Author Topic: Basic decade counter using 7 segment and zilog F082A mcu  (Read 768 times)
Offline thEta
« on: May 09, 2012, 01:23:25 PM »
hi i am new to zilog programming, and i want to learn how to connect 7 segment display
and make a basic decade counter . . but the problem is i don't have any idea on how to this
one,, do i need to use some ttl ic's?  ???
~pls help. .thanks  :-[
Offline ΔЅịMø
  • Pogi/Ganda Points: 140
  • "Live Curious"
Re: Basic decade counter using 7 segment and zilog F082A mcu
« Reply #1 on: May 09, 2012, 07:51:17 PM »
You're from US sir? :D
You need to have some TTL IC in order to make a MCU based decade counter. All you have to learn it multiplexing. Maybe 74LS47 or a decoder will do. ;D
Offline thEta
« Reply #2 on: May 09, 2012, 10:03:35 PM »
ahaha US pa gd?  ;D
need pa din ba sir? decoder lng po ba ang kelangan? . . .
Offline ΔЅịMø
  • "Live Curious"
« Reply #3 on: May 09, 2012, 10:55:08 PM »
Aw. ;D Akala ko kasi from US kayo. Yup. AFAIK, no need na. Kailangan nyo lang nga decoder at multiplexer. Project po ba to?
Offline thEta
« Reply #4 on: May 09, 2012, 11:17:27 PM »
hindi po sir . . mg a-advance study lng sana para sa micro namin next semester . .
meron po ba kaun diagram or sample code for counters sir? . . dq pa kc kabisado
ang 082a sir , ,  :)
Offline thEta
« Reply #5 on: May 09, 2012, 11:22:04 PM »
anu po pala meaning ng AFAIK ?
<<<<<< newbie here 8)
Offline ΔЅịMø
  • "Live Curious"
« Reply #6 on: May 09, 2012, 11:28:44 PM »
ang 082a sir , ,  :)
Meron. Pero, mas maigi kung kayo talaga yung maka-learn. ;D Hanggang saan na po yung knowledge nyo about zilog? Hello world na program, alam nyo na?
AFAIK = As Far As I Know
Offline thEta
« Reply #7 on: May 09, 2012, 11:40:38 PM »
basics pa lng sir.. ang hellow world po ba sa zilog is yung on and off ng LED?
yup tapos na po kami nyan . . ung basics lang po sana bout variable declarations. .
or bka meron pa pong imports na kelangan  sa library? . .
kc wala naman manual un zilog nung binili namin . . then hindi pa po ganun ka advance ung mga
topic namin sa zilog . .  ???
ahh NIK sir . .
Offline tiktak
  • Pogi/Ganda Points: 204
    • Tiktakx's Blog
« Reply #8 on: May 09, 2012, 11:49:27 PM »
try to look at the seven segment app note of zilog
8051 stuff
Offline thEta
« Reply #9 on: May 10, 2012, 09:21:24 AM »
up po mga master   ;) ;) ;)
Offline thEta
« Reply #10 on: May 10, 2012, 09:06:50 PM »
up ulit  ;D
Offline ΔЅịMø
  • "Live Curious"
« Reply #11 on: May 10, 2012, 11:55:23 PM »
Pasensya TS kung di napansin. Busy siguro yung ibang mga masters dito. ;D Ano nga po pala talaga pakay nyo dito? ;D ;D
Offline thEta
« Reply #12 on: May 11, 2012, 02:58:56 AM »
ask lng po sana f panu i connect ung 7 segment , multiplexers at mcu sir ;)
wala po talga idea . . bka meron po kau simple code . .
Offline motion55
  • Pogi/Ganda Points: 245
« Reply #13 on: May 11, 2012, 08:07:29 AM »
Ang hirap sa mga Zilog products ay kaunti lang sa atin gumgamit nito. Kung wala kang idea, gayahin mo mga schematics ng 7-segment displays ng ibang MCUs like PICs. Almost magkahawig naman ang pins. Kaunting common sense lang yan. No need for spoon feeding.
And as to the program code, maraming C language versions ng decimal counters ma gogoogle mo. It's very easy to port to the Zilog MCUs. Again common sense lang din.
Pag na-assemble mo na ang mga items na ito, then saka na lang ikaw mag tanong ng specific questions. This way, mas maraming tutulong sa iyo.
"Set your mind free!"
Offline thEta
« Reply #14 on: May 11, 2012, 10:57:54 AM »
ahh ganun po, anyway baguhan pa lng po ako sa zilog kaya wala pa po akong idea dito,.
at although the same lng ang schematic interms sa PIC sir but the directives used sir mgkapaehas din po ba?. .i am not asking naman ng whole program sir, ung basic lng po..
Offline thEta
« Reply #15 on: May 11, 2012, 11:09:58 AM »
sir tiktak tnx sa info ;) :)
Offline ΔЅịMø
  • "Live Curious"
« Reply #16 on: May 13, 2012, 11:29:16 AM »
Tama si sir motion. Google it, marami kang makikita dun. Try to connect it by your self then, balik ka dito. About the codes, since alam mo na paano mag hello world, ganoon parin ang decade counters. May idea ka sa C programming? If I am not mistaken, going 5th year kana siguro.
Offline ΔЅịMø
  • "Live Curious"
« Reply #17 on: May 13, 2012, 11:31:24 AM »
And i am trying to point out the tutorial ni sir paranz. Di ko alam kung nabasa mo naba or baka hindi pa. Kung nabasa mo na, then, good. If hindi pa, basahin mo muna.
Offline ΔЅịMø
  • "Live Curious"
« Reply #18 on: May 14, 2012, 07:12:29 PM »
Natapos nyo na to TS? :D
Here is the link: http://www.electronicslab.ph/forum/index.php?topic=294.0
Offline ΔЅịMø
  • "Live Curious"
« Reply #19 on: May 15, 2012, 07:13:56 PM »
TS?
