At kung papayag rin si sis ultra. Santa picpic in the house.
mkagawa nga din nito.
gusto ko kasi ako ang gagawa. para maunawaan ko ang flow ng circuit. ang probz lang kamot ulo ako sa programming (T_T)
ha ? programming ba yun ? noob basic yata yun eh.. . (T_T
Another note on DIY building this tester read the notes lalo na yung arrangement ng test terminal.It should be number if horizontally place to be PIN 2-3-1 from left to right. Or 2-3-1 from top to bottom where 2 is at the top mid (3) bottom (1).Reason. When I place a 5200 and 1943 where PIN arrangement of 3-2-1 vertically top(3),mid(2) and bottom(1)Placing lead terminal of transistor PIN(1) and PIN(3) to Tester PIN(1) and PIN(2) and the middle transistor lead to Tester PIN(3). Read BEC that where supposed to read BCE(the correct terminal marking. Same thing if you place it in between Tester PIN(2) and PIN(3) and the mid to PIN(1). Error reading.
Syempre adjusted mo yung firmware yata. Sakin as is lang. Or yung 680 at 470K ang dahilan.
Wala ako binago sa soft..hand picked ko yung 680R at 470k..
Sakin kasi wa ako mapick. Baka kasi mapakyaw ko dito ang lahat ng resistor bago makakuha ng magkakalapit na value. Kaya nga nakaalalay na yung order ng 1% kaso naorder mo na rin daw lahat.
