Author Topic: MikroC's SPI Ethernet ENC28J60 Library  (Read 9660 times)
Offline PlCUSER
  • Pogi/Ganda Points: 152
« Reply #260 on: May 20, 2012, 10:12:39 PM »
Pwede kaya yun?
pwd prof, kung sa dotmatrix mo na gagamitin. pero kung pang lcd lang, gamitin mo na lang ung uart lcd pang uart test. saktong sakto un. ;D ;D ;D
Offline ΔЅịMø
  • Pogi/Ganda Points: 140
  • "Live Curious"
« Reply #261 on: May 20, 2012, 10:15:32 PM »
Gagamitin ko lang po yung ibang pins sa PIC nito sir?
Offline PlCUSER
« Reply #262 on: May 20, 2012, 10:38:42 PM »
huwat the question is prof??? me dont get it. ;D ;D ;D
Offline carlsberg11
  • Pogi/Ganda Points: 30
« Reply #263 on: May 20, 2012, 10:48:01 PM »
salamat!! ,maraming activity, galing mo talaga sir lurker.. :D :D :D sige try ko po yung change backround sir lurker... direct to the point mga explanation ah... :D :D :D
prof kaw naman gumawa ng tuts about arduino.. :D :D :D
-Albert Einstein
Offline ΔЅịMø
  • "Live Curious"
« Reply #264 on: May 21, 2012, 08:20:11 AM »
Nyahahahaha. Pasesya sir. Ang ibig ko pong sabihin, kung gagamit po ako ng LCD display via UART, i-sosolder ko po talaga yung mga pins ng PIC18 sir para ma-connect sya sa LCD?
Offline ΔЅịMø
  • "Live Curious"
« Reply #265 on: May 21, 2012, 08:22:19 AM »
Hindi ako magaling sa arduino sir. Yung example ng arduino IDE ang magaling. ;D
Si sir alyas ata ang ARDUINO expert dito sa elab.
Offline PlCUSER
« Reply #266 on: May 21, 2012, 08:28:33 AM »
Sa mcu board, no need to solder. Ung gitnang pin ng connector is tx pin ng mcu
Offline dummy_c
  • Pogi/Ganda Points: 162
« Reply #267 on: May 21, 2012, 09:09:00 AM »
Up!
Master PICUSER pwedi maghingi ng datasheet or manual sa LCD ni prof?
Na curious lang ako. ;D
Maraming salamat.
Yung isa pa niyan saan kaya napunta? ;D ;D
Offline PlCUSER
« Reply #268 on: May 21, 2012, 09:15:43 AM »
ung isa??? sakin. ;D ;D ;D
alam ko nung pinost ko ung lcd dito sa elab, kasama ung datasheet.
Offline dummy_c
« Reply #269 on: May 21, 2012, 09:20:01 AM »
Dami mo ng LCD. Napakarami. ;D ;D ;D
Ok master halungkatin ko sa mga post mo. ;D
Offline ΔЅịMø
  • "Live Curious"
« Reply #270 on: May 21, 2012, 09:25:29 AM »
Yun lang po ang gagamitin ko to interface with the LCD sir?
Maraming salamat.
Eto ata yun sir.
VACUUM DISPLAY FLUORESCENT MODULE
Offline dummy_c
« Reply #271 on: May 21, 2012, 10:03:31 AM »
Napaka swerte mo prof. ;D
Offline ΔЅịMø
  • "Live Curious"
« Reply #272 on: May 21, 2012, 10:08:05 AM »
;D ;D ;D Subukan ko muna ang ENC ko sir bago ako didiretso sa LDC. ;D
Offline ΔЅịMø
  • "Live Curious"
« Reply #273 on: May 21, 2012, 10:35:46 AM »
Pinalitan ko na ang connectors, ganun parin. :(
Wala paring reply from ENC pag-PING ko.
Offline dummy_c
« Reply #274 on: May 21, 2012, 10:41:48 AM »
Ok ito gawin mo prof.
Reset mo yung mcu then ping.
Huwag muna gumamit sa browser.
Offline ΔЅịMø
  • "Live Curious"
« Reply #275 on: May 21, 2012, 10:50:30 AM »
Newbee question sir"
Paano po yun gawin? :D And, hindi kaya mawawala bootloader ko pagnireset sir?
Offline ΔЅịMø
  • "Live Curious"
« Reply #276 on: May 21, 2012, 10:55:30 AM »
Ko-connect ko po sa ground ang PIN1. Tama po ba sir?
Offline dummy_c
« Reply #277 on: May 21, 2012, 10:58:21 AM »
^ Sorry hindi ako sure kasi magkaiba ang ENC natin.
Pareho kayo ni carlsberg.
Pero nasa pin1 then ang ground ng ENC ko.
Newbie answer ko din, hindi mawawala ang bootloader prof.
Hindi ma reprogram ang mcu mo paghindi ka dadaan sa bootloader unless meron ka other means of reprogramming your mcu like using a pickit.
Wala bang reset button ang board?
Di ba mag reset ka before ka mag boatload?
If wala alisin mo nalang ang power.
Then power up.
After 15sec try pinging.
Offline PlCUSER
« Reply #278 on: May 21, 2012, 11:04:58 AM »
Prof, related pa din ba yang hindi ma ping na problem, sa line na dinadagdag na nagcaucause ng hindi makapag open ng page?
Offline ΔЅịMø
  • "Live Curious"
« Reply #279 on: May 21, 2012, 11:13:34 AM »
Opo sir. Eto po yung lines sir:
if(!memcmp(getRequest+6, "1=ON", 4))   // do we have ON command
                 LATC6_bit=1;
if(!memcmp(getRequest+6, "1=OFF", 5))     // do we have OFF command
                 LATC6_bit=0;
Pagtinanggal ko pa yan sa code sir, na-pi-ping ko po ang ENC. Pero pag anjan po yan, eto po yung lalabas:
Then power up.
Ayaw parin sir Lurker.
