Author Topic: ashrock cpu pa tsamba sa hardisk  (Read 605 times)
Offline charles jericho
  • Pogi/Ganda Points: 19
  • its only tomatoe my friend
« on: April 29, 2012, 06:30:17 PM »
mga master any idea, di madetect ung primary master, hanggang i multiple restart minsan tsumatsamba pag tsumamba naman khit maghapon mo gamitin ok naman, ano kaya sakit nito? khit ibang hard disk di nya ma detect pag sinumpong,, tia
Life is not about waiting for the storms to pass,....Its about learning how to dance the rain.
  • Pogi/Ganda Points: 316
Re: ashrock cpu pa tsamba sa hardisk
« Reply #1 on: April 29, 2012, 06:33:37 PM »
palit SATA CABLE.
sub.
« Reply #2 on: April 29, 2012, 06:45:03 PM »
pata pa ito sis tia
Offline Lola Baciang
  • Pogi/Ganda Points: 130
« Reply #3 on: April 29, 2012, 06:58:44 PM »
sinubukan mo na ba palitan ng cable yan?
baka loose lang sa connector
if the problem is persist,try palitan muna ng true rated ang psu nyan
Expect The Unexpected
« Reply #4 on: April 29, 2012, 07:00:03 PM »
kung on board ang videocard nyan,try muna din alisin then observe
« Reply #5 on: April 29, 2012, 07:06:59 PM »
sinubukan ko inilaGAy SA IDE2 using another cable ganun pa din, pero kalaunan tsumamba na naman,,, gmit ko na namaN XA, TIA
« Reply #6 on: April 29, 2012, 08:02:32 PM »
ibig ko po sabihon,alisin muna temporarily ang v-card,then gamitin muna built-in vga out,then observe muna sis
« Reply #7 on: April 29, 2012, 08:05:09 PM »
nagkaganyan din yung board ko, linabhan ko na lang, di na intermittent  ngayon.
Offline Johannah Aleksandria
  • Pogi/Ganda Points: 136
  • Make it simple
« Reply #8 on: April 29, 2012, 09:43:32 PM »
Mlamang PSU problem, pag mainit ang buga ng hangin.
  • Pogi/Ganda Points: 411
« Reply #9 on: April 29, 2012, 09:45:28 PM »
Dumi nga kung ganyan. Gamit ka ng bagong ide cable tapos lipat mo rin sa ibang molex connector.
Or baka nga kulang sa power.
Offline BhongTech
  • Pogi/Ganda Points: 152
« Reply #10 on: April 29, 2012, 10:00:04 PM »
ang ginagawa ko sa mga ganyang mobo na madalas palya at minsan gagana nililinis ko lang ng gamit ay toothbrush at laquer thinner.bina brush ko ng maigi ang mga socket.wag lang yung nangingitim na laquer thinner kasi marumi na din yun ;D syempre yung malinis na laquer thinner.
« Reply #11 on: April 29, 2012, 10:06:11 PM »
^Pede pede, teka anong brand? Kikintab nga mga pins neto. Bawas non contact.
Offline Asarnako
« Reply #12 on: April 30, 2012, 08:48:07 AM »
Check mo ang mga CAPS around sa procie, re solder mo pag medyo darkened na ang leads, replace pag may suspected bloating na....
Offline j a y k e z
  • gimmegaggigsss
« Reply #13 on: April 30, 2012, 09:03:50 AM »
baka mobo nga eto, baka di magtagal bumigay na si harddisk ;D
Offline batang_teatro_ako
« Reply #14 on: August 28, 2012, 05:49:51 PM »
Master Charles wrong spell baka Asrock.
« Reply #15 on: August 28, 2012, 05:55:29 PM »
master Charles iyan talaga ang sakit ng Asrock. sa akin ginawa ko na lahat. palit sata cable, linis mobo,palit psu,palit hdd. ganon parin hard to start.
Offline Mayor Johnaray
  • Pogi/Ganda Points: 238
« Reply #16 on: August 28, 2012, 06:43:12 PM »
Uy binuhay ang Thread ni BATANG_TEATRO ;D ;D ;D WELCOME BACK...
@TS PSU ang problem nyan, we have the same brand of Motherboard and same issue, only to find out na di kinakaya ng supply ng voltage, try mo din labhan ng JOY but make sure na totally tuyo na sya before use or else...HAPPY NEW YEAR!
« Reply #17 on: August 28, 2012, 07:41:56 PM »
ahahahaha ;D ;D ;D
