Author Topic: MikroC's SPI Ethernet ENC28J60 Library  (Read 9741 times)
Offline PlCUSER
  • Pogi/Ganda Points: 153
« Reply #300 on: May 21, 2012, 07:20:11 PM »
ung uart lcd mo, pwd mo try kay arduino. connect mo sa pc si arduino para sa pc ka na mag send ng chars to display sa lcd
Offline ΔЅịMø
  • Pogi/Ganda Points: 140
  • "Live Curious"
« Reply #301 on: May 21, 2012, 07:26:57 PM »
Sige po sir. Sinusubukan ko pa kasi muna ipagkasundo si ARDUINO at PIC eh via UART. Kaya lang, ayaw ata nila.
Offline dummy_c
  • Pogi/Ganda Points: 162
« Reply #302 on: May 21, 2012, 07:29:46 PM »
Bugbugin ka daw muna prof sabi ni master. ;D
3.3v ba si arduino prof?
Offline ΔЅịMø
  • "Live Curious"
« Reply #303 on: May 21, 2012, 07:34:09 PM »
Nyahahahaha. Oo nga sir eh. ;D ;D
Hindi po sir. 5V po sya. Pwede kaya?
Offline dummy_c
« Reply #304 on: May 21, 2012, 07:39:59 PM »
Hindi ako kabisado sa arduino sir at wali rin akong datasheet niyan.
I think yan ang dahilan bakit hindi tatanggapin ni arduino ang binabato ni pic.
Kailangan mo ng level converter prof. Marami na yan dito.
Offline PlCUSER
« Reply #305 on: May 21, 2012, 07:45:29 PM »
ung rx ng arduino, 3.3V un kung ang signal ay galing sa usbtoserial chip. kaya sabi ko, ung pc ang gamiting tx'er.
Offline dummy_c
« Reply #306 on: May 21, 2012, 07:56:29 PM »
Matigas ang ulo ni prof ohh... ;D ;D
Offline carlsberg11
  • Pogi/Ganda Points: 30
« Reply #307 on: May 21, 2012, 08:01:24 PM »
waaaaaa!! good to go na pala si prof! sorry ngayon lang naka online :D :D :D good to hear that prof na ok na yung prob mo... :D :D :D basa mode lang po ako ha?
si sir picuser ang agressive ha.... :o :o :o
-Albert Einstein
Offline PlCUSER
« Reply #308 on: May 21, 2012, 08:10:28 PM »
sige. si boy femfem na lang ang gulpihin. ;D ;D ;D
Offline dummy_c
« Reply #309 on: May 21, 2012, 08:34:54 PM »
Tuwad na boy femfem... ;D ;D
Pagulpi ako if manalo ako sa challenge. ;D
Offline carlsberg11
« Reply #310 on: May 21, 2012, 08:35:24 PM »
waaaa! wag ako sir! :D :D inosente ako dyan :D :D
-Albert Einstein
Offline carlsberg11
« Reply #311 on: May 21, 2012, 08:36:19 PM »
Pagulpi ako if manalo ako sa chalenge. ;D
very OT:
indi po ako taga tuwad, taga show lang ako :D :D wala ka pang pass sir lurker, pero dahil magaling kang gumiling.... may VIP pass kana sa show ko! nyahahaha! :o :o :o
EDIT:
matatagalan pa sana yung challenge :D :D para naman maging ready kami. big big prizes kasi binibigay ni doc picuser :D :D
-Albert Einstein
Offline dummy_c
« Reply #312 on: May 21, 2012, 08:46:13 PM »
Update ko lang yung sa assignment ko.
Nakuha ko na yung hex to char conversion.
Yung browser automatically na i-convert nya to hex pag may input na symbols for example:
.,?$&, etc...
At ang masaklap pa ay separated ang hex characters, so ikalawa nya ibato ang hex code.
Ang ginagawa ko gumamit ako ng more than one swicth case statements.
Baka meron din iba pang solution.
One bug solved...two more to go. ;D ;D
Offline carlsberg11
« Reply #313 on: May 21, 2012, 08:49:37 PM »
.,?$&, etc...
@%$!%^$@&*^@ ,..... ano daw? :o :o :o ..back to change backround, ill do my assignment na rin... :D :D :D
-Albert Einstein
Offline PlCUSER
« Reply #314 on: May 21, 2012, 09:02:26 PM »
Sige aral lng tayo. Pag naggawa ko nang pag usapin si ENC module at SIM900 GSM module over the internet, baka by that time, ready na tayong lahat sa challenge. Ready na rin akong mag good bye kay GSM module nun. ;D ;D ;D
Offline ΔЅịMø
  • "Live Curious"
« Reply #315 on: May 21, 2012, 09:14:45 PM »
Gusto ko sang sumali, kaya lang, parang di kayanin ng powers ko e. ;D
Salamat nga pala boy femfem. ;D
Ilang volts po pala pinapalabas ni PIC sir PICUSER? ;D
Susubukan ko palang bukas lahat-lahat. So far, gumana po yung LCD 16x2 ko using arduino at serial. Yung pamasko na ni sir PICUSER ang papaganahin ko bukas.
Offline carlsberg11
« Reply #316 on: May 21, 2012, 09:37:26 PM »
ayos lang prof! pero yung assignment natin tungkol sa RAM, indi po nameet since sa ROM parin tayo nag save. sana ok lang kay master lurker yun.
sir picuser, ilang V nga po pala output nung PIC? wild guess ko 3.3 V din po no?
-Albert Einstein
Offline ΔЅịMø
  • "Live Curious"
« Reply #317 on: May 21, 2012, 10:05:06 PM »
Sana nga. :D Para hindi na kailangan ang level converter.
Offline carlsberg11
« Reply #318 on: May 22, 2012, 12:02:44 AM »
sir lurker, may prob ako tungkol sa pag papalit ng backround, since hindi gumagana sa amin na ilagay yung HTML sa RAM, invalid po yung
memcpy(automation+366, colorOFF, 6);  // clear OFF button background
dapat kasi char automation siya  which can be found in RAM pero hindi naman gagana. pero if const char code automation* gagana po siya kaso ito nman yung prob yung memcpy(automation+366, colorOFF, 6);
saglit nga research muna..
-Albert Einstein
Offline PlCUSER
« Reply #319 on: May 22, 2012, 12:07:39 AM »
ayeoh. adik na. ;D ;D ;D
