Author Topic: help kung paano mag-program sa MCU gamit ang mikroC  (Read 389 times)
Re: help kung paano mag-program sa MCU gamit ang mikroC
« Reply #20 on: May 11, 2012, 03:57:52 AM »
tama po ba tong steps na gngawa ko..
first kinompile ko ang code from mikroC then it generate a .hex file. yung .hex file inimport ko sa mplab ide. then configure what pic na gagamitin ko then select programmer then enable it.
yun po kc gngwa ko pero parang di naman na program yung mga codes kasi po walang output na nagagawa
first, are you sure that your program is working? and your hardware setup is correct for testing?
you didnt mention about selecting the programmer and "Program" the chip :D
