maagang natulog ang mga adik ah. naubusan ata ng mahihithit.
UP!Ahahahaha akala ko nagawa nila. Ready na ba LCD mo prof?Gusto ninyo LCD na tayo? Hindi muna yung scrolling display.
^^ Pakita nga ng codes... By the way matanong lang sir femfem, ano ginamit ni master na XTAL sa board ninyo?Salamat.
const code char *automation="<form name=\"input\" action=\"/\" method=\"get\"><body bgcolor=#99FFCC><h1 align=center>ENC28j60 Home Automation System</h1><h2 align=center> by: Boyfemfem</h2><br>\<table align=center width=200 bgcolor=#4974E2 border=2><tr><td align=center colspan=2><font size=6><b>MahiwagangGate</b></font>";const code char *defaultbutton ="</td></tr><tr><td align=center bgcolor=#F52887><input name=\"1\" width=60 type=\"submit\" value=\"ON\"></td><td align=center bgcolor=#F52887><input name=\"1\" type=\"submit\" value=\"OFF\"></td></tr></table></form></body></html>";const code char *onbutton ="</td></tr><tr><td align=center bgcolor=#FFFF00><input name=\"1\" width=60 type=\"submit\" value=\"ON\"></td><td align=center bgcolor=#F52887><input name=\"1\" type=\"submit\" value=\"OFF\"></td></tr></table></form></body></html>";const code char *offbutton ="</td></tr><tr><td align=center bgcolor=#F52887><input name=\"1\" width=60 type=\"submit\" value=\"ON\"></td><td align=center bgcolor=#FFFF00><input name=\"1\" type=\"submit\" value=\"OFF\"></td></tr></table></form></body></html>";
if(!memcmp(getRequest+6, "1=ON", 4)) // do we have ON command { LATC6_bit = 1; // set PORTD bit7 len = putConstString(httpHeader) ; // HTTP header len += putConstString(httpMimeTypeHTML) ; // with HTML MIME type len += putConstString(automation); len += putConstString(onbutton) ; } if(!memcmp(getRequest+6, "1=OFF", 4)) // do we have OFF command { LATC6_bit = 0; len = putConstString(httpHeader) ; // HTTP header len += putConstString(httpMimeTypeHTML) ; // with HTML MIME type len += putConstString(automation) ; len += putConstString(offbutton) ; } len = putConstString(httpHeader) ; // HTTP header len += putConstString(httpMimeTypeHTML) ; // with HTML MIME type len += putConstString(automation) ; len += putConstString(defaultbutton) ;
Another +2 for that sir carlsberg.Babalik lang ako sir kasi bili pa ako ng 20mhz xtal.Try ko paganahin ang bootloader.May comment ako sa codes mo, mamaya na.
sige sir! go go go! salamat po sa ganda points , feel free to comment lang sir para naman may learnings ulit
^^ Papakita ang grades mo dito prof or else minus points ka.... Sir carlserg I admire your effort kaya binibigyan kita ng pampa pogi. Ok try this with your program sir,Turn ON the LED using the browser.Then after that go to your ENC's IP address, 192.168.1.2.Is the ON button still active?
prof ,baka ina away mo yung ENC module mo.. LQ ba kayo? ayan si doc picuser..... love doctor yan..
Check mo ng multimeter prof if may supply ba ang ENC prof.Kahit na walang mcu basta meron lang supply, iilaw talaga yang yellow at green LEDs.By the way kakabalik lang ng net ko.Sir carlsberg maka connect ka ba ng LCD sa ENC hardware mo.If hindi plan B tayo, sa UART nalang. Mas madali pa ang debugging.
