Author Topic: sharp primo 20v-l70m no power,no oscillation, led lit  (Read 1148 times)
Offline sodz
« on: May 10, 2012, 03:55:13 PM »
helo mga master,bagohan po sa electronics sana matulungan, may ni repair ako sharp 20v-l70m chassis
ayaw po mag power heto po condition after volt teasting,
secondary volt
b+ 135v, 7v at 11v
jungle tda9387 vcc pin 56 = 3.3v pin 61 =3.3 v
fbt secondary
no voltage
hot base voltage =zero volt
na try ko na mag load ng 100w bulb ok ang psu
tumaas konti ang secondary output
b+ 145v, 8v and 13v na sya
d ko matumbok. ano po salarin? pahelp naman po? TIA
Offline DSM_elektronix_shop
  • Pogi/Ganda Points: 153
Re: sharp primo 20v-l70m no power,no oscillation, led lit
« Reply #1 on: May 10, 2012, 04:17:27 PM »
check supply ng jungle..
check supply ng hdt driver sa collectotr..
check eeprom supply 5v
check kung umiilaw pa led stanby led..
nagooscillate ba sa first on?o gumagana ba ang tv a few seconds...kung nagooscxillate sya  ng 5sec check mo vertical ic kung nagkakasuply o kaya check mo vert ic kung sira na....
resoldr muna baka loscon pa ang main board mo...checxk possible shorted zener or possible burned resistor or open resistor...
DSM_electronics_shop
Alvin Y. Carulasan
Sinal Village, Taguig city
  • Pogi/Ganda Points: 231
« Reply #2 on: May 10, 2012, 04:42:22 PM »
agree.. check mo muna ang mga ito. lalong lalo na yung 5V standby
Offline pEN DoTA
« Reply #3 on: May 10, 2012, 05:17:39 PM »
umiilaw ba yung LED sis?
GOD LOVES YOU
  • Pogi/Ganda Points: 909
« Reply #4 on: May 10, 2012, 05:17:52 PM »
agreed din ako...
pero mas refer ko yung supply ng jungle/UOC Hvcc
lagi kasi yang nawawala sa ganitong chassis ;D
Offline envader
  • simplicity is beauty
« Reply #5 on: May 11, 2012, 08:01:41 AM »
sis, kong nagawa mo na ang advice ng nasa taas at wala p rin ay hagilapin mo protection circuit baka active ito, nag oscillate ba then auto shut off?
GUSTO MO BA NG EXTRA INCOME? BUMISITA KA DITO AT MAGRIGISTER: http://viralpaidads.com/?=3666
« Reply #6 on: May 11, 2012, 10:06:28 AM »
wala na ts ano kaya update
Alvin Y. Carulasan
Offline sodz
« Reply #7 on: May 12, 2012, 06:40:24 PM »
mga master salamat sa reply, d ako naka online kahapon, may importanting lakad
tapos napo ako nag resolder..,hindi po nag oscillate.., mayron naman po supply 5v standby..
naka ilaw ang led...pero walang supply sa vertcal..
Offline sodz
« Reply #8 on: May 12, 2012, 07:10:16 PM »
sis, hindi sya nag oscillate, walang 8v sa output ng reg ic, at wala boltahe sa hdt collector
ano kaya posible salarin, saan po banda ang protection circuit, bagohan pa kasi ako,,
  • Pogi/Ganda Points: 771
« Reply #9 on: May 12, 2012, 07:26:47 PM »
kadalasan vert. problem actual palit ng vert. ic
check/replace eeprom
Offline sodz
« Reply #10 on: May 12, 2012, 07:53:46 PM »
thanks sir pete at mga master update ko nalang kayo,
actual replace nalang muna vert at eeprom yun ang din hula ko,,tia
  • Pogi/Ganda Points: 315
« Reply #11 on: May 13, 2012, 03:06:17 PM »
protect?
Offline Tripler02
  • Pogi/Ganda Points: 84
  • Saka na my own pic
« Reply #12 on: May 13, 2012, 04:28:48 PM »
pwede matanung fbt # nito ts?
Offline ping
« Reply #13 on: May 13, 2012, 06:45:25 PM »
pahelp man poh sharp 20v-L70M no power noh indcator
Offline brucetech
  • Pogi/Ganda Points: 46
« Reply #14 on: May 13, 2012, 07:17:20 PM »
sis gawa ka ng bagong thread...
 mukhang naka protect nga to...
« Reply #15 on: May 13, 2012, 09:40:40 PM »
pa OT
T602
FO228PE
FO230PE
Offline Tripler02
« Reply #16 on: May 13, 2012, 09:47:05 PM »
pa OT
T602
FO228PE
FO230PE
for 20 and 21inch ba to respectively sis?502+1=503
Offline alphavic
  • Pogi/Ganda Points: 27
  • Alphavic Communication
« Reply #17 on: May 13, 2012, 10:11:50 PM »
vertical, x prot=ABL sec., eeprom pagpilian mo lang baka makachamba ;D ;D
selfish ka o duwag ka lang ma failed?
Offline pEN DoTA
« Reply #18 on: May 13, 2012, 11:29:46 PM »
check vertical section.
GOD LOVES YOU
Offline J@M
« Reply #19 on: May 14, 2012, 01:17:59 AM »
Vertical din ako
Don't Give up
