Author Topic: kv-sw212n63 no color  (Read 216 times)
Offline kudilong
« on: May 11, 2012, 04:04:14 PM »
Mga bossing ano po kaya posibleng sira pag nawala po yung kulay ng tv. may konting naaaninag lang na picture..
Offline Min
  • Pogi/Ganda Points: 202
Re: kv-sw212n63 no color
« Reply #1 on: May 11, 2012, 04:08:22 PM »
TS when u say nawawala ang kulay ibig mo ba sabihin nag ba black and white ang picture at the same time dark sya na parang naka zero brightness?
Offline mcleod
  • Pogi/Ganda Points: 143
« Reply #2 on: May 11, 2012, 05:14:56 PM »
check mo jungle / chroma ic. google mo datasheet. hanapin mo kung may pin na labeled "color" - check mo components sa pin na ito. may osd ba ito? nalilipat mo ng channel? sa a/v mode, ganito din ba?
Offline kudilong
« Reply #3 on: May 11, 2012, 06:17:27 PM »
boss HG ganun nga parang alang zero brightness sya... at sir mcleod, oo khit ilipat sa ibang chanel at av mode ganun din.
Offline Min
« Reply #4 on: May 11, 2012, 06:20:59 PM »
subukan mo muna adjust screen control usually located to sa CRT board. Tignan mo kung magliliwanag ang buhay, picture pala. ;D
Offline kudilong
« Reply #5 on: May 11, 2012, 06:30:14 PM »
cge boss try ko tas update kita ano maging resulta...  :D
Offline acer
  • Pogi/Ganda Points: 109
« Reply #6 on: May 11, 2012, 09:24:51 PM »
abang lang sa update
nevergive up
Offline mcleod
« Reply #7 on: May 12, 2012, 07:19:02 AM »
dagdag mo pala check mo cpt / crt board mo. saka yung mga pins sa jungle mo for R,G,B at mga nakakabit dito. check mo na rin kung tama mga supply sa other ic's.
Offline kudilong
« Reply #8 on: May 12, 2012, 02:22:03 PM »
ok na yung kulay mga bossing... sa crt board nga nya ung may cold solder lang... big thanks sa lahat... ;D
Offline mcleod
« Reply #9 on: May 14, 2012, 09:48:13 AM »
congrats ts! i like you marunong kang makinig sa suggestion! dahil diyan 1 point ka sa akin! (ako una!)
