Author Topic: Sanyo TV ST-21CF1 No Sounds.  (Read 2277 times)
Offline ßlaze25
Re: Sanyo TV ST-21CF1 No Sounds.
« Reply #40 on: May 12, 2012, 04:58:03 PM »
24C161 ic baka bumigay na ito nakalikot ko pa naman ito kahapon sa service mode pero ok pa naman ito kahapon hanggang umuwi ako ngayong umaga pagbukas ko ayaw na nakailaw na lang iyong standby pilot lamp niya pero walang indications pag i press mo chanel button or no raster and HV.
Offline ßlaze25
« Reply #41 on: May 12, 2012, 09:15:12 PM »
mga masters update ko lang kung bakit kaya ayaw na magpower ito di na po sumisipa ang HV niya wala naman ako ginalaw dito kahapon at check ko posible loose conection ok naman..,laking disgrasya ito lagot ako sa may ari,dati sounds lang problema ngayon ayaw na mag on hu hu..,HELP.
Offline comtronixs
« Reply #42 on: May 12, 2012, 11:13:16 PM »
minsan di talaga maiiwasan yan na manganak ang sira.. baka naman may nakaligtaan kalang sir. power mo muna via remote
Offline ßlaze25
« Reply #43 on: May 13, 2012, 06:43:17 AM »
na try ko na din pero ayaw talaga sir.
Offline ßlaze25
« Reply #44 on: May 13, 2012, 04:00:28 PM »
Bigyan niyo naman ako ng malinaw na guide para mabuhay ko ito ulit step by step po waaa hu hu hu hu...
Offline Macoy8932
  • Pogi/Ganda Points: 4
« Reply #45 on: May 13, 2012, 06:06:23 PM »
5Q0765RT ba main regulator nya?
Offline ßlaze25
« Reply #46 on: May 13, 2012, 07:08:47 PM »
di ako sure sir di ko nasilip kanina sa shop,pero siguro pag iyan ang main regulator ng Sanyo St 21CF1 malamang ganun nga iyon.
Offline ßlaze25
« Reply #47 on: May 14, 2012, 09:44:47 AM »
Chassis AC6A1 ...Regulator IC STR W6753
Offline ßlaze25
« Reply #48 on: May 14, 2012, 11:51:54 AM »
B+ measure is 125v mga master..
Offline comtronixs
« Reply #49 on: May 14, 2012, 12:37:17 PM »
load ka kaya ng bagong dumps
Offline ßlaze25
« Reply #50 on: May 14, 2012, 01:10:39 PM »
wala ako idea paano magload ng dumps sir..
Offline ßlaze25
« Reply #51 on: May 14, 2012, 01:51:55 PM »
Naku abnormal pala 9v neto galing sa transistor C2026 regulator yata ito ng 9v normal naman input nia galing secondary is 50v kaso output ng c2026 is 0.4v lang,sa 5v eh stable nman,ano sa tingin niyo mga masters sira na c2026 at iyon ba dahilan at di na magpower?
Offline DSM_elektronix_shop
  • Pogi/Ganda Points: 155
« Reply #52 on: May 14, 2012, 02:44:09 PM »
anng part ba ng transistor nag-in ang supply input sa collector ba??
pakilinaw...
DSM_electronics_shop
Alvin Y. Carulasan
NCII certificate holder# 1013160220767
PRC (ECT) Lisence Number# 0001237
Sinal Village, Taguig city
Offline ßlaze25
« Reply #53 on: May 14, 2012, 03:41:43 PM »
pakilinaw...
Offline comtronixs
« Reply #54 on: May 14, 2012, 06:04:55 PM »
buo ba yang trans nayan  kapg itest mo out of cirucit  kung ihang mo yang d681
Offline ßlaze25
« Reply #55 on: May 14, 2012, 06:09:17 PM »
na hang ko na din d681 and test voltage reading at walang pinagbago po still .4volts read.
  • Pogi/Ganda Points: 924
« Reply #56 on: May 14, 2012, 06:24:25 PM »
may in pero wlang out ?
nasa  apat lng na napabilog sa diagram ang dahilan..
open resist, open/leak power tranny
open/leak zener
except kng may over load sa power rail nya...
pakihinang nga muna  ts  ng maisolate mu ang problem
Offline ßlaze25
« Reply #57 on: May 14, 2012, 07:04:04 PM »
open/leak zener
alin po ang ihinang ko master,sensya na po newbie lang OJT ika nga.
« Reply #58 on: May 14, 2012, 07:28:51 PM »
yun nasa diagram mu na 9V na binilugan na katabi lng ng P.F  ;D
kong anung parts ang nakakabit jan.. nyu mu  muna float ang paa.. then power up kng makakaroon ka ng output voltage jan (9V)
Offline ßlaze25
« Reply #59 on: May 14, 2012, 07:59:18 PM »
@newborn salamat sir iyang advise mo una ko titirahin bukas pag open ko ng shop,update ko na lang bukas ito.
