Author Topic: Anong Math ang Pinakamahirap para sa inyo??  (Read 12585 times)
Offline torpedo212001
  • Silent waters run deep
« on: July 07, 2008, 09:35:26 PM »
Anong engineering math subjects ang pinkamahirap para sa inyo??
Sa akin, pinakamahirap ang Differential Equations...maraming techniques plus memoryahan ng formulas sa difcal at intcal. Pinakamahirap na topic sa DE ang Inspection, for me.
1. Algebra
2. Trigonometry
3. Anal Geom
4. Solid Geom
5. Diff Cal
6. int Cal
7. Diff Eq
8. Adv. Eng. Math
9. num methods
10. Discrete Math
11. Or any math..
First impressions shouldn't last
Offline penny
  • Pogi/Ganda Points: 22
Re: Anong Math ang Pinakamahirap para sa inyo??
« Reply #1 on: July 07, 2008, 09:38:12 PM »
pwede bang all of the above and many more!!! hehehe ;)
Offline paranz
  • Pogi/Ganda Points: 177
  • 1/4W resistor specialist
    • RapidSignal Electronics
« Reply #2 on: July 07, 2008, 09:41:55 PM »
yung math na mahahaba ang solutions, yan ang ayaw ko  >:(
like math topics on signal and systems, DSP, fouriers (engg math)
Offline blue_striker
« Reply #3 on: July 07, 2008, 09:43:47 PM »
In our school th Math Based Subjects Available are
-Algebra
-Trigonometry
-Solid Mensuration
-Analytic and Solid Geometry
-Diff Calc
-Int Calc
-Multivariable Calculus
-Diff Eq
-Probability and Statistics
-Numerical Methods Lec and Lab
-Discrete Math
-Advance Engineering Math
-Digital Signal Processing
The most difficult dahil hindi magaling ang prof ay Multivariable Calculus
  • Pogi/Ganda Points: 635
« Reply #4 on: July 07, 2008, 09:58:23 PM »
Algebra. ;D ;D ;D ;D ;D ;D ;D
Offline paranz
« Reply #5 on: July 07, 2008, 09:58:56 PM »
Offline 'yus
  • Pogi/Ganda Points: 299
  • hw -> fw -> sw
    • yus' projects
« Reply #6 on: July 08, 2008, 10:39:28 AM »
Arithmetic!  >:(
nagka-Trauma pa ako nung elementary nun pina-memorize sa'min and
pina-recite sa harap ng buong klase yung multiples ng mga numbers (e.g. 6x1=6; 6x2=12.....)  :D
ayaw na ayaw ko ang magmemorize!  >:(
at least yung ibang math pwedeng gumamit ng calculator.  :D
« Reply #7 on: July 08, 2008, 01:20:32 PM »
 ;D ;D ;D
Offline gentleman
  • Pogi/Ganda Points: 8
  • Aim High...
« Reply #8 on: July 08, 2008, 01:37:17 PM »
sa akin pinakamahirap ay D.E. : Difficult Equation  ;D ;D ;D
The beginning of knowledge is knowing that you don't know everything...
Offline delta06
« Reply #9 on: July 09, 2008, 01:07:13 AM »
Kaya siguro hirap kami sa engineering mechanics :-[
Dahil din kaya sa hindi rin magaling instructor namin :D
-Algebra
-Trigonometry
-Solid Mensuration
-Diff Calc
-Int Calc
-Diff Eq
-Discrete Math
« Reply #10 on: July 09, 2008, 12:16:05 PM »
Ako math_lab hindi pa rin ako marunong hanggang ngaun.  ;D he he he
sa totoo lang calculus di ko nga alam paano me nakapasa ksi intention ko na ibagsak ang diff calculus nuon ksi nga di ko maintindihan tapos my prof gave me a remedial exam un nakapasa ska me nagsisi nung intagral calculus na.
Offline Google
  • Pogi/Ganda Points: 20
« Reply #11 on: July 09, 2008, 03:30:21 PM »
computer MAth  ;D ;D ;D
nakakailang kasi lalo n yung 1+1 = 0  at saka yung sa BOOLEAN ALGEBRA na mga Identities
Offline clarkent
  • iehs
« Reply #12 on: July 09, 2008, 04:57:14 PM »
DE
« Reply #13 on: July 12, 2008, 07:50:11 PM »
ano bang meron sa digital signal processing? mahirap ba talaga? 2nd semester pa sa amin yun (coe 5th year na po ako ngaun)
« Reply #14 on: July 12, 2008, 08:36:39 PM »
pag di magaling magturo ang prof, humihirap talaga ang subject ;D ;D ;D plus pag wala kang book at sa lecture ka lang naasa ;D ;D ;D
Offline paranz
« Reply #15 on: July 12, 2008, 09:30:06 PM »
basta may textbook lang, mas madali na ang subject  :D
« Reply #16 on: July 12, 2008, 09:34:34 PM »
hehehe ;D nung college ako bihira ako bumili ng mga textbooks kaya kalimitan sa lecture ako naasa ;D nanghihinayang kasi ako bumili ng books ;D ;D
Offline Google
« Reply #17 on: July 12, 2008, 10:44:51 PM »
mahirap talaga yan kailangan dyan matibay foundation mo sa math... puro kasi math analysis yan eh
« Reply #18 on: July 13, 2008, 09:52:41 PM »
normally, Fourier, Z-transform. tapos parang digital version ng Control System yung block diagram.
Offline paranz
« Reply #19 on: July 13, 2008, 09:59:37 PM »
nakakatamad magsolve ng ganyan problems hehe
