Welcome,
Guest
. Please
login
or
register
1 Hour
1 Day
1 Week
1 Month
Forever
Home
Help
Search
Login
Register
Mixed Systems and Specialization
Broadcast and Engineering Acoustics ( Hi-Fi Audio/Video )
Amplifiers, Mixers and Equalizers
Problem with Konzert AV-633
« previous
next »
Print
Pages: [
1
Go Down
Author
Topic: Problem with Konzert AV-633 (Read 484 times)
jojoc
CR2032 Battery
Pogi/Ganda Points: 1
on:
May 13, 2012, 08:27:35 AM »
Hellow mga sis pls. help naman.... when I turned on my amp. both chanels are ok naman after a while the relay of left ch. is turning off and on...and off. Papatayin ko amp.tapos io-on ko and then okey na naman and after a while ganon na naman problem but sometimes no problem at all.... ano kaya sira nito mga sis?
Logged
on:
BhongTech
Diesel Generator
Pogi/Ganda Points: 152
Gender:
Re: Problem with Konzert AV-633
Reply #1 on:
May 13, 2012, 08:31:59 AM »
resolder mo muna malamang loscon lang ito.
Logged
Reply #1 on:
jiggins20
Lead Acid Battery
Gender:
Reply #2 on:
May 13, 2012, 09:03:58 AM »
malamang loscon lng yan.....
Logged
Audio amp addict
Reply #2 on:
efren
Diesel Generator
Pogi/Ganda Points: 210
Gender:
old school audio fanatic
Reply #3 on:
May 13, 2012, 10:15:05 AM »
common problem yan sa Sakura, Konzert, dB audio,(China amps), re-soldering usually solves the problem...
Logged
"just keep 'em glowing"
Reply #3 on:
Disabled
Solar Power Satellite
Pogi/Ganda Points: 316
Reply #4 on:
May 13, 2012, 01:03:14 PM »
tirahin mo ung protection circuit, pero monitor mo muna ung DC out (ung sa speaker terminal) kung ilan, dapat di lalagpas ng +/- 100mv ung lalabas. short input to ground.
Logged
Reply #4 on:
pEN DoTA
Gas Turbine
Pogi/Ganda Points: 183
Reply #5 on:
May 13, 2012, 02:50:56 PM »
losscon lang yata
Logged
pete
Pogi/Ganda Points: 771
Gender:
Reply #6 on:
May 13, 2012, 03:02:32 PM »
resistor sa protection circuit
Logged
CASTILLO ELECTRONICS
http://tunein.com/tuner/?StationId=99570&
jyjc
Size AAA Battery
Pogi/Ganda Points: 25
Cisco Professionals
Reply #7 on:
May 13, 2012, 05:55:24 PM »
ano ang irresolder?
Logged
Disabled
Reply #8 on:
May 13, 2012, 06:12:00 PM »
^ ung malapit sa relay.
Logged
j a y k e z
Diesel Generator
Gender:
gimmegaggigsss
Reply #9 on:
May 13, 2012, 06:30:45 PM »
lahat nalang baka may coldsolder jan
Logged
http://www.elab.ph/forum/index.php
jyjc
Size AAA Battery
Cisco Professionals
Reply #10 on:
May 13, 2012, 06:35:54 PM »
pag meron DC output na 2.5Volts ano po ittroubleshoot
Logged
Disabled
Reply #11 on:
May 13, 2012, 06:40:50 PM »
^ ung ampli na mismo.
Logged
jyjc
Size AAA Battery
Cisco Professionals
Reply #12 on:
May 13, 2012, 06:48:33 PM »
sa speaker out my DC 2.5volts
Logged
jojoc
CR2032 Battery
Reply #13 on:
May 13, 2012, 08:47:53 PM »
thank u mga sis... Ill try all ur suggestions....
Logged
J@M
Diesel Generator
Pogi/Ganda Points: 122
Gender:
Reply #14 on:
May 14, 2012, 02:39:33 AM »
Cguruhin mo solder para wala an duda d2..
Logged
Don't Give up
Reply #14 on:
Print
Pages: [
1
Go Up
« previous
next »
