456789012345678901234567890123
    VarY = 0
    VarX = 9
    Repeat                                   ' Make a loop as dictated by SMSLength
      MobileBuffer[VarY]=GlobalBuffer[VarX]  ' Store it to MobileBuffer
      Inc VarX:Inc VarY                      ' Increment counters
    Until VarY = 14                          ' Finish the job
    Print At 1,1,Str MobileBuffer
Offline ninjatuna
« Reply #44 on: May 03, 2012, 11:57:54 AM »
Ok
^ ito tama
PatuLong na lng pano ideclare as variable sa proton ung inoutput ng AT+CPBR=1 master salamat
Offline ninjatuna
« Reply #45 on: May 03, 2012, 12:02:03 PM »
master,
129 Unknown type (IDSN Format Number)
161 National number type (IDSN)
145 International number Type (ISDN)
177 Network Specific Number (ISDN)
Offline ΔЅịMø
  • Pogi/Ganda Points: 140
  • "Live Curious"
« Reply #46 on: May 03, 2012, 12:02:16 PM »
Kailangan pala dapat naka +63 para valid. :D :D
OT:
Titext ko rin daw si Joy kung kamusta na ang project na to. ;) ;)
Offline ΔЅịMø
  • "Live Curious"
« Reply #47 on: May 03, 2012, 12:03:08 PM »
yun nalaman ko din kung ano yung 129 and 145
+1 dito prof
Salamat sir iceberg. ;D ;D
Offline ninjatuna
« Reply #48 on: May 03, 2012, 12:05:55 PM »
Ok
^ ito tama
Master di ko mgets pano ilgay dun sa AT+CMGS= Ung number na nput as variable na gling sa AT+CPBR=1?
TIMEOUT:
    VarY = 0
    VarX = 9
« Reply #49 on: May 03, 2012, 12:07:41 PM »
engr ako hindi master... si carlsberg ang master dito.  ;D ;D ;D
andon na sample code pag-aralan mo na lang
Offline ninjatuna
« Reply #50 on: May 03, 2012, 12:09:32 PM »
Hehehe sige engr try ko balitaan ko kayo ;D ;D ;D
Offline carlsberg11
« Reply #51 on: May 03, 2012, 12:11:21 PM »
OT:
nge! FYI sir dacuycoy, may title kana dito sa elab. Master Eng'r. Dacuycoy dapat yung pangalan mo kaya palitan mo na :D
@TS
bait ni Master Eng'r Dacuycoy no? :D :D :D may example code kana TS kaya mo na yan.. salamat pala dun sa 129 145 etc. :D
-Albert Einstein
Offline carlsberg11
« Reply #52 on: May 03, 2012, 12:13:30 PM »
Ok
^ ito tama
TIMEOUT:
    VarY = 0
    VarX = 9
bat ang simple simple talaga mag coding sa proton!! hirap nito sa mikroC e... :(
-Albert Einstein
« Reply #53 on: May 03, 2012, 12:15:13 PM »
errata:
varx = 10
Offline ninjatuna
« Reply #54 on: May 03, 2012, 01:34:39 PM »
errata:
varx = 10
Master engr. penge nman link ng proton na pde iDL ng error na proton ko ;D
+1 pt
« Reply #55 on: May 03, 2012, 01:37:13 PM »
sori ala ako nyan  ;D ;D ;D
Offline ninjatuna
« Reply #56 on: May 03, 2012, 01:39:24 PM »
haha ok na master engr. balitaan kta ;D maraming saLamat ;D
Offline e-tronix
« Reply #57 on: May 06, 2012, 09:34:31 AM »
ptambay
Offline ninjatuna
« Reply #58 on: May 17, 2012, 08:58:50 PM »
[code]'****************************************************************
'*  Name    : UNTITLED.BAS                                      *
'*  Author  : [select VIEW...EDITOR OPTIONS]                    *
'*  Notice  : Copyright (c) 2012 [select VIEW...EDITOR OPTIONS] *
'*          : All Rights Reserved                               *
'*  Date    : 5/17/2012                                         *
'*  Version : 1.0                                               *
'*  Notes   :                                                   *
Device = 16F877A
Declare XTAL = 4
HSERIAL_SPBRG = 25
HSERIAL_RCSTA = $90
HSERIAL_TXSTA = $24
HSERIAL_CLEAR = On
HSERIAL_BAUD = 9600
ADCON1 = 7
Symbol CR            =    13   ' Carriage Return
Symbol LF            =    10   ' Line Feed
Symbol CTRL_Z        =    26   ' Control + Z key
Dim MobileBuffer[13] As Byte    ' Mobile phone storage
Dim GlobalBuffer[13] As Byte   ' Sms storage & General storage
Dim VarX As Byte                ' Global variable
Dim VarY As Byte                ' Global variable
start:
High PORTA.1
DelayMS 500
Low PORTA.1
DelayMS 4000
HSerOut["AT",13]
DelayMS 2000
HSerOut["AT+CMGF=1",13]
DelayMS 2000
HSerOut["AT+CFUN=1",13]
DelayMS 2000
HSerOut["AT+CMEE=2",13]
DelayMS 2000
HSerOut["AT+COPS=0",13]
DelayMS 2000
TIMEOUT:
'    +CPBR: 1,"+639*********",145,"name"
    VarY = 0
    VarX = 10
HSerOut["AT+CMGS=",34,MobileBuffer[VarY],34,13]
DelayMS 2000
HSerOut["Test GSM",26]
DelayMS 2000
End
[/code]
ok na ba yan engr?
Offline ninjatuna
« Reply #59 on: May 17, 2012, 09:48:00 PM »
'*  Version : 1.0                                               *
'*  Notes   :                                                   *
Device = 16F877A
Declare XTAL = 4
HSERIAL_SPBRG = 25
HSERIAL_RCSTA = $90
HSERIAL_TXSTA = $24
HSERIAL_CLEAR = On
HSERIAL_BAUD = 9600
ADCON1 = 7
start:
High PORTA.1
DelayMS 500
Low PORTA.1
DelayMS 4000
HSerOut["AT",13]
DelayMS 2000
DelayMS 2000
DelayMS 2000
DelayMS 2000
DelayMS 2000
TIMEOUT:
    VarY = 0
    VarX = 10
DelayMS 2000
DelayMS 2000
End
engr. eto na pla code ko tama ba flow?[/code]
