Author Topic: sharp primo 20v-l70m no power,no oscillation, led lit  (Read 1777 times)
Offline mcleod
  • Pogi/Ganda Points: 144
Re: sharp primo 20v-l70m no power,no oscillation, led lit
« Reply #20 on: May 14, 2012, 10:26:31 AM »
helo mga master,bagohan po sa electronics sana matulungan, may ni repair ako sharp 20v-l70m chassis
ayaw po mag power heto po condition after volt teasting,
secondary volt
b+ 135v, 7v at 11v
jungle tda9387 vcc pin 56 = 3.3v pin 61 =3.3 v
fbt secondary
no voltage
hot base voltage =zero volt
na try ko na mag load ng 100w bulb ok ang psu
tumaas konti ang secondary output
b+ 145v, 8v and 13v na sya
d ko matumbok. ano po salarin? pahelp naman po? TIA
na-check na ang HOT ?good ba? check mo main regulator mo. (resistors dito) good ba? abl resistors see markings ng fbt mo sundan mo ang copper trace (be sure di nakasaksak bago sundin ang trace!!!)
Offline sodz
« Reply #21 on: May 15, 2012, 11:34:41 AM »
mga master oscilliate sya ng 1 sec tapos standby mode sya ulit
may napansin ako aalog alog ang core fbt, ano po magandang gawin ko..newbie lang po ako
nagpalit narin po ako ng vert ic stv9302a galing salvage monitor board tda8172
pero no luck parin..
If you ran you only die tired
Offline hengilbert
  • Pogi/Ganda Points: 384
« Reply #22 on: May 15, 2012, 11:48:25 AM »
^ protect na ata.
Offline sodz
« Reply #23 on: May 15, 2012, 12:34:46 PM »
^ protect na ata.
sis ryu, anong gagawin pag nag protect, please help
Offline hengilbert
« Reply #24 on: May 15, 2012, 12:37:25 PM »
  • Pogi/Ganda Points: 1088
« Reply #25 on: May 15, 2012, 03:40:28 PM »
msa chassis ito tama ?
tumuon sa mga prot. ckt.
paki check mu nga ts.
R803, R804, R805, D601, D754, D7xx, D7xx   ;D
DVD Dump - http://www.elab.ph/forum/index.php?topic=22986.1660;topicseen
Offline hengilbert
« Reply #26 on: May 15, 2012, 04:21:50 PM »
pinuntirya kaagad ;D
Offline sodz
« Reply #27 on: May 16, 2012, 03:43:10 PM »
kapehan na
r605=82k opened at r60720ohms chaged value to 28ohms
malapit sa flyback
wooo sarap ng feeling first times ko sa tv na halos 1 buwan ko ginawa,
masaya din auntie ko ok na tv nya
sa mga nag tiyaga sa akin maraming salamat mga kapatid
marami akong natutunan, ilagay ko sana d ako marunong,sory hehe
+1 pogi points kayo lahat sa akin
Offline sodz
« Reply #28 on: May 16, 2012, 05:19:57 PM »
Offline hengilbert
« Reply #29 on: May 16, 2012, 05:45:46 PM »
ingat sa BJ ;D
Offline Deantyne
  • Pogi/Ganda Points: 122
  • Use P-C-D-A in daily life.
« Reply #30 on: May 16, 2012, 06:21:38 PM »
congrats..hehehe
"To gain new ideas, read the old book" - UNKNOWN
« Reply #31 on: May 17, 2012, 09:53:08 AM »
di pumasok ang hula ko  ;D
Offline DSM_elektronix_shop
  • Pogi/Ganda Points: 159
« Reply #32 on: May 17, 2012, 09:57:51 AM »
congrats...
DSM_electronics_shop
Alvin Y. Carulasan
Sinal Village, Taguig city
Offline lenovo
« Reply #33 on: May 17, 2012, 10:06:13 AM »
master mukhang malabo n bolang xtal mo,,, upgrade mo n yan
@ ts sa r607 change value at bumaba? 200 ohms to 28 ohms,,,
Offline lenovo
« Reply #34 on: May 17, 2012, 10:09:31 AM »
e2 pogi pt u sir kz nagawa u unit 1st tym 1st pt  ;)
Offline lenovo
« Reply #35 on: May 17, 2012, 10:12:09 AM »
GA1 chassis master kaya pala mali hula mo,,, hehee
Offline sodz
« Reply #36 on: May 17, 2012, 10:14:19 AM »
20 ohms naging 28 ohms
no bj sya two days obsevation na
salamat mga masters
Offline lenovo
« Reply #37 on: May 17, 2012, 10:16:49 AM »
salamat mga masters
ay uu nga pala sori heheeh congratz sir  sodz
  • Pogi/Ganda Points: 267
« Reply #38 on: May 17, 2012, 01:04:46 PM »
Congratzzzzzz..
Offline mcleod
« Reply #39 on: May 17, 2012, 04:02:46 PM »
congrats ts! and thank you, di ka nawala tulad ng ibang ts, pagtapos magawa meron pa nga pagkahaba - haba ng pm tapos nung magawa di nag - update!  ;D ;D ;D
