Author Topic: ugong..... lang maririnig ......??????  (Read 525 times)
Offline eirrab
  • Pogi/Ganda Points: 7
« on: May 03, 2012, 06:55:36 PM »
patulong po mga sis may natanggap po ako amplifier ugong lang po maririnig pag power on mo ugong lang ito po yung unit pic
una ko ginawa tinanggal ko yung equalizer section...  power on ulit ugong parin
pangalawa...check component...shorted po yung power amp naka red circle saka po yung trasistor ..sunog dn po yung mga reistor
dn,...... pinalitan ko po yung mga defect component
power on ulit without equalizer ugong parin  paki edit nalang po sa guide thanks.....
NEWBE LANG PO>>>>>>>SALAMAT
  • Pogi/Ganda Points: 324
Re: ugong..... lang maririnig ......??????
« Reply #1 on: May 03, 2012, 06:57:14 PM »
remove output (the big ones) check dc offset sa speaker terminal.
Offline mcleod
  • Pogi/Ganda Points: 143
« Reply #2 on: May 03, 2012, 07:25:23 PM »
psu section sis, asan? history, bakit nagkaganito? (kung nagkuwento owner)
Offline ditchie
  • Pogi/Ganda Points: 100
  • wish ....wish...
« Reply #3 on: May 03, 2012, 07:37:16 PM »
 replace main filter ecap of higher capacitance value and voltage rating.
--Mahatma Gandhi
Offline ditchie
  • wish ....wish...
« Reply #4 on: May 03, 2012, 07:40:42 PM »
if shorted output trannie, diba naopen yung emmiter resistor niya sis? 0.22ohms na 2watts?
--Mahatma Gandhi
Offline 01110011
  • Pogi/Ganda Points: 101
« Reply #5 on: May 03, 2012, 07:47:06 PM »
try mo na walang pre-amp, check mo din voltages PSU mo
Offline ♪ ♫ ♫ ♪ ♪ ♪ ♫ ♫ ♫
  • Pogi/Ganda Points: 124
« Reply #6 on: May 03, 2012, 08:53:14 PM »
TS..
ano ba ang nangyari at nasunog at umgong yan?
Offline BhongTech
  • Pogi/Ganda Points: 152
« Reply #7 on: May 03, 2012, 09:06:18 PM »
check mo na rin ang mga transistor na paisa isa yung 2N5551 at 2N5401 at yung resistor dapat eksaktong 100ohms din ang ikabit.check mo na rin ang mga 2w/0.22ohms resistor tulad ng nasabi sa itaas at sa pag test pwede naman wala muna ang output transistor para ma test muna kong may dc offset sa output ng amp.
Offline Johannah Aleksandria
  • Pogi/Ganda Points: 138
  • Make it simple
« Reply #8 on: May 03, 2012, 09:40:25 PM »
Palitan mo lang mga sira, at check kung di shorted ang speaker.
2 diodes ang biasing sa LTP CCS tranny.
Series resistor + diode sa biasing ng driver trannies.
Sunog ang mga driver trannies at output pati resistor ng driver, maaring open ang mga 0.22ohm resistor.
Offline eirrab
« Reply #9 on: May 04, 2012, 11:47:22 AM »
isa isa ko po gawin mga suggest nyo post ako ulit ano result salamat na tumulong......
Offline tatamcleanz
« Reply #10 on: May 04, 2012, 11:52:34 AM »
patambay...
Offline acer
  • Pogi/Ganda Points: 117
« Reply #11 on: May 04, 2012, 02:01:03 PM »
tamabay lang muna
nevergive up
Offline eirrab
« Reply #12 on: May 04, 2012, 02:37:31 PM »
sis paturo pano mag test nang dc offset ilang volt ba dapat lalabas sa speaker terminal  tnx...
Offline eirrab
« Reply #13 on: May 04, 2012, 02:45:47 PM »
bigla nalang daw umugong sis sabi nang may ari
Offline ditchie
  • wish ....wish...
« Reply #14 on: May 04, 2012, 02:54:01 PM »
^advice ko lang yun at para iwas din backjob. yan ang ginagawa ko sa mga china speaker amp na dumadating sa akin. kasi based on my experienced palaging bloated dahil underrated siya. then maliit din capacitance value.
--Mahatma Gandhi
Offline j a y k e z
  • gimmegaggigsss
« Reply #15 on: May 04, 2012, 02:57:31 PM »
parang voltage test sa out ng amplifier na walang signal sa input. mV
Offline eirrab
« Reply #16 on: May 04, 2012, 02:58:07 PM »
ano po ba pwede value ipalit natin sis
Offline ditchie
  • wish ....wish...
« Reply #17 on: May 04, 2012, 03:04:30 PM »
i use not lower than 4,700uf/ 63 volts
--Mahatma Gandhi
Offline eirrab
« Reply #18 on: May 04, 2012, 03:05:04 PM »
PAKI EDIT nalang po sa pic dami kona napalitan resistor.,transistor, 4 amp at saka capsitor ...medyu sumakit na ulo ko paturo po paano mag trace sa voltage ...... pahingi narin para sa gamot sa ulo jejejjejejejjejejeje.......
Offline eirrab
« Reply #19 on: May 04, 2012, 03:07:29 PM »
ok try ko yan sis
