Author Topic: Sanyo TV ST-21CF1 No Sounds.  (Read 2258 times)
Offline ßlaze25
« on: May 10, 2012, 04:54:23 PM »
Mga masters baka po pwede patulong dito posible na kaya sira na iyong ic na malaki na LA76938NDE56SO-E,nagpalit na po me ng LA42032 audio ic pero no luck,i check vcc ng la42032 its ok 12vdc,may nakita ako dito post ni sir roverics at try ko iyon pero no luck(PIN 6 audio out jungle ic) direct connect to PIN 2and 4 of LA42032 audio ic no luck po,posible ba na jungle ic na?
Offline Min
  • Pogi/Ganda Points: 202
Re: Sanyo TV ST-21CF1 No Sounds.
« Reply #1 on: May 10, 2012, 05:07:10 PM »
Question TS, No sound ba pag sa TV programs, how about pag sa AV mode no sound din ba?
  • Pogi/Ganda Points: 915
« Reply #2 on: May 10, 2012, 05:13:11 PM »
sis  di mu nabanggit  about sa pag try ng disable ng mute pin ng sound ic..
 LA42032 (pin6) at pati din ang stndby pin (pin5) nya...
pag na try mu na yan... pasukin mu naman ang SVC mode... try kalikutin don
Offline pEN DoTA
« Reply #3 on: May 10, 2012, 05:16:28 PM »
oo nga disable muna.
ang galing ni master ultra. :)
GOD LOVES YOU
  • Pogi/Ganda Points: 231
« Reply #4 on: May 10, 2012, 05:21:09 PM »
i agree.. nakaka talino talaga ang saging.. ;D
Offline ßlaze25
« Reply #5 on: May 10, 2012, 05:25:42 PM »
SVC mode paano gawin iyon master ultra sensya na medyo nangangapa pa ako sa ganitong gawain.
Offline ßlaze25
« Reply #6 on: May 10, 2012, 05:27:18 PM »
uu lahat wala sounds master...
Online pete
  • Pogi/Ganda Points: 771
« Reply #7 on: May 10, 2012, 05:29:14 PM »
make sure na ok ang tact switch ng tv
on mode
press and hold menu on tv and press number 2 on remote
use vol-+ to adjust
use ch-+ to select
press menu to exit
Online pete
« Reply #8 on: May 10, 2012, 05:30:37 PM »
wala bang sound kahit sa a/v out?
baka may sound processor na LV ic yan
« Reply #9 on: May 10, 2012, 05:33:31 PM »
ito pasok ka dito...
http://www.electronicslab.ph/forum/index.php?topic=2267.140
bago ka mag attempt mag bago ng data.. ilista muna sa malinis na papel ang orig data parameter.. para kng sakaling may mali sa pag-aadjust mu.. pwde mu pang ibalik sa default settings...
but takenote di ko pa nirerefer sau ang service mode as long na di mu pa sinusubukan ang suggestion ko sa taas.. at ang gustong ipagawa sau ni sis HG
how about sa AV mode ?
wala din bang sound ?
dahil nag attempt kang i direct ang from jungle/UOC to Sound ic.. dapat dinisable mu  muna ang Mute pin at siguraduhing di naka standby mode ang sound ic mu...
yan  nlng  muna.. .gudlak
Offline ßlaze25
« Reply #10 on: May 10, 2012, 05:44:16 PM »
ok salamat try ko itong mga advise ninyo salamt mga masters..
FB later..
Offline ßlaze25
« Reply #11 on: May 10, 2012, 06:50:53 PM »
                  di ba delikado iyong ginawa ko master,dagdag ko na din itong nakuhang info sa may ari dati daw intermitent daw ang sounds nia at ginagawa nia press on/off daw nila ang power button at minsan ok daw ang sound pero kalaunan ayaw na talaga kahit ilang gawin ang on/off,ang problema pa walang remote control nawala daw,ilang voltage ba dapat ang LV ic pin 2 at 35?
Offline BUMBLEBEE
  • Pogi/Ganda Points: 109
  • transform!!!!!!!!!!!
« Reply #12 on: May 10, 2012, 07:33:02 PM »
subs.. baka may sound controller pa eto bago dumating sa audio ic
try mo muna payo ni master ultra.. TS. malapit yan sa katotohanan
Online pete
« Reply #13 on: May 10, 2012, 09:36:15 PM »
check www.datasheet4u.com for pinning ng ic mo
Offline comtronixs
  • Pogi/Ganda Points: 53
« Reply #14 on: May 11, 2012, 12:03:01 AM »
load ka muna ng bagong eeprom dumps  bago kumalikot sa hradware :)
Offline Pinoy_Tech
  • Pogi/Ganda Points: 181
    • My YT-Channel
« Reply #15 on: May 11, 2012, 01:02:11 AM »
Uy, abang mode nga ako dito... what a coincidence, exactly same model yung dinala sa
house ko kanina at di ko pa maharap kung anong sira, di pa rin bumalik may ari.
Offline nucleus
« Reply #16 on: May 11, 2012, 01:12:58 AM »
sirain ang dound procie ng sanyo
Offline ßlaze25
« Reply #17 on: May 11, 2012, 06:27:14 AM »
Madugong labanan pala ang unit na ito puro new sa pandinig ko ang mga solutions na ito..,try ko mamaya pagpasok ko sa shop.
Offline ßlaze25
« Reply #18 on: May 11, 2012, 08:22:30 AM »
ito try ko ito ngayon pero no luck pa din po mga masters..
Offline ßlaze25
« Reply #19 on: May 11, 2012, 08:59:35 AM »
Di ko ma svc kasi wala na remote control ibebenta yata sa junkshop hu hu hu....
