Author Topic: Sanyo TV ST-21CF1 No Sounds.  (Read 2254 times)
Offline ßlaze25
Re: Sanyo TV ST-21CF1 No Sounds.
« Reply #20 on: May 11, 2012, 09:56:13 AM »
napasok ko svc mode by using universal remocon,ngayon ano dapat puntahan ko dito para maset ito?
  • Pogi/Ganda Points: 143
« Reply #21 on: May 11, 2012, 10:20:15 AM »
yung item no. 47 naka-set sa "0",  item no. 80 (volume control) = 110, item no. 83 (sifsw) = "1", item no. 86 ="0" ,  88 (audio monitor sw, monitor or fm)= "1"
yan muna.
Offline ßlaze25
« Reply #22 on: May 11, 2012, 10:51:48 AM »
may post si sir bobbie at ito sabi..
@ TS... DON NOT PRESS "MENU" ON TV PANEL & "2" ON REMOTE FOR THIS MODEL, MA CORRUPT ANG EEPROM SETTING MO.... may lalaba na iSORT sa menu at magugulo ang remote functions... FYI
« Reply #23 on: May 11, 2012, 12:49:40 PM »
Offline ßlaze25
« Reply #24 on: May 11, 2012, 01:53:04 PM »
ito sir ang link ng share ng 1 master dito http://www.electronicslab.ph/forum/index.php?topic=33279.0;topicseen
share ko lang mga sis SANYO model:ST-21CE1V.ang problem di mahinaan ang sound..
solution:enter service mode press menu on tv,press 1 button sa remote tapos..yun data tingnan kong 01 gawin mong 00..
index    address                 data
174      opt mono ste           00
wala nman po iyan sa service mode niya sir item #94 lang po ito ang hanganan..,at saka ayaw po niya sa press menu+remocon #1...,sa PRESS MENU + REMOCON #2 lang ito gumagana.
Offline ßlaze25
« Reply #25 on: May 11, 2012, 02:02:52 PM »
ano kaya jungle ic pin# 6 audio out to pre amp to audio amp input pin # 2 at 4 ng la42032 ic..,sino po may pre amp simple circuit lang po pa share...
dugo na ilong ko dito hu hu hu....
Offline Min
  • Pogi/Ganda Points: 202
« Reply #26 on: May 11, 2012, 02:30:12 PM »
Na try mo na sundot method? ung sundutin un input or magpasok na audio unput sa IC tapos kaylangan me marinig ka sa speaker.
M I N 2 5  e l e c t r o n i c s
« Reply #27 on: May 11, 2012, 02:33:25 PM »
baka may sound processor na LV ic yan
hindi mopa nasasagot ito kadalasan kasi ito ang salarin
Offline ßlaze25
« Reply #28 on: May 11, 2012, 02:49:44 PM »
meron po iyan sir kaso wala tayo pamalit sa lv na iyan..
nasundot na din iyan at may may tumutunog nman pag i touch ko input niya..
« Reply #29 on: May 11, 2012, 03:34:17 PM »
san ba location mo? mayron naman yan sa svc center makati
try mo hung pin number 6 ng sound ic mo
  • Pogi/Ganda Points: 911
« Reply #30 on: May 11, 2012, 03:44:11 PM »
makikiabang  nlng muna  ako.. halos nabanggit na ang mga solution..
nagiging spoon feed tuloy  ;D
@TS sundan lang ang mga payo.. at makakapagkape kana
Offline ßlaze25
« Reply #31 on: May 11, 2012, 05:15:23 PM »
Mindanao po ako sir.,na try ko na din po iyan sir  hung LA42032 pin #6 at 5.
malamang LV ic sira neto,pero meron ako nakita dito na temporarily eh ginamitan mo na ng pre amp kasi nga wala pampalit na LV ic.
« Reply #32 on: May 11, 2012, 05:21:56 PM »
vol - and vol + di nagana sa service mode? sa pad-adjust ng data. tingnan mo nga exact chassis sa board ano ba iyan at ng di tayo naghuhulaan, biyernes pa naman ngayon.
post mo nga mga ic's ginamit. nahihirapan ng mga masters sa iyo. and kung pede pa-picture nga ng naka-service mode ng makita ng husto!
Offline nucleus
« Reply #33 on: May 11, 2012, 05:25:49 PM »
pwede tangalin lv direct na lang audio galing sa jungle ang audio kaso mono,
Offline ßlaze25
« Reply #34 on: May 11, 2012, 05:47:47 PM »
ok try ko tommorow ito,master kahit ba di na tayo dadaan og gagawa ng pre amp ay may lalabas na sounds?
Offline nucleus
« Reply #35 on: May 11, 2012, 05:50:45 PM »
yup kaso yung volume control nito ay magiging di pihit
« Reply #36 on: May 11, 2012, 05:56:19 PM »
baka naman wala lang 9V yung lv1116NV-EP ic mo? or pin 30(mute) ng QXXAVC646 may problem sa piyesa dito or loose con?
Offline ßlaze25
« Reply #37 on: May 11, 2012, 06:18:25 PM »
Kasi na try ko din i jump jungle pin#6 to pin #2 at 4 la42032 w/out remove lv ic pero no luck po,naku sensya na pati po kayong lahat ay nabulabog ko pa,e paano ba naman malayo ako sa electronic store sa davao city pa kasi ang mabibilhan ng parts dito which is 3.5hrs byahe from here so 1 day talaga gugulin mo sa pagbili ng part e kung 1 ic lang bibilhin mo naku wla lugi tayo,kaya ito pinipilit ko mapa sounds kahit konti lang temporarily.
Offline ßlaze25
« Reply #38 on: May 12, 2012, 10:49:16 AM »
Waaa huhuhu umaandar pa ito kahapon pag uwi ko bakit now ayaw na pilot lamp lang umiilaw..
disgrasya na siguro memory nito hu hu..
« Reply #39 on: May 12, 2012, 10:57:08 AM »
check na rin for loose connection
