Author Topic: First Watt B1 Buffer Preamp  (Read 2391 times)
Offline Engr. Dacuycoy
  • Pogi/Ganda Points: 161
  • Proton Orcad EasyPCB User
« on: May 03, 2012, 10:26:08 AM »
Why I want this?
1.The impedance mismatch that makes your tunes sound mushy.
2.A lack of output voltage means that you have to crank up your stereo volume to get a decent listening
Just completed my Buffer Preamp for my ipod.. the problem is the 10uF caps
meron kaya available nito sa pinas?
Re: First Watt B1 Buffer Preamp
« Reply #1 on: May 03, 2012, 10:34:15 AM »
http://beavishifi.com/projects/JFET_preamplifier/
ito sana kaso wala akong makitang MPF102
Offline fantom_mayonaise
  • Pogi/Ganda Points: 30
« Reply #2 on: May 03, 2012, 11:10:10 AM »
mukang 'boutique' capacitor po yata kailangan nyo?
Try nyo din sa e-gizmo. Got this from their site
550106300 10uf/630v           10uF/630V RIFA Cap.                        A
580001361 15UF/250V           Polyester Film Cap.                        A
« Reply #3 on: May 03, 2012, 11:16:31 AM »
ayon.. matanong nga yan +1  ;D
« Reply #4 on: May 03, 2012, 11:46:37 AM »
expect them to be relatively expensive sir. Pa-post na din price dito pag na-inquire nyo.
Offline efren
  • Pogi/Ganda Points: 210
  • old school audio fanatic
« Reply #5 on: May 03, 2012, 12:05:07 PM »
seeing this post made me rummage through my vintage trannies colection
there they are!
gold pins...kinda cute :D
"just keep 'em glowing"
« Reply #6 on: May 03, 2012, 12:11:00 PM »
wow so lucky naman sis efren. baka pwede bilhin ko na yan kahit yong used na  ;D ;D ;D
Offline efren
« Reply #7 on: May 03, 2012, 12:13:47 PM »
just the shipping cost you can have 'em ;)
Offline duc_tech
  • Pogi/Ganda Points: 32
« Reply #8 on: May 03, 2012, 12:23:02 PM »
@Engr. Dacs
interested ako sa pre amp na to kaya lang ang ginamit na JFET na MPF102
ito yung datasheet (RF Amp ^_^)
mukhang ito lang yung available na jfet sa bin ng gumawa nito ...
ito sa bin ko meron akong JFET (2sk117) for replacement ,for audio amp talaga,
image from datasheet:
balak kung ilagay sa DR100w amp...thanks sa share..
« Reply #9 on: May 03, 2012, 12:40:38 PM »
ygpm
@duc_tech
pwede siguro yan adjust lang sa biasing
Offline efren
« Reply #10 on: May 03, 2012, 12:53:30 PM »
the JLH 1996 & 2005 revisions employ VHF RF trannies, no issues encountered regarding sound quality...
Offline abeTIR
  • Pogi/Ganda Points: 96
  • the show must go on...
« Reply #11 on: May 03, 2012, 12:59:23 PM »
you can ask gerry morales, the last time I went there binigyan niya ako ng isa "bonus" pang-test daw 10uf/600v metallized poly..
sa DEECO I've seen on the shelf 6.8k 250v metallized poly din, mukhang mura lang naman.
+1 ganda ng PCB.. ;D
- The Method of DePalma
Offline efren
« Reply #12 on: May 03, 2012, 01:08:24 PM »
sa deeco marcos highway meron Nichicon 10uF/25V non-polar, packed in two's for less than 20Pesos. malamang marami din yan sa ibang branch or store other than deeco.
Offline n0th1n6
  • Pogi/Ganda Points: 62
« Reply #13 on: May 03, 2012, 01:12:18 PM »
Sir efren, pwede rin po makiamot ng mpf102? Gusto ko rin gumawa ng guitar preamp gamit JFET.
Offline duc_tech
« Reply #14 on: May 03, 2012, 01:19:27 PM »
thanks sir efren for the info's
Offline efren
« Reply #15 on: May 03, 2012, 01:25:09 PM »
hingi ka nalang kay engr Dacs, nakuha na nya, dun nya kukunin sa bahay ni sir tony ;)
alam ko pupwede kahit di mpf102, mag aadjust ka nga lang ng mga biasing resistors, meron pa ako dito 2pcs 2N5458 general purpose N channel Jfet 25V, 16mA isabay ko narin dalhin kung type mo,.
« Reply #16 on: May 03, 2012, 01:35:20 PM »
may nakita din akong ganyan sa deecon cubao. di ko alam kung paano basahin yung 6.8K. paano nga ba?
Offline abeTIR
« Reply #17 on: May 03, 2012, 01:49:01 PM »
^ reads 6.8uf k is for tolerance..correct me if i'm wrong...
Offline n0th1n6
« Reply #18 on: May 03, 2012, 06:58:55 PM »
Aw nakuha na pala. Kung di na umabot sir ok lang po. Ngayun lang kasi uli ako nakapag login. Baka umorder na lang ako ng J201 sa element14.
  • Pogi/Ganda Points: 520
« Reply #19 on: May 03, 2012, 07:18:20 PM »
ako meron...... :D :D :D
actually pwede naman na 50volts yung working voltage ng coupling caps, pm nyo sa Danny, merong mga WIMA caps sya....
