Author Topic: MikroC's SPI Ethernet ENC28J60 Library  (Read 9648 times)
Offline carlsberg11
  • Pogi/Ganda Points: 30
« Reply #320 on: May 22, 2012, 12:26:55 AM »
ayeoh. adik na. ;D ;D ;D
:D :D medyo busy sa umaga at hapon e. kaya gabi na ako maka loving2x sa enc module :D :D :D
back to topic:
may idea na ako sir lurker regarding
memcpy(automation+366, colorOFF, 6);  // clear OFF button background
lagyan lang ng & yung automation...
memcpy(&automation+366, colorOFF, 6);  // clear OFF button background
pero indi ko pa napagana yan, successfully build lang po yan ha... indi ko pa na change backround... suko na kasi ako sa pagbibilang nung bgcolor of each button kung pang ilan sila sa array.... :( :( :(
EDIT:
nightwatch ako lagi sa thread na to a... :D :D :D ako lang OL at si doc picuser :D :D :D
-Albert Einstein
Offline dummy_c
  • Pogi/Ganda Points: 162
« Reply #321 on: May 22, 2012, 12:26:36 PM »
Nabigay ko na kay prof yung VB application sir.
Baka mamayang gabi na ako mag online ulit.
Saka na ang instruction sa paggamit doon.
Offline dummy_c
« Reply #322 on: May 22, 2012, 07:13:55 PM »
Up!
Ito po yung applicationvery simple vb application sir carlsberg,
https://rapidshare.com/files/1078142608/VB6_HTMLlength.zip
Ito po yung example sa paggamit...
Very simple lang po yan.
Nagawa ko yan noon dahil desperate ako paano madalian kong makuha ang value saan nakalagay ang color attribute.
After noon hindi ko na na-improve dahil sa wala ng time. ;D
Offline ΔЅịMø
  • Pogi/Ganda Points: 140
  • "Live Curious"
« Reply #323 on: May 22, 2012, 07:21:45 PM »
Salamat dito sir. ;D Ang dali lang magbilang. ;D
Offline dummy_c
« Reply #324 on: May 22, 2012, 07:24:46 PM »
Swerte mo hindi mo na experience magbilang.
Ako at si carsberg naduling(nalibat) sa pagbibilang. ;D ;D
Offline ΔЅịMø
  • "Live Curious"
« Reply #325 on: May 22, 2012, 07:34:38 PM »
Nyahahaha.
Inuna ko kasi muna ang LCD ko sir bago po ako pupunta sa pagpapalit ng kulay. ;D
Offline carlsberg11
« Reply #326 on: May 22, 2012, 07:43:49 PM »
maraming salamat po dito sir lurker! napadali talaga.... maya2x mag loloving loving na rin ule sa ENC module...
naiinis lang ako sa pag bilang kasi indi po kasi accurate. especially nag tritrial and error ka.. yung tipong sasabog ka sa inis cause your expecting that you counted it correctly... galing mo talaga sir lurker sa paggawa ng apps.. :D :D +1 po dito sir!!
+1 din po sayo prof.... salamat sa pagbigay :D :D :D, intermediate action agad si prof e :D
-Albert Einstein
Offline ΔЅịMø
  • "Live Curious"
« Reply #327 on: May 22, 2012, 08:43:05 PM »
Yun kasi ang sabi ni master lurker eh. ;D Nakuha ko narin ang LCD. Pa-communicate ko nalang si PIC at ARDUINO. After nito, balik na sa pagkukulay ng button. ;D
Offline carlsberg11
« Reply #328 on: May 22, 2012, 08:52:57 PM »
advance kana prof e.. :D :D congrats po nyan. dont forget sa tuts.. haha :D :D :D
-Albert Einstein
Offline dummy_c
« Reply #329 on: May 22, 2012, 09:09:14 PM »
I am not sure if pwedi ba ninyo ma edit ang HTML kasi na save ninyo ito as a constant, meaning usually hindi ito binago.
A much easier approach ay hati hatiin ninyo ang HTML ninyo.
Ihiwalay niyo ang part sa color attribute.
That way pwedi kayo maggawa ng more than one constant HTML code para sa button lang mismo.
For example,
const   char    *Button1On = ....
const   char    *Button1Off= .....
const   char    *Button2On = .....
const   char    *Button2Off= .....
And much easier kasi di na kailangan magbilang.
I hope naintindihan ninyo ang ibig kong sabihin. ;D ;D
Offline ΔЅịMø
  • "Live Curious"
« Reply #330 on: May 22, 2012, 09:11:48 PM »
Nyahahahaha. Malapit na kasing matapos ang summer eh. Kahit hanggang LCD nalang muna ako. Mamaya nalang yung dot matrix. ;D
Salamat nga pala sir lurker at sir PICUSER sa pagtitiis. ;D ;D ;D At sayo rin sir boy femfem sa pagsabay. ;D
Offline ΔЅịMø
  • "Live Curious"
« Reply #331 on: May 22, 2012, 09:14:11 PM »
For example,
Bali, tatawagin nalang po namin yung mga constant na yan?
Offline dummy_c
« Reply #332 on: May 22, 2012, 09:18:26 PM »
Yah tatawagin sir depende kung ano condition ng mga buttons.
Yung HTTP example ng mikroC, hinati sa dalawa ang HTML codes.
Offline dummy_c
« Reply #333 on: May 22, 2012, 09:19:44 PM »
OT:
Malapit na si femfem makakakita ng Pampalinaw sa Mata. ;D ;D
Offline carlsberg11
« Reply #334 on: May 22, 2012, 09:22:05 PM »
For example,
parang nag declare na lang kami ng variables of button for manipulation , ganun po ba sir lurker?para fix na lang po? hope tama ako :D :D :D
gusto ko rin kasi mga ganitong activity, marami kang natututunan at hindi ka magiging tamad eh may nag hehelp sayo :D :D,dev board na lang kulang prof e... good to go na agad :D :D :D
-Albert Einstein
Offline dummy_c
« Reply #335 on: May 22, 2012, 09:25:07 PM »
Ganito pag call,
      len =  putConstString(httpHeader) ;               // HTTP header
                len += putConstString(httpMimeTypeHTML) ;   // with HTML MIME type
                len += putConstString(indexPage) ;              // HTML page first part
// Test mo dito ang condition ng button then for example,
                len += putConstString(Button1On) ;
                len += putConstString(Button2Off) ;
                len += putConstString(indexPage2) ;             // HTML page second part
or
                len += putConstString(Button2On) ;
Offline carlsberg11
« Reply #336 on: May 22, 2012, 09:28:11 PM »
Ganito pag call,
or
ayos!! na excite na naman ako sir lurker! kinikilig eh!! :o :o :o ma try nga ngayon :D :D
-Albert Einstein
Offline dummy_c
« Reply #337 on: May 22, 2012, 09:40:17 PM »
I wish matagalan pa ang net ko para mapa work natin ito.
Pero mamaya mawala na to. :(
Ito ang entire HTML ko,
char automation[] =
"<form name=\"input\" action=\"/\" method=\"get\">\
<body bgcolor=#99FFCC>\
<h1 align=center>ENC28j60 Home Automation System</h1>\
<br>\
<table align=center width=200 bgcolor=#4974E2 border=2><tr>\
<td align=center colspan=2><font size=6><b>Gate</b></font>\
</td></tr><tr><td align=center bgcolor=#F52887><input name=\"1\" width=60 \
type=\"submit\" value=\"ON\"></td><td align=center bgcolor=#F52887>\
<input name=\"1\" type=\"submit\" value=\"OFF\"></td></tr></table>\
</form></body></html>";
For example if hati hatiin natin yan,
const   char    *indexPage =
<br>\
"</td></tr><tr><td align=center bgcolor=#F52887><input name=\"1\" width=60 \
const   char    *indexPage2 =
"<input name=\"1\" type=\"submit\" value=\"OFF\"></td></tr></table>\
Gawa pa kayo ng ibang,
const   char    *Button1On= .....
Offline PlCUSER
  • Pogi/Ganda Points: 152
« Reply #338 on: May 23, 2012, 12:23:20 AM »
maagang natulog ang mga adik ah. naubusan ata ng mahihithit. ;D ;D ;D
Offline dummy_c
« Reply #339 on: May 23, 2012, 08:22:05 AM »
UP!
Ahahahaha akala ko nagawa nila. ;D ;D ;D
Ready na ba LCD mo prof?
Gusto ninyo LCD na tayo? Hindi muna yung scrolling display. ;D
